[AG-TECH] Bridge service?
Eric Olson
eolson at mcs.anl.gov
Wed Aug 27 18:24:06 CDT 2003
Randy,
You've started everything correctly. All you need to do now is enter the
venue with your VenueClient before selecting 'Use Unicast' (the bridge
name will appear with the default name "None/None").
To answer your service question, a quickbridge exists in a single venue.
Since you specified a VenueServer argument to the BridgeServer, the
BridgeServer started a quickbridge in each venue on that server.
Use --name and --location when starting the quickbridge if you want to
name it. Also note that you can specify an individual venue
(or file with a list of venues) to bridge instead of the entire
VenueServer.
Eric
On Wed, 27 Aug 2003, Randy Groves wrote:
> Well, I've figured out how to start the Bridge Server (presuming that I'm
> starting it right):
> ./BridgeServer.py --venueServer
> https://trinity.rt.cs.boeing.com:8000/VenueServer --qbexec /usr/bin/QuickBridge
> Now the question is - is this a venue service or a node service? And how
> does one expose this? I've tried selecting the 'Use unicast', and it
> doesn't give me any way to select a host that isn't in the (presently
> blank) list.
> -randy
