[AG-TECH] AGTk 2.1 Released
Bob Riddle
bdr at internet2.edu
Mon Aug 18 14:51:40 CDT 2003
well, I went back and uninstalled 2.1 and then logged in as the same
admin user that I used to install the AG 2.0 stuff and it found all the
globus stuff in that users directory. Just an interesting tidbit ...
then I started the Venue Client. It brought up the "Startup" message
BOX labelled "Loading Venue Client", the blue bar moved all the way
across & then ... it just hung ....
I'm happy to send the log ... if only I could remember where to find the
log ... sigh, vacation is tough.
Ivan R. Judson wrote:
>Hey Bob,
>Windows globus is under the hood now. The parts that are required are
>installed with the toolkit. You should be able to point it the same way you
>did the previous version of the software. That is there's a configuration
>wizard for globus stuff.
>If you've run that and it's not working, can you send your client log along
>and we'll take a look at it?
>Thanks,
>--Ivan
>>-----Original Message-----
>>From: Bob Riddle [mailto:bdr at internet2.edu]
>>Sent: Monday, August 18, 2003 9:20 AM
>>To: judson at mcs.anl.gov
>>Cc: ag-tech at mcs.anl.gov; ag-announce at mcs.anl.gov
>>Subject: Re: [AG-TECH] AGTk 2.1 Released
>>I followed the instructions for the AG2.1tk found at
>>http://www-unix.mcs.anl.gov/fl/research/accessgrid/software/re
>>leases/2.1/windows.html,
>>which included uninstalling WinGlobus.
>>When I go to launch the Venu client, it wants to know where my
>>usercert.pem resides ... I point it to the location & then
>>get errors on
>>startup ... is this something I just need to muddle through? Is
>>WinGlobus installed as part of the AG2.1tk install?
>>>The Access Grid Toolkit 2.1 is available for download at:
>>>http://www.mcs.anl.gov/fl/research/accessgrid/software/releas
>es/2.1/ind
>>ex.ht
>>ml
>>The Access Grid Toolkit 2.1 is available for download. Packaging has
>>again been reorganized to be only one windows installer for everything
>>except python and
>>wxpython. For more information on this release see the official release
>>page.
>>This release delivers functionality that will be usefuly to SC Global, but
>>all users! Highlights include:
>>- Support for Unicast Bridging Services.
>>- Completely re-engineered certificate management.
>>- Venue Server fallback configurability.
>>- A Node Configuration Wizard.
>>As always, feedback is desired, please file bug reports, feature
>>requests,
>>or enhancements via the Access Grid Bugzilla pages
>>(http://bugzilla.mcs.anl.gov/acucessgrid) or via the ag-tech mailing
>>list (mailto:ag-tech at mcs.anl.gov).
>>Thanks,
>>The AG Team
Bob Riddle (bdr at internet2.edu) Technologist,Internet2
3025 Boardwalk, Suite 100 Ann Arbor, Michigan 48108
Business Phone: 734.913.4257 Fax Number: 734.913.4255
"Opportunity is missed by most people because it is dressed in overalls and looks like work" Thomas Edison
