[AG-TECH] VenueClient unable to load default config
Frank Sweetser
fs at WPI.EDU
Mon Aug 18 08:56:02 CDT 2003
(I would bugzilla this, but there isn't an entry for 2.1 yet)
AccessGrid 2.1 installed, running on RedHat 9. Blew away ~/.AccessGrid, but
left ~/globus alone. On the first run, it hangs and has to be killed manually.
On the second run, it gets further, but dies and hangs after trying to load
the default config. Here's the traceback
Traceback (most recent call last):
File "/usr/bin/AGNodeService.py", line 141, in ?
nodeService.LoadDefaultConfig()
File "/usr/lib/python2.2/site-packages/AccessGrid/AGNodeService.py", line 84, in LoadDefaultConfig
raise Exception("Failed to load default configuration %s" %self.defaultConfig)
Exception: Failed to load default configuration defaultLinux
I've also attached the VenueClient.log file.
Frank Sweetser fs at wpi.edu
WPI Network Engineer
08/18/2003 09:53:14 AM 1074152064 AG.VenueClientUIClasses VenueClientUIClasses.py:3018 DEBUG My hostname is erwin.wpi.edu
08/18/2003 09:53:14 AM 1074152064 AG.VenueClientUIClasses VenueClientUIClasses.py:3023 DEBUG VerifyExecutionEnvironment: bind to local hostname of erwin.wpi.edu succeeds
08/18/2003 09:53:14 AM 1074152064 AG.toolkit Toolkit.py:52 DEBUG userConfigDir: /home/fs/.AccessGrid
08/18/2003 09:53:14 AM 1074152064 AG.CertificateManager CertificateManager.py:270 DEBUG initializing repository
08/18/2003 09:53:14 AM 1074152064 AG.Types VenueClient.py:122 ERROR bin.VenueClient::OnInit: WXGUIApplication creation failed
File "/usr/bin/VenueClient.py", line 119, in __init__
self.app = Toolkit.WXGUIApplication()
File "/usr/lib/python2.2/site-packages/AccessGrid/Toolkit.py", line 141, in __init__
self.gui)
File "/usr/lib/python2.2/site-packages/AccessGrid/CertificateManager.py", line 249, in __init__
self.InitializeRepository()
File "/usr/lib/python2.2/site-packages/AccessGrid/CertificateManager.py", line 282, in InitializeRepository
self.InitRepoFromGlobus(self.certRepo)
File "/usr/lib/python2.2/site-packages/AccessGrid/CertificateManager.py", line 300, in InitRepoFromGlobus
certLocations = pyGlobus.sslutilsc.get_certificate_locations()
AttributeError: 'module' object has no attribute 'get_certificate_locations'
08/18/2003 09:55:19 AM 1074152064 AG.VenueClientUIClasses VenueClientUIClasses.py:3018 DEBUG My hostname is erwin.wpi.edu
08/18/2003 09:55:19 AM 1074152064 AG.VenueClientUIClasses VenueClientUIClasses.py:3023 DEBUG VerifyExecutionEnvironment: bind to local hostname of erwin.wpi.edu succeeds
08/18/2003 09:55:19 AM 1074152064 AG.toolkit Toolkit.py:52 DEBUG userConfigDir: /home/fs/.AccessGrid
08/18/2003 09:55:19 AM 1074152064 AG.CertificateManager CertificateManager.py:242 DEBUG Opened repository /home/fs/.AccessGrid/certRepo
08/18/2003 09:55:19 AM 1074152064 AG.CertificateManager CertificateManager.py:841 ERROR No identity certs found
08/18/2003 09:55:19 AM 1074152064 AG.VenueClient VenueClient.py:789 INFO Applications dir = /etc/AccessGrid/applications
08/18/2003 09:55:19 AM 1074152064 AG.Types VenueClient.py:158 DEBUG bin.VenueClient::OnInit: ispersonal=1
08/18/2003 09:55:19 AM 1074152064 AG.PersonalNodePipes PersonalNodePipes.py:235 DEBUG Start service manager with ['/usr/bin/python2', '/usr/bin/AGServiceManager.py', '--pnode', '14:18:15:13,14,15,16,17,18,19,20,21,22']
08/18/2003 09:55:20 AM 1074152064 AG.PersonalNodePipes PersonalNodePipes.py:255 DEBUG Start node service with ['/usr/bin/python2', '/usr/bin/AGNodeService.py', '--pnode', '20:17:21:13,14,15,16,17,18,19,20,21,22']
08/18/2003 09:55:20 AM 1074152064 AG.PersonalNodePipes PersonalNodePipes.py:331 DEBUG Closing unused pipe ends
08/18/2003 09:55:20 AM 1074152064 AG.PersonalNodePipes PersonalNodePipes.py:105 DEBUG Close write 20
08/18/2003 09:55:20 AM 1074152064 AG.PersonalNodePipes PersonalNodePipes.py:97 DEBUG Close read 21
08/18/2003 09:55:20 AM 1074152064 AG.PersonalNodePipes PersonalNodePipes.py:105 DEBUG Close write 14
08/18/2003 09:55:20 AM 1074152064 AG.PersonalNodePipes PersonalNodePipes.py:97 DEBUG Close read 15
08/18/2003 09:55:20 AM 1074152064 AG.PersonalNodePipes PersonalNodePipes.py:97 DEBUG Close read 17
08/18/2003 09:55:20 AM 1074152064 AG.PersonalNodePipes PersonalNodePipes.py:105 DEBUG Close write 18
08/18/2003 09:55:20 AM 1074152064 AG.PersonalNodePipes PersonalNodePipes.py:129 DEBUG waiting on read on 13
08/18/2003 09:55:20 AM 1074152064 AG.PersonalNodePipes PersonalNodePipes.py:177 DEBUG Service manager running at https://erwin.wpi.edu:12000/ServiceManager
08/18/2003 09:55:20 AM 1074152064 AG.PersonalNodePipes PersonalNodePipes.py:97 DEBUG Close read 13
08/18/2003 09:55:20 AM 1074152064 AG.PersonalNodePipes PersonalNodePipes.py:129 DEBUG waiting on read on 19
