[AG-TECH] AG Linux dist. on Dell Precision
Gavin W. Burris aka 86
ga5in at psu.edu
Tue Nov 26 08:44:16 CST 2002
I have been very successful installing Access Grid on three Dell
Precision 530s.
The display node w/ Windows XP loading AG 1.2 with no problem. The
Linux machines are a different story. I believe Access Grid should be
distributed as packages and not a complete OS install be default.
I installed from a fresh ISO of Redhat 7.3, used apt-rpm to update all
Redhat packages, then installed all the Access Grid packages with the
ag-update.sh script someone posted a while back to get the 2001-08-16
22:28:00-05 snapshot of RPMs. All packages install fine, except for
the reflector, which I've never used. You will also have to move the
defunct /usr/local/ag/jre1.2.2 out of the way, then download and
install a newer build from java.sun.com. Then all is well.
Cheers.
Jonathan C. Humfrey wrote (on Mon, 25 Nov 2002 at 14:28):
> Hello,
> We have recently purchased a Dell Precision 530 and have had some trouble
> loading the AG Linux distribution iso on it. Has anyone encountered a
> problem with this and/or have suggestions?
> Thanks,
> Jonathan Humfrey
<<--=[ Gavin W. Burris aka 86 <ga5in at psu.edu> ]=-->>
<<--=[ Penn State Visualization Group Systems Programmer ]=-->>
<<--=[ http://viz.aset.psu.edu/ga5in ]=-->>
<<--=[ EOF ]=-->>
