[AG-TECH] RE: Gentner App CPU utilization
Osland, CD (Chris)
C.D.Osland at rl.ac.uk
Tue Mar 26 06:54:27 CST 2002
Jay,
Many thanks for that. I'm on leave this week but will try your
suggestion as soon as I can when I'm back in. My guess is that
the Gentner software meters will be less accurate (which is no
great problem) but that the sticky windows problem might be
improved or even solved.
Cheers
Chris
____________________________________________________________________
Chris Osland Office tel: +44 (0) 1235 446565
Digital Media and Access Grid Medialab tel: +44 (0) 1235 446459
BIT Department Access Grid room tel: +44 (0) 1235 445666
e-mail: C.D.Osland at rl.ac.uk Fax: +44 (0) 1235 445597
CLRC Rutherford Appleton Laboratory (Bldg. R18)
Chilton, DIDCOT, Oxon OX11 0QX, UK
[The contents of this email are confidential and
are for the use of the intended recipient only.
If you are not the intended recipient do not take
any action on it or show it to anyone else,
but return this email to the sender and delete your copy of it.]
-----Original Message-----
From: Jay Beavers [mailto:jbeavers at microsoft.com]
Sent: 25 March 2002 19:45
To: Osland, CD (Chris) ; Goss-Walter Torsten; ag-tech at mcs.anl.gov
Subject: Gentner App CPU utilization
Has anyone tried adjusting the process priority of APWare and seeing if
that helps the situation? The shorthand way to do this is to bring up
task manager, select Processes, right click on the app name, and choose
Set Priority -> Low.
If someone tests this out and finds it of use, I'll produce a little
shell app that will autolaunch the Gentner exe in low priority as well
as feed the source code of how to programmatically change the process
priority back to the Gentner folk for inclusion in a future update.
- jcb
From: Osland, CD (Chris) [mailto:C.D.Osland at rl.ac.uk]
Sent: Monday, March 25, 2002 6:33 AM
To: 'Goss-Walter Torsten'; ag-tech at mcs.anl.gov
Subject: RE: [AG-TECH] Access Grid Installation
Torsten,
I don't know whether you've been looking at ag-tech recently,
but here at RAL (and many locations have reported the same
problem) there is a severe problem with the Gentner control
software (AP-ware) running in the same machine as anything
else. We have fallen fowl of this, thinking that it was daft
to use a whole machine to control a 9600 baud serial line.
We are now looking at trying to squeeze the fourth machine back
into our racks-designed-for-3-computers!
For the rest, others have made most of the relevant comments,
although I would also note that there are problems fitting
all the required cards into a single machine (if that was a
direction you were thinking of going) as well as the problem
of one failing application possibly taking out another if it is
in the same machine.
Cheers
Chris Osland
From: Goss-Walter Torsten [mailto:torsten.goss-walter at dwd.de]
Sent: 22 March 2002 09:49
To: ag-tech at mcs.anl.gov
Subject: [AG-TECH] Access Grid Installation
Hello,
we are planning to set up an Access Grid node and combine it with
another
video conferencing system, i.e. VCON from Siemens. We try to recycle as
much
hardware as possible, especially the beamer, the cameras and the
microphones, which we want to use for both systems (shouldn't be a
problem,
I think).
According to the Access Grid hardware spec from Robert Olson, at least
four
computers are needed for display, video capture, audio capture and
control.
... two questions:
1. Is anyone of you already using a combined video conferencing system,
e.g.
Access Grid and VCON, on the same hardware plattform?
2. Does anybody have any experiences with using less than four servers
for
Access Grid? Is it possible to combine some of the functions, e.g. video
capture + audio capture on one machine by using a faster server?
Thanks for your answers in advance,
Regards
Torsten
Torsten Goss-Walter
Deutscher Wetterdienst
E-Mail: Torsten.Goss-Walter at dwd.de
