[AG-TECH] APware behaviour
Osland, CD (Chris)
C.D.Osland at rl.ac.uk
Tue Mar 19 09:28:02 CST 2002
I have just had the following response back from Gentner about the
behaviour of APware:
"But the answer for today is
that APWare will not work any better than the way it currently works.
APWare does use a lot of resources. It's main purpose is to configure AP
units, not real-time operate AP units. The design of the AP units limits
the external control. This has been much improved with the XAP units. You
can actually use G-Ware as the real-time controlling software but even that
is limited by the RS232 interface. This customer may have to go back to
using a dedicated computer if they want to use APWare as a real-time
operating system."
Putting a fourth machine back into our rig just to drive the Gentner
is not really an option - the rack enclosure, purchased for the project,
is just about full! Added to which, using a 1.4 GHz processor system
just to control a 9600 baud line brings us to Alice in Wonderland
territory (IMHO)!
I'll get back to Gentner with a comment along the lines that their
comment that "APWare does use a lot of resources" is a little
disingenuous - it uses every last cycle irrespective of CPU speed
and actually impacts the ability of the machine it is running on
to minimize or close the APware window itself, as far as I can tell -
it certainly does if, by chance, you focus on another window
while APware is running!
I haven't heard of G-Ware - is that for XAP units only? Does
it suffer the same way?
Cheers
Chris
____________________________________________________________________
Chris Osland Office tel: +44
(0) 1235 446565
Digital Media and Access Grid Medialab tel: +44 (0)
1235 446459
BIT Department Access Grid room tel: +44
(0) 1235 445666
e-mail: C.D.Osland at rl.ac.uk Fax: +44
(0) 1235 445597
CLRC Rutherford Appleton Laboratory (Bldg. R18)
Chilton, DIDCOT, Oxon OX11 0QX, UK
[The contents of this email are confidential and are for the use of the
intended recipient only.
If you are not the intended recipient do not take any action on it or show
it to anyone else,
but return this email to the sender and delete your copy of it.]
