[AG-TECH] APware running - always or just when needed
Robert Olson
olson at mcs.anl.gov
Mon Mar 18 10:27:52 CST 2002
I like having it up to keep an eye on things; it's interesting that they
don't see it being used that way.
That said, in the rooms that are up and running well we don't typically
have much need to poke at things with it. And especially with the XAP, the
full tool is really too complex for normal folks to want to deal with,
especially to poke at single levels (like the crosspoint attenuation that
helps manage the telco/local/network audio levels..)
--bob
At 04:12 PM 3/18/2002 +0000, Osland, CD (Chris) wrote:
>In an initial response to my query about APware hogging the CPU
>(original Subject: was something like Display Machine Performance)
>Gentner have got back to me with a comment as follows:
>"One thing that concerns me is it sounds like APWare is being
>used as a real time controller. It was always designed as a
>configuration help, not a real time controller that would be
>up and running all the time."
>I was wondering whether other AG sites typically have APware
>running all the time or just fire it up when they need to
>change configuration. I have tended to leave it running so
>that if I want to start a CD feed for audio line-up, or enable or
>disable a mic on the operator's desk, I can.
>I'd be interested in what others do.
>Cheers
>Chris
>____________________________________________________________________
>Chris Osland Office tel: +44
>(0) 1235 446565
>Digital Media and Access Grid Medialab tel: +44 (0)
>1235 446459
>BIT Department Access Grid room tel: +44
>(0) 1235 445666
>e-mail: C.D.Osland at rl.ac.uk Fax: +44
>(0) 1235 445597
>CLRC Rutherford Appleton Laboratory (Bldg. R18)
>Chilton, DIDCOT, Oxon OX11 0QX, UK
>[The contents of this email are confidential and are for the use of the
>intended recipient only.
>If you are not the intended recipient do not take any action on it or show
>it to anyone else,
>but return this email to the sender and delete your copy of it.]
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20020318/ea2b856f/attachment.htm>
