[AG-TECH] Re: Display Machine Performance
Robert Olson
olson at mcs.anl.gov
Fri Mar 15 12:51:36 CST 2002
Ah, good point. What was the proper cable -- we've been using standard DB9
straight-thru cables.
(Probably worth checking settings on the software too, to make sure flow
control set right there).
--bob
At 10:52 AM 3/15/2002 -0800, John Shalf wrote:
>I had some issues with APware freaking out because I was
>using a serial cable that didn't have CTS and RTS set up the
>way that Gentner required. So their serial driver spent all
>of its time agressively polling the serial port for
>messages. Soldering up a proper cable and enabling hardware
>flow control made the problem go away.
