[AG-TECH] USB Support for AG 1.0
Don Morton
morton at cs.umt.edu
Wed Jun 26 11:50:27 CDT 2002
I agree, thanks! Was this from the 2.2 kernel or 2.4
(I'm assuming the latter)?
Tom Coffin wrote:
> awesome documentation!
> ______________________________________________________
> At 09:36 AM 6/26/2002 +0900, shudo at ni.aist.go.jp wrote:
> >From: Don Morton <morton at cs.umt.edu>
> >> I've received a USB Kritter Cam and want to run it off a
> >> machine in which I've installed the AG 1.0 Redhat ISO
> >> available at www.accessgrid.org (dated 14 June 2001).
> >My brief investigation concluded that the Kritter USB has not worked
> >on Linux. The camera has Divio's NW801 chipset and I could not find a
> >device driver for it. Would someone corret me if I overlooked something.
> >Some of USB cameras are supported by Linux. I has been happy with a
> >camera with the OV511 chipset as once I have reported.
> > Linux OV511/OV518 Driver
> > http://alpha.dyndns.org/ov511/
> > CPiA webcam driver for Linux
> > http://webcam.sourceforge.net/
> > Linux support for Philips USB webcams
> > http://www.smcc.demon.nl/webcam/
> >The following list of USB cameras is an extract from a document
> >(Documentation/Configure.help) in Linux kernel tar ball:
> >USB IBM (Xirlink) C-It Camera support
> >CONFIG_USB_IBMCAM
> > Say Y here if you want to connect a IBM "C-It" camera, also known as
> > "Xirlink PC Camera" to your computer's USB port. For more
> > information, read <file:Documentation/usb/ibmcam.txt>.
> >USB OV511 Camera support
> >CONFIG_USB_OV511
> > Say Y here if you want to connect this type of camera to your
> > computer's USB port. See <file:Documentation/usb/ov511.txt> for more
> > information and for a list of supported cameras.
> >Philips webcam support
> >CONFIG_USB_PWC
> > Say Y or M here if you want to use one of these Philips USB webcams:
> > PCA645, PCA646, PCVC675, PCVC680, PCVC690, PCVC730, PCVC740, or
> > the Askey VC010. The PCA635, PCVC665 and PCVC720 are not supported
> > by this driver and never will be.
> > This driver has an optional plugin, which is distributed as a binary
> > module only. It contains code that allow you to use higher
> > resolutions and framerates but may not be distributed as source.
> > But even without this plugin you can these cams for most
> > applications.
> > See <file:Documentation/usb/philips.txt> for more information and
> > installation instructions.
> > The built-in microphone is enabled by selecting USB Audio support.
> >USB SE401 Camera support
> >CONFIG_USB_SE401
> > computer's USB port. See <file:Documentation/usb/se401.txt> for more
> >USB STV680 (Pencam) Camera support
> >CONFIG_USB_STV680
> > computer's USB port. This includes the Pencam line of cameras.
> > See <file:Documentation/usb/stv680.txt> for more information and for
> >Vicam
> >CONFIG_USB_VICAM
> > Say Y here if you have 3com homeconnect camera (vicam).
> >QuickCam BW Video For Linux
> >CONFIG_VIDEO_BWQCAM
> > Say Y have if you the black and white version of the QuickCam
> > camera. See the next option for the color version.
> >QuickCam Colour Video For Linux
> >CONFIG_VIDEO_CQCAM
> > This is the video4linux driver for the colour version of the
> > Connectix QuickCam. If you have one of these cameras, say Y here,
> > otherwise say N. This driver does not work with the original
> > monochrome QuickCam, QuickCam VC or QuickClip. It is also available
> > as a module (c-qcam.o).
> > Read <file:Documentation/video4linux/CQcam.txt> for more information.
> >W9966 Webcam (FlyCam Supra and others) Video For Linux
> >CONFIG_VIDEO_W9966
> > Video4linux driver for Winbond's w9966 based Webcams.
> > Currently tested with the LifeView FlyCam Supra.
> > otherwise say N.
> > This driver is also available as a module (w9966.o).
> > Check out <file:drivers/media/video4linux/w9966.txt> and
> > <file:drivers/media/video/w9966.c> for more information.
> >CPiA Video For Linux
> >CONFIG_VIDEO_CPIA
> > This is the video4linux driver for cameras based on Vision's CPiA
> > (Colour Processor Interface ASIC), such as the Creative Labs Video
> > Blaster Webcam II. If you have one of these cameras, say Y here
> > and select parallel port and/or USB lowlevel support below,
> > otherwise say N. This will not work with the Creative Webcam III.
> >CPiA USB Lowlevel Support
> >CONFIG_VIDEO_CPIA_USB
> > This is the lowlevel USB support for cameras based on Vision's CPiA
> > (Colour Processor Interface ASIC), such as the Creative Webcam II.
> > If you have the USB version of one of these cameras, say Y here,
> > It is also available as a module (cpia_usb.o).
> > Kazuyuki Shudo, Ph.D. shudo at ni.aist.go.jp, http://www.shudo.net/
> > Grid Technology Research Center
> > National Institute of Advanced Industrial Science and Technology (AIST)
> ___________________________________________________________
> Tom Coffin .......................... tcoffin at ncsa.uiuc.edu
Don Morton http://MRoCCS.cs.umt.edu/~morton/
Department of Computer Science The University of Montana
Missoula, MT 59812 | Voice (406) 243-4975 | Fax (406) 243-5139
