[AG-TECH] Font.
Vikas Chowdhry
vikas at evl.uic.edu
Fri Jan 25 14:27:35 CST 2002
In the default installation of AGIB Version 1.0 I could not locate any
such file. font.properties file is however stored in the
<java-directory>/jre/lib once you install the Java sdk from the java site.
I did that and replaced the above specified file with the patch but I
still get the error message when I run arm-evenlistener.
Any pointers?
Thanks
Vikas
On Thu, 24 Jan 2002, Kabe Vanderbaan wrote:
> All,
> You may see the following error when you run arm-eventlistener or vrm-eventlistener,
> I have seen this on my redhat 7.2 systems.
> Fonts specified in font.properties not found [--symbol-medium-r-normal-* ....
> There is a patch available at the location below
> Kabe
> http://www.geocrawler.com/archives/3/84/2001/9/0/6642826/
> (Inluded below as well)
> > Hi,
> > When I tried to run a JAVA Swing application on linux Red Hat7.1, I got
> > messages like:
> > Could you pls tell me how to set the fonts?
> > Thanks a lot!
> Hi!
> There is a patch for the font.properties file.
> You should replace it with the new one:
> http://java.sun.com/j2se/1.3/font.properties
> See http://java.sun.com/j2se/1.3/relnotes.html#fontproperties
> for details.
> Kabe VanderBaan, Senior Research Engineer
> Networks and Infrastructure Research, Motorola Labs
> Phone: 847-576-1832
> Cell: 847-980-4100
> http://internet2.motlabs.com/agnode/index.htm
> http://internet2.motlabs.com/agnode/tech/ipaq/index.htm
