[AG-TECH] Serial Connections between Sony EVI-D30/D31 Cameras
Marcia Perry mperry at lbl.gov
Mon Feb 11 13:17:51 CST 2002
Hello Steve,
We've successfully chained the Sony EVI-D30s to one serial port.
The specs say you can chain up to 7, but we've tested with up to 3
cameras.  Some old API that I have shows this pinout below for the
daisy-chain cables:
	MD8P			MD8P
	1 DTR	---------	2 DSR
	2 DSR	---------	1 DTR
	3 TXD	---------	5 RXD
	4 GND   ---------	4 GND
	5 RXD	---------	3 TXD
	6 GND			6 GND
	7 IR OUT		7 OPEN
	8 MD Caution		8 OPEN
So 5 pins need to be wired, but I do suggest buying cables from
sites mentioned by Ivar.
If you want to control the cameras from a computer (up to 7 on one port is
possible), we have a camera control system available at http://www-itg.lbl.gov/mbone/devserv.
-- marcia
"Steve McGough (Mobile)" wrote:
> Hi,
> Were interested in using serial control of the Sony EVI-D30/D31 camera.
> Has anyone else tried using these cameras on serial control?
> We can get the first camera working but you are supposed to be able to
> daisy-chain up to three of them together. Has anyone tried this?
> The main question is do all eight pins need to be wired? or can you get
> away with five in the same way as the link to the PC?
> Many thanks,
> steve..
> Dr A. Stephen McGough
> Research Associate, Imperial College of Science, Technology and Medicine,
> Department of Computing, 180 Queen's Gate, London SW7 2BZ, UK
> tel: +44 (0)207-594-8310  fax: +44 (0)207-581-8024
> Assistant Warden, Brabazon House, Pimlico, 5 Moreton Street, London
> SW1V 2PN, UK            tel: +44 (0)207-828-4733 fax: +44 (0)207-233-8105
Marcia Perry                            MPerry at lbl.gov
Lawrence Berkeley National Laboratory   WORK#  (510) 486-6786
1 Cyclotron Road                        FAX#   (510) 486-6363
Berkeley, CA 94720     			MS: 50A-3111
More information about the ag-tech mailing list
