[AG-TECH] Lurkers in the venues
Tony Rimovsky tony at ncsa.uiuc.edu
Fri Feb 1 13:54:22 CST 2002
Some venues use glop addresses and some are legacy addresses that
were, at one point, assigned by SDR and are still in use long after
the SDR event expired.
/tsr
On Thu, Jan 31, 2002 at 12:41:09PM +0900, shudo at ni.aist.go.jp wrote:
> This discussion brought up one question in my mind. AG
> venues set up by Argonne people keep 20 or more IP
> multicast group addresses. Why those numbers
> (eg. 224.2.177.155 for AG Lobby) are choosen? Are they
> reserved? Are they compliant with the following
> convention?
> | Subject: Re: [AG-TECH] Virtual Venues Server Software
> | From: Robert Olson <olson at mcs.anl.gov>
> | Date: Tue, 15 Jan 2002 08:30:09 -0600
> | If your site has an Autonomous System number assigned, you have 256
> | addresses of class D space to play with. See http://www.ogig.net/glop/ for
> | a calculator to tell you them.
> > It's probably not worth worrying about for most of the conversations
> > taking place, but I just want to make certain that everyone is clear on
> > this... even if there are no apparent "lurkers" in a Virtual Venue,
> > there is no guarantee that someone else is not listening.  Although it
> > may not be likely, someone could join the multicast groups associated
> > with a VV and eavesdrop, right?  Just because the Vic and RAT interfaces
> > don't show someone else in the "room" doesn't mean it is secure.
> > Jeff
>   Kazuyuki Shudo		shudo at ni.aist.go.jp
>   Grid Technology Research Center
>   National Institute of Advanced Industrial Science and Technology (AIST)
More information about the ag-tech mailing list
