[AG-TECH] video only shows on primary display
Allan Spale
aspale at evl.uic.edu
Mon Apr 22 11:01:34 CDT 2002
Chris,
That is one of the things that I do not like about the display setup for
the G450. It seems to treat two displays as one logical display. If you
find a workaround for this (where each individual display appears as
itself in Display Properties), please let me know.
Allan
EVL at UIC
node-op
On Mon, 22 Apr 2002, Osland, CD (Chris) wrote:
> Oh - another piece of info. While the G200 shows up as
> multiple screens under the Advanced tab, at least for me the
> G450 showed as a single screen that you could set up as 2048
> (or more) wide. The net result is much the same (the first
> 1024 pixel columns come out of the first socket, the next out
> of the second) but it looks different in the software.
> Cheers
> Chris
> ____________________________________________________________________
> Chris Osland Office tel: +44 (0) 1235 446565
> Digital Media and Access Grid Medialab tel: +44 (0) 1235 446459
> BIT Department Access Grid room tel: +44 (0) 1235 445666
> e-mail: C.D.Osland at rl.ac.uk Fax: +44 (0) 1235 445597
> CLRC Rutherford Appleton Laboratory (Bldg. R18)
> Chilton, DIDCOT, Oxon OX11 0QX, UK
> [The contents of this email are confidential and
> are for the use of the intended recipient only.
> If you are not the intended recipient do not take
> any action on it or show it to anyone else,
> but return this email to the sender and delete your copy of it.]
> -----Original Message-----
> From: Allan Spale [mailto:aspale at evl.uic.edu]
> Sent: 22 April 2002 15:59
> To: Stewart Macneill
> Cc: ag-tech at mcs.anl.gov
> Subject: Re: [AG-TECH] video only shows on primary display
> Stewart,
> As a future reference, though this probably will not apply in your case
> since your video card is not recognized, but always make sure to have the
> same color depth selected for all your displays. Otherwise, video will
> show up fine in one display, and then disappear in another display.
> One thing to make sure of is that multiple displays are enabled. This can
> be done by opening up Display Properties and pressing the Advanced button.
> A Matrox dialog will appear. Press the DualHead tab and select the option
> DualHead Multi-Display. Even though you may have already done this, it is
> possible that one of the sections of the Matrox dialog will be of use.
> EVL uses two Matrox G450 cards (one AGP and one PCI) on our display
> machine. We used to have one G200, but after Windows 2000 we noticed
> performance hit (probably related to the driver), so we switched to our
> current setup.
> I hope this information helps you come up with ideas for how to have your
> displays work properly.
> Allan
> EVL at UIC
> node-op
> On Mon, 22 Apr 2002, Stewart Macneill wrote:
> > Hi all
> > Just in the process of coaxing our node into life. I've got the standard
> > G450 AGP and G200 PCI configuration set up on a dual CPU IBM
> IntelliStation
> > but have a problem in that the video from my cameras only shows up in the
> > primary display.
> > It doesn't seem to matter whether the primary display is set to the LCD
> > monitor or a projector, PCI or AGP, as soon as I drag the Vic window onto
> > one of the other displays, the feed is lost - if I minimize and restore
> then
> > the window just picks up whatever is behind it. If I move it back into
> the
> > primary display, I see the video again.
> > The only two oddities I have noticed are that W2K Advanced Server (display
> > machine) only reports one of the G450 heads in the Matrox window control
> > panel, and the capture computer (also a dual CPU IntelliStation, Red Hat
> > 7.2) reports that it can't find a monitor list and is using the 'main'
> > display. I don't know if that is at all significant.
> > Has anyone come across this problem? I had a search through the AG-Tech
> > archives, but didn't find anything.
> > Thanks for any suggestions.
> > Stewart
> > Stewart D Macneill
> > NeSC Systems Manager (Glasgow)
> > University of Glasgow
> > Dept of Computing Science
> > 17 Lilybank Gardens
> > G12 8RZ
> > Tel: 0141 330 3102 (direct)
> > Fax: 0141 330 4913
> > email: macneisd at dcs.gla.ac.uk <mailto:macneisd at dcs.gla.ac.uk>
