[AG-TECH] RE: Fixing the audio connections etc in PS2 room
Kyoung Shin Park park at evl.uic.edu
Fri Sep 21 15:55:48 CDT 2001
Today, Seung and I tried to lable the audio connection.
But we figured out that the audio connection is not matched with the plasma
panel input source. So, before we start re-arranging the cabling in PS2
room, I'd like to ask you
what's needed, e.g. AG needs audio input/output.
Next week we will start re-arrange cables.
Let us know if anyone has any particular needs here.
Thanks.
-----Original Message-----
Sent: Friday, September 21, 2001 11:02 AM
To: Jason Leigh
Cc: cavern at evl.uic.edu
Subject: Re: Fixing the audio connections etc in PS2 room
Okay...I think it's the second mic (not Polycom) that causes the feedback
problem, and you end up hearing yourself through the speakers. I'll try to
sort + label stuff.
Atul
On Fri, 21 Sep 2001, Jason Leigh wrote:
> Hi Atul, Kyoung,
> can you two fix/clearup/clarify the audio connections on the PlasmaPC.
Right
> now people are plugging in and unplugging audio rather than using the
switch
> and so there is a weird feedback problem somewhere that we need to fix.
Also
> we need to label the audio select box so it is obvious which button does
> what.
> Thanks
> Jason
> Jason Leigh, PhD
> spiff at evl.uic.edu              Electronic Visualization Lab (M/C 154)
> EVL Phone (312) 996-3002         University of Illinois at Chicago
> EVL FAX   (312) 413-7585         851 S. Morgan St. Room 1120 SEO
> http://www.evl.uic.edu/spiff     Chicago, IL 60607-7053
____________________________________________________________________________
__
Atul Nayak					  Dept. of Computer Science
Electronic Visualization Laboratory               EVL FAX   : 312-413 7585
University of Illinois at Chicago		  Home Phone: 312-775 7538
More information about the ag-tech mailing list
