[AG-TECH] Matrox G200 problem on the second monitor
Robert Olson
olson at mcs.anl.gov
Mon Sep 17 16:33:28 CDT 2001
Did you install the Matrox drivers from their website? I think this is
somethign that may show up with the default win2k drivers.
You'll see the symptom of no video on the display if the different panes
are set to different color depths. If you set them all to 16-bit you should
see video.
--bob
At 04:28 PM 9/17/2001 -0500, Supreeya Miller wrote:
>Thank you for the quick response on the rat problem. I missed this one on
>the AGDP site.
>However, I have another problem that I have not found the solution for it
>yet. Right now the AGnode is in the temporary area and using only 2
>SonicView A70f 17"-monitors. I'm trying to set the resolution on the second
>monitor. I can only set to the resolution 856 x 480 in order to get True
>Color(32 bit). When I set the resolution to 1024 x 768 or 1152 x 864, the
>color sets itself automatically to High Color(16 bit). I tried to change
>the color to True Color(32 bit), the resolution changed itself to 856 x 480.
>With the color setting to anything less than True Color(32 bit) on the
>second monitor, I can not see any video image at all.
>Any suggestion on this problem?
>Please forgive me if I missed this in the AGDP site.
>Supreeya Miller
>System Administrator/Visualization Researcher
>High Performance Visualization Center
>Center of Higher Learning
>Building 1103
>Stennis Space Center, MS 39539
>Phone: 228-688-2969
>Fax: 228-688-7454
>E-mail:Supreeya.Miller at usm.edu
