[AG-TECH] AG Virtual Venue Server Prototype available
Kabe Vanderbaan
Kabe_VanderBaan-KVANDER2 at email.mot.com
Fri Sep 14 20:23:47 CDT 2001
Bob,
I have followed the install directions on both your email and in the
/usr/share/doc/ag-vv-1.0.00/INSTALL directory. I successfully installed
the software, but when I run the vv-configure script, I receive:
--begin
Can't locate DBI.pm in @INC (@INC contains: /usr/local/ag/VVServer/lib
/usr/lib/perl5/5.6.0/i386-linux /usr/lib/perl5/5.6.0
/usr/lib/perl5/site_perl/5.6.0/i386-linux /usr/lib/perl5/site_perl/5.6.0
/usr/lib/perl5/site_perl .) at /usr/local/ag/VVServer/lib/DBSetup.pm
line
32.
BEGIN failed--compilation aborted at
line 32.
Compilation failed in require at /usr/local/ag/VVServer/bin/vv-configure
line 20.
line 20.
--end
Here is a rundown of my process:
I installed Redhat 7.1 on a clean box
I went to ftp://ag-tech.mcs.anl.gov/pub/vv/ and downloaded all of the
rpms
I went to redhat.com and downloaded the other rpms I needed
I then installed in this order using "rpm -U -v <rpm name>"
apache-1.3.12-25.i386.rpm
postgresql-7.0.2-17.i386.rpm
postgresql-server-7.0.2-17.i386.rpm
moo-1.8.1-1.i386.rpm
perl-URI-1.15-1.i386.rpm
perl-XML-Parser-2.30-1.i386.rpm
perl-SOAP-Lite-0.51-1.i386.rpm
php-4.0.4pl1-3.i386.rpm
php-pgsql-4.0.4pl1-3.i386.rpm
ag-vv-1.0.00-1.i386.rpm
I then ran
/sbin/service httpd start
/sbin/service postgresql start
/sbin/service vv-moo start
and
/sbin/chkconfig httpd on
/sbin/chkconfig postgresql on
/sbin/chkconfig vv-moo on
successfully.
Finally, I ran the vv-config script and received the messages from
above.
Any Ideas why I would receive this? Am I using the correct versions?
Kabe
Robert Olson wrote:
> [Once again, properly this time]
> A prototype release of the new Virtual Venues server is now available.
> You will need a cleanly built RedHat 7.1 system. When you build it, ensure
> the following packages are installed:
> Web Server
> SQL Server
> For those that use KickStart, I have attached a KickStart configuration
> file that I use for building test machines. (You'll have to change the NFS
> build option to something appropriate to your site, of course).
> The RPMs are available at ftp://ag-tech.mcs.anl.gov/pub/vv/. Install all
> the .i386.rpm files:
> rpm -U -v <rpm filenames>
> You will find further installation notes in
> The primary purpose of this release is to shake out installation issues.
> There are some loose ends in the implementation as yet that will be fixed
> in the short term.
> You can report problems with the installation via the Bug Tracker at Source
> Forge. Go to http://sourceforge.net/projects/accessgrid and click on the
> Bugs link to get there. Set the category in the bug report to "Virtual
> Venue Server".
> thanks,
> --bob
> vv.ks.cfg Type: unspecified type (application/octet-stream)
> Encoding: base64
Kabe VanderBaan, Research Engineer
Networks and Infrastructure Research, Motorola Labs
Phone: 847-576-1832
Cell: 847-980-4100
