[AG-TECH] Multicast beacon questions
Bill Nickless
nickless at mcs.anl.gov
Wed Oct 24 16:20:22 CDT 2001
At 02:37 PM 10/24/2001 -0400, David E. Bernholdt wrote:
>As my networking friends point out, the current beacon approach isn't
>terribly scalable as the number of AG nodes increases (presuming a 1:1
>association with beacons). Its already enough to trigger concern with
>folks here, though maybe its just that they're not used to seeing
>any mcast traffic at all. Has anyone thought about this?
My experience with multicast deployment is that a given network is at one
of two levels of multicast deployment (when multicast is deployed at all!):
- Initial deployment: uses software forwarding, dense-mode
flood-and-prune routing protocols, and so forth. Generally this
works "correctly" for things like the NASA Select TV one-to-many
desktop applications. Overall packet rates are in the 10-250
packets/second range.
- Solid Deployment: uses hardware forwarding, sparse-mode
forwarding protocols, IGMP snooping on switched networks, and
so forth. This level of deployment supports packet rates exceeding
1000 packets/second, and is absolutely required for Access Grid.
If a network is at the "Initial Deployment" level, then the beacon group
traffic levels will cause problems right away. I believe this is a good
thing, because it highlights the need to make infrastructure upgrades to
the "Solid Deployment" level.
In other words, if today's beacon group is causing problems with a given
network, that network is not yet properly configured to support an Access
Grid node.
The good news is that experimental network hardware and software is no
longer required to get to the "Solid Deployment" level. The required
multicast routing protocols are in Cisco GA code, for example.
Bill Nickless http://www.mcs.anl.gov/people/nickless +1 630 252 7390
PGP:0E 0F 16 80 C5 B1 69 52 E1 44 1A A5 0E 1B 74 F7 nickless at mcs.anl.gov
