[AG-TECH] Video Titling for All...for the Cost of One Video Stream
Ivan R. Judson
judson at mcs.anl.gov
Tue Oct 30 21:57:14 CST 2001
Alternatively if anyone is interested in testing Open Mash's vic, it claims
to have the ability to load a ppm overlay. We are interested in it's
comparative performance to the ucl vic we've been using, as well as it's
stability.
http://www.openmash.org/
--Ivan
> -----Original Message-----
> From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov]On
> Behalf Of Allan Spale
> Sent: Tuesday, October 30, 2001 3:09 PM
> To: ag-tech at mcs.anl.gov
> Subject: [AG-TECH] Video Titling for All...for the Cost of One Video
> Stream
> Hello,
> I have determined a way for * everyone * to have the capability to add a
> banner title in a manner similar to what is seen on the video stream of
> EVL. Even though the setup is a bit more cumbersome than using a video
> mixer, I would estimate that you would have about the same degree of
> flexibility. All of these steps must be performed on the video machine
> running a Gnome desktop (it is probably possible to do these steps on
> another windowing system, but I am not experienced with Linux desktops
> like KDE, so I would not know how offhand) with at least four
> "pagers"/desktops (this is the thing in the center of the task-bar-like
> thing that shows how windows are arranged on your desktop).
> Here are the steps to take:
> 1. Determine the video stream that you would want to have the banner
> title (called "SOURCE VIDEO" from now on). Find the VIC window that
> contains this video stream and bring up its window in one of the top
> desktop (that is, on this diagram, make sure that the "highlighted
> desktop" is one of the top desktops or rectangles).
> 2. Move the "task bar" by pressing one of the arrow buttons on the "task
> bar". If done properly, it should slide to the left or the right and
> "disappear". (To bring it back, press the visible arrow button.)
> 3. Move the SOURCE VIDEO to the bottom left-hand portion of the screen so
> that only the title bar of the window is seen on this desktop. On the
> desktop below, the video stream should appear.
> 4. Find the VIC window that contains a video stream that is not needed
> (called "X11 VIDEO" from now on). On that VIC window, press the Menu
> button. In the dialog box that appears, press the Device button. From
> the list that appears, select X11. Then press the Dismiss button. This
> will now allow that video stream to capture the upper-left hand corner of
> whatever desktop is currently viewed on your screen.
> 5. Use the applet in the center of the task bar to switch to the lower
> desktop. This should display the desktop that has the SOURCE VIDEO window
> with the title bar appearing in the above desktop. If you have your
> display machine video visible at this time, bring up the X11 VIDEO window.
> You will notice that the X11 VIDEO window should be transmitting the
> SOURCE VIDEO. As a result, you should have two video windows that have
> exactly the same content. If you are unhappy with the location of the
> video window, return to the above desktop and move the video window again
> until it is in an acceptable location.
> 6. Staying in this desktop, bring up a graphics program or text program
> that you will use for titling. Electric Eyes (found in the Graphics menu
> that appears when pressing the "G" button on the task bar) is a good
> program because it allows graphics to be scaled depending on how large the
> window is. For text, try gEdit (found in the Applications menu that
> appears when pressing the "G" button on the task bar). For animations,
> you could try Flash and a browser or Java.
> 7. Open the file or create the content that will act as the banner title
> (called "CONTENT" from now on).
> 8. Position the CONTENT somewhere on the video window ignoring the fact
> the location of the CONTENT's title bar. For name titling, placing the
> CONTENT on the lower portion of the X11 VIDEO is suitable.
> 9. Once the CONTENT has been placed, right-click on the title bar of the
> CONTENT, and select "Set Border Style" -> BORDERLESS. Once this is done,
> the borders of the CONTENT window and the title bar of the CONTENT window
> disappear. Note that once you do this, you cannot move that window. You
> would have to reload the content and repeat this step. Repeat this step
> for all windows that should contatin content.
> 10. On the X11 VIDEO, switch to the desktop containing the title bar of
> the X11 VIDEO. Right-click on the title bar of the X11 VIDEO and select
> "Set Border Style" -> SHAPED. This will remove the borders of the X11
> VIDEO window.
> 11. Now, make the CONTENT windows active so that they appear over the X11
> VIDEO, and you have a titled video window.
> 12. On any desktop where you hid the task bar, press the button on the
> hidden taks bar to make it reappear.
> So, that's it. If anyone has any questions or comments or better ideas,
> please share them.
> Allan
> EVL/UIC
> node-op
