[AG-TECH] Re: Numerator vs Denominator
Bill Nickless
nickless at mcs.anl.gov
Mon Oct 29 08:54:38 CST 2001
At 09:37 AM 10/29/2001 +0000, Chris Greenhalgh wrote:
>but there is more than one way to determine and/or communicate
>packets per second transmitted. No packets getting through is
>simple :-) If on the other hand any are getting through then they
>can contain info on sent packets and/or their own sequence
>numbers so that you can infer pps xmit.
While true, I still say that the automatic scaling of beacon bandwidth is:
- intractable in practice because not all sources hear each other
due to lack of uniform reachability
- unnecessary in the context of O(100) beacons supporting Access Grid
(1000 pps is roughly equivalent to one Access Grid session; if this
is causing problems for networks somewhere then those networks need
to be repaired to support Access Grid nodes)
Bill Nickless http://www.mcs.anl.gov/people/nickless +1 630 252 7390
PGP:0E 0F 16 80 C5 B1 69 52 E1 44 1A A5 0E 1B 74 F7 nickless at mcs.anl.gov
