[AG-TECH] Fwd: Re: Havards message
Robert Olson
olson at mcs.anl.gov
Wed May 30 07:09:27 CDT 2001
More on this.
>X-Authentication-Warning: mail.internet2.edu: Host [65.89.75.10] claimed
>to be sippie.star2.net
>Date: Tue, 29 May 2001 23:02:03 -0400
>From: Marshall Eubanks <tme at 21rst-century.com>
>Reply-To: tme at 21rst-century.com
>Organization: Multicast Technologies
>X-Mailer: Mozilla 4.7C-CCK-MCD {C-UDP; EBM-APPLE} (Macintosh; I; PPC)
>X-Accept-Language: en
>To: "Kevin C. Almeroth" <almeroth at cs.ucsb.edu>, Havard Eidnes <he at nordu.net>,
> Bill Nickless <nickless at mcs.anl.gov>
>CC: wg-multicast at internet2.edu
>Subject: Re: Havards message
>Sender: owner-wg-multicast at internet2.edu
>Dear Harvard;
>1.) We are also involved with multicast monitoring and would be
>glad to work with you in resolving problems. We can mtrace
>to your through Sprint, etc.
>2.) My multicast contact at Sprint is Jeff Loughridge <jeffl at sprint.net>;
>but queries should also be sent multicast at sprint.net, a mailbox for
>questions or issues about multicast on Sprint's network.
>3.) I would separate the operators of the beacon (who may or may not
>have anything to do with the network the beacon is operating on) from the
>network & NOC engineers (who do). In other words, I do NOT think that
>a e-mail address for a beacon site should be required or trusted.
>4.) See http://beaconserver.accessgrid.org:9999/host for IP addresses.
>I use MBGP to see how the multicast connectivity should go.
>5.) I think that most connectivity troubles are due to MSDP back-holes.
>By comparison, MBGP appears pretty stable. I have been working on
>the inverse problem (taking msdp logs from several sites, and finding
>out where the blackholes are), and am convinced that this can be done
>given sufficient numbers of logs.
>6.) I do not see a beacon from nordu.net, so I cannot see whether
>we have connectivity with you or not.
> Regards
> Marshall Eubanks
> Multicast Technologies, Inc.
> 10301 Democracy Lane, Suite 410
> Fairfax, Virginia 22030
> Phone : 703-293-9624 Fax : 703-293-9609
> e-mail : tme at on-the-i.com http://www.on-the-i.com
> Test your network for multicast : http://www.multicasttech.com/mt/
>Check the status of multicast in real time :
>http://www.multicasttech.com/status/index.html
>"Kevin C. Almeroth" wrote:
> > >>To: wg-multicast at internet2.edu
> > >>Subject: Beacons, in-addr.arpa and forward-DNS
> > >>From: Havard Eidnes <he at nordu.net>
> > >>Hi,
> > >>I started looking a bit closer at the accessgrid beacon multicast
> > >>reachability status, with a view towards finding out what is causing
> > >>some of the reachability problems my beacon is experiencing.
> > >>I noticed that the accessgrid beacon status page now hsa 5 beacons
> > >>which apparently do not have an in-addr.arpa DNS registration, which
> > >>looks a little lame.
> > >>Furthermore, I found at least two beacons that I have connectivity
> > >>problems with (nephilim.sprintlink.net and vogt.sprintlink.net)
> > >>where there does not exist a name-to-IP-address mapping for these
> > >>names. Needless to say, this creates somewhat of a problem when it
> > >>comes to debugging the connectivity problems from my end of things.
> > >>Furthermore, it appears that the user/host combinations are similar
> > >>to e-mail addresses -- I assumed that is the intent. I'll however
> > >>bet that attempts at sending e-mail to the beacon identifiers would
> > >>generate quite a number of bounces, something which again makes
> > >>debugging more difficult than it otherwise can be.
> > >>I'll therefore appeal to those of you who run beacons on the
> > >>accessgrid group to at least make sure that reverse *and* forward
> > >>mappings for the beacon IP addresses are consistent with reality,
> > >>and that such mappings exist.
> > >>I'm not sure about whether it should be possible to send e-mail to
> > >>the beacon identifiers (for what it's worth, it is possible to send
> > >>e-mail to my beacon identifier).
> > >>Secondly, I would like to get in touch with the administrator of the
> > >>sprintlink.net participant beacons, to get the IP addresses of the
> > >>participating beacons, and so that we can (off-line) look into what
> > >>is causing our connectivity problems; pointers or replies
> > >>appreciated.
> > >>Best regards,
> > >>- Håvard
