[AG-TECH] AG HW
Chris Geddings
cegeddin at colltech.com
Thu Jun 14 10:06:09 CDT 2001
That is correct, I replaced the 450's with PCI cards.
However, when I used 7.1 as my OS base, the 450 does work fine, so
when the AG software is moved to that base, the 450's will be
supported out of the box.
--Chris
"John A. Greenfield" wrote:
> On the other hand, the Matrox Millenium 450 video card does NOT work
> with the current linux iso. The 450 is not supported by the version of
> xfree86 in our install and hangs the install.
> On Thu, 14 Jun 2001, Robert Olson wrote:
> > I hear from Chris Geddins that he has M pro hardware, and it works great
> > for both the Win2k and Linux side.
> > --bob
> > At 10:33 PM 5/29/2001 +0200, Franca Fiumana wrote:
> > >Hello,
> > >For the setup of the AG Node we are considering an IBM based solution
> > >IBM IntelliStation M pro model k2T72xx (for the display, audio capture,
> > >video capture and control PC):
> > >Pentium III 1000 MHz dual processor
> > >512 MB RAM
> > >5(4) PCI full size
> > >Graphic card Matrox Millenium 450
> > >Has anyone experience with this kind of hardware for AG Node, are there
> > >known problems with the specific cards to be installed?
> > >- matrox G200 for the display pc
> > >- Hauppage Wintv 401 for the video capture PC
> > >- SB128 card for the audio capture PC
> > >Any comment and/or advice would be greatly appreciated.
> > >Regards,
> > > Franca
> > >Franca Fiumana e-mail: f.fiumana at cineca.it
> > >CINECA phone: +390516171588
> > >InterUniversity Computer Center fax: +390516132198
> > >Via Magnanelli, 6/3 I-40033 Casalecchio di Reno (Bologna) Italy
> John Greenfield
> green at ahpcc.unm.edu
> University of New Mexico
> THE ALBUQUERQUE HIGH PERFORMANCE COMPUTING CENTER
> Office # 505-277-8249
> Direct # 505-277-9545
> Fax # 505-277-8235
