[AG-TECH] New Gentner Software
Bob Olson
olson at mcs.anl.gov
Thu Jul 26 17:48:20 CDT 2001
That would be a great thing if someone wanted to do it. It's not hard,
just a fairly large amount of detail to cope with to get it useful &
right. There are other reasons for doing just htat, including enabling hte
creation of a unified control panel application.
--bob
On Thu, 26 Jul 2001, Jay Beavers wrote:
> Ya know, all the Gentner software is doing is sending a series of text
> commands through a serial port.
> With all the inconveniences we keep seeing with the software (OS
> incompatibility, CPU utilization, UI overload), I wonder if it might be
> useful to clearly articulate exactly what it is we need the software to
> do and then use a simple UI program developed in spec with the very well
> documented serial protocol to create an AG specific Gentner control
> program.
> - jcb
> -----Original Message-----
> From: Robert Olson [mailto:olson at mcs.anl.gov]
> Sent: Monday, July 23, 2001 9:28 AM
> To: Bill Nickless
> Cc: Mustafa Varank; ag-tech at mcs.anl.gov
> Subject: Re: [AG-TECH] New Gentner Software
> I also did a brief test of manually changing hte priority from the task
> mgr. Didn't seem to have an effect on the operation of the gentner
> software. Haven't tried with the ag video up.
> Still worry about function overload on the display machine console...
> --bob
> At 11:24 AM 7/23/2001 -0500, Bill Nickless wrote:
> >At 10:50 AM 7/23/2001 -0500, Robert Olson wrote:
> >>NOte that both Gware and APware will consume 100% cpu even in an idle
> >>state. We've not tested yet to see if this has a bad effect on other
> >>things happening on the display box, but it seems it can't be good.
> >>Current thinking is to perhaps move to Win2k on the control machine,
> so
> >>we can run other network services there as well.
> >The good news about Windows 2000 is that you can set the process
> >priority
> >of an application at start time. I've had very good success running
> >things like MP3 encoders at LOW (IDLE) priority and continuing to do
> other
> >things on the system.
> >This should work really well on a display machine with two
> >processors. Last I heard, vic wasn't multithreaded so could only
> saturate
> >one processor.
> >Here are the details on the start command:
> >C:\>start /?
> >Starts a separate window to run a specified program or command.
> >START ["title"] [/Dpath] [/I] [/MIN] [/MAX] [/SEPARATE | /SHARED]
> > [/LOW | /NORMAL | /HIGH | /REALTIME | /ABOVENORMAL |
> /BELOWNORMAL]
> > [/WAIT] [/B] [command/program]
> > [parameters]
> > "title" Title to display in window title bar.
> > path Starting directory
> > B Start application without creating a new window. The
> > application has ^C handling ignored. Unless the
> application
> > enables ^C processing, ^Break is the only way to
> interrupt
> > the application
> > I The new environment will be the original environment
> passed
> > to the cmd.exe and not the current environment.
> > MIN Start window minimized
> > MAX Start window maximized
> > SEPARATE Start 16-bit Windows program in separate memory space
> > SHARED Start 16-bit Windows program in shared memory space
> > LOW Start application in the IDLE priority class
> > NORMAL Start application in the NORMAL priority class
> > HIGH Start application in the HIGH priority class
> > REALTIME Start application in the REALTIME priority class
> > ABOVENORMAL Start application in the ABOVENORMAL priority class
> > BELOWNORMAL Start application in the BELOWNORMAL priority class
> > WAIT Start application and wait for it to terminate
> > command/program
> > If it is an internal cmd command or a batch file then
> > the command processor is run with the /K switch to
> cmd.exe.
> > This means that the window will remain after the
> command
> > has been run.
> > If it is not an internal cmd command or batch file
> then
> > it is a program and will run as either a windowed
> application
> > or a console application.
> > parameters These are the parameters passed to the command/program
> >If Command Extensions are enabled, external command invocation through
> >the command line or the START command changes as follows:
> >non-executable files may be invoked through their file association just
> > by typing the name of the file as a command. (e.g. WORD.DOC
> would
> > launch the application associated with the .DOC file extension).
> > See the ASSOC and FTYPE commands for how to create these
> > associations from within a command script.
> >When executing an application that is a 32-bit GUI application, CMD.EXE
> > does not wait for the application to terminate before returning to
> > the command prompt. This new behavior does NOT occur if executing
> >When executing a command line whose first token is the string "CMD "
> > without an extension or path qualifier, then "CMD" is replaced
> with
> > the value of the COMSPEC variable. This prevents picking up
> CMD.EXE
> > from the current directory.
> >When executing a command line whose first token does NOT contain an
> > extension, then CMD.EXE uses the value of the PATHEXT
> > environment variable to determine which extensions to look for
> > and in what order. The default value for the PATHEXT variable
> > is:
> > .COM;.EXE;.BAT;.CMD
> > Notice the syntax is the same as the PATH variable, with
> > semicolons separating the different elements.
> >When searching for an executable, if there is no match on any
> >extension, then looks to see if the name matches a directory name. If
> >it does, the START command launches the Explorer on that path. If done
> >from the command line, it is the equivalent to doing a CD /D to that
> >path.
> >Bill Nickless http://www.mcs.anl.gov/people/nickless +1 630 252
> 7390
> >PGP:0E 0F 16 80 C5 B1 69 52 E1 44 1A A5 0E 1B 74 F7
> nickless at mcs.anl.gov
