[AG-TECH] AG 1.0.1 - Missed Heartbeat
Satish K. Vanimisetti
satish at ccs.uky.edu
Thu Jul 12 18:14:44 CDT 2001
Thanks!
That fixed it.
-Satish
When we've had this problem the host file was not configured
correctly. You can edit the host file directly or run netcfg and edit host
info.
At 05:32 PM 7/12/2001 -0400, Satish K. Vanimisetti wrote:
>I am trying out the AG software from
>http://www-fp.mcs.anl.gov/fl/accessgrid/agpkgdownload.htm
>I have set the display machine on both audio and video
>to the correct machine. When I start 'arm-eventlistener'
>or 'vrm-eventlistener' I get the following error message:
>Got newstate true
>Look for cache
>Create watchdog app=ag.AudioResourceManager at 34128745
>Watchdog thread starts
>Missed heartbeat!
>Mssed a second heartbeat, trying reconnect
>disconnect sdp channel listener
>Got newstate false
>create listener
>Got event channel
>org.omg.CosEventChannelAdmin.StubForEventChannel:com.ooc.CORBA.Delegate at 52028745
>Got newstate true
>reconnect succeeded!
>I see a solid black dot against "Connected" but do not see the
>blinking blue dot against "Heartbeat".
>This happens on both video and audio.
>Anyone run into this?
>(If you did - how did you fix it?)
>Thanks,
>Satish
