[AG-TECH] Soundblaster Cards
John A. Greenfield
green at ahpcc.unm.edu
Tue Jul 10 16:40:58 CDT 2001
I have also found a couple of instances where the default install with oss
drivers did not work at all on SBLive boards on some Dell machines
(vic couldn't find the boards even though the drivers installed fine). I
haven't debugged the problem since it was MUCH simpler to swap in Ensoniq
AudioPCI cards which worked fine.
John
On Tue, 10 Jul 2001, Robert Olson wrote:
> At 02:13 PM 7/10/2001 -0700, Jonathan C. Humfrey wrote:
> >Is there any reason we should not go with an SB Live card instead of the
> >128r, in the event that we use the cpu for other sound apps?
> Yes. The SBLive has characteristics (large minimum fragment size) that make
> it less than suitable for low latency full duplex audio use. The Creative
> Ensoniq AudioPCI card works fine, and is easily available.
> http://www2.soundblaster.com/sound/ensoniq/
> http://www.cdw.com/shop/products/default.asp?EDC=115070
> --bob
John Greenfield
University of New Mexico
THE ALBUQUERQUE HIGH PERFORMANCE COMPUTING CENTER
Office # 505-277-8249
Direct # 505-277-9545
Fax # 505-277-8235
