[AG-TECH] Adjustments to AGN Specs
Don Morton
morton at cs.umt.edu
Wed Jan 10 08:55:16 CST 2001
1) Due to unexpected configuration of Display machine motherboard,
I'm running 3 projectors plus monitor off of the G200 Quad
card. As it turns out, the G200 won't cooperate with any
other video adaptor in the machine unless its a Matrox
(and the restriction is probably more specific than just that).
So, at this point everything runs off of the G200 Quad. Naturally,
it's working in the sense that I can display on all three
projectors plus monitor. However, I have concerns that it won't
handle the load of a real AGN session. Does anybody have
experience with this? I don't know if I want to leave things
the way they are, or if it would be prudent to get a new
motherboard with AGP slot, or some other solution. Money
doesn't flow freely here, but an AGN that can't process all
these graphics isn't desirable, of course :)
2) On the video capture machine, there are only two free PCI slots
for the WinTV cards. One slot is taken up by the NIC, yet
there is also an onboard 10/100 port. I understand that the
Intel PCI Pro/100+ NIC that's in there does some processing
of a level or two of the TCP/IP stack, so I'm wondering if
pulling that out and using the onboard 10/100 would critically
cut the network capabilities of that machine. Again, does anybody
have experience enough to provide advice?
We're still several weeks away from even getting our high-speed network
connected in to the AGN, so I can't test this myself. Which reminds
me, U. Montana has an opening for a Networking position (I don't know
exactly at what level) - if anybody's interested, I can find more
info for you. In general, low monetary rewards, high peace-of-mind
rewards :)
Don
Don Morton http://www.cs.umt.edu/u/morton/
Department of Computer Science The University of Montana
Missoula, MT 59812 | Voice (406) 243-4975 | Fax (406) 243-5139
