[AG-TECH] Urgetnt!!!
Allan Spale
aspale at evl.uic.edu
Wed Aug 1 17:45:26 CDT 2001
If this font.properties not found is what I think it is, it is not a
serious error. The fonts displayed for the Java applications will
probably just be some "fixed"-type font. As long as the application works
properly, I would not be concerned about this.
I am not an expert on drivers, although someone at EVL might be able to
help you because a separate project here is using that card or a similar
card for Linux (I think). E-mail Vikas, another node-op at EVL, at
vikas at evl.uic.edu to see if he could ask someone at EVL about this.
Hope this helps.
Allan
EVL/UIC
node-op
On Wed, 1 Aug 2001, Mustafa Varank wrote:
> Hello,
> I was trying to install the new Access Grid version 1. But I am getting
> the error message of:
> Font specified in font.properties not found. Do you guys know how can I
> solve this problem?
> Also I need drivers for NVidia Geforce 2 GTS for Linux 6.2. Did anyone has
> drivers for it ( kernel 2.2.16-3smp)
> Thank you,
> Mustafa
