[AG-TECH] Question about the beacon client.
Bob Olson
olson at mcs.anl.gov
Mon Apr 30 17:42:34 CDT 2001
I'd first check that hte beacon really died. How did you shut it down? if
you're using an AG linux box and used /etc/rc.d/init.d/nlanr-beacon stop,
there's a chance the beacon process itself is still running (do a ps and
look for the java process).
If it did die, perhaps there is a kernel timer that has to expire before
the group subscription is gone. I've not noticed the behavior you're
seeing, but I can't say I've looked for it.
--bob
On Mon, 30 Apr 2001, Chris Geddings wrote:
> So,
> I'm having a slew of multicast issues. At least I think they are
> multicast issues. I'm trying to use the beacon to help me diagnose
> some of these problems, or at least prove to the appropriate people
> that they exist. When I go to shut down the beacon, it stops okay,
> but leaves me in the multicast group until I reboot the machine. Is
> there a way to gracefully exit the nlanr-beacon that also tells the
> kernel to remove me from the multicast group?
> They way I know that it doesn't remove me from the multicast group,
> at least from the kernel perspective, is that before starting the
> beacon, I cat /proc/net/igmp. After starting the beacon, I note that
> an additional group has been added in that file. After stoping the
> beacon that group is not gone. On a reboot, the group is not in the
> file.
> I'm *guessing* that as the application exits, it never tells the kernel
> that it no longer needs the services of that group, and so the kernel
> keeps thinking it has an application needing to be a member of that
> group,
> so continues to listen to traffic for that group. Following, the router
> never finds out that the client machine that requested that group
> membership doesn't need to be a member any more, and so continues to
> remain a member of that group and so on.
> Feedback?
> --Chris
