[AG-TECH] Beacons: restart needed
Gary Orser
orser at cns.montana.edu
Wed Apr 11 10:05:43 CDT 2001
No, there are not two copies running.
I had manually started the one running, terminal was
blocked, and it printed that it received the kill signal
and terminated correctly.
If the beacon was started from /usr/local/ag/bin, that
script doesn't update the pid correctly, and the stop would
not work correctly.
Cheers, Gary
Gary Orser , (406) 994-6451, orser at nervana.montana.edu
Montana State University
Center for Computational Biology
1 Lewis Hall, Bozeman MT, 59717
On Wed, 11 Apr 2001, Robert Olson wrote:
> Make sure you don't have two beacons running now. That's the failure mode
> we've seen.
> --bob
> At 08:51 AM 4/11/2001 -0600, Gary Orser wrote:
> >Bob,
> >Hmm, restart just worked for me?
> >Cheers, Gary
> > > Hi -
> > > If you've looked at the beacon matrix page lately, you'll notice that all
> > > is not right there. Something's caused most beacons to stop sending
> > reports
> > > to the beacon server. Though we don't yet know the cause, we do know
> > that a
> > > restart of your beacon will be necessary for it to show up again on the
> > matrix.
> > > Please do so at your earliest convenience. If you're running a beacon
> > on an
> > > AG linux box, you can restart by either simply rebooting the machine
> > > running the beacon, or by running the following as root:
> > > kill `ps axuw | grep 'java Beacon' | grep -v grep | awk '{print $2}'`
> > > /etc/rc.d/init.d/nlanr-beacon start
> > > Note there's a bug in the init.d script such that a restart via the script
> > > does *not* work. (If someone wants to fix that... :-)
> > > thanks,
> > > --bob
