RTP
George Estes
gestes at ncsa.uiuc.edu
Wed Oct 25 13:26:39 CDT 2000
The informations is being written to the file .RTPdefaults. Just as a
little test I changed the email address in the rtp window and then did cat
.RTPdefaults and the new address was written to .RTPdefaults. But, when I
restart the Video Resource Manager the RTP window comes up again with the
old rtpemail address and the rtpname blank.
At 10:50 AM 10/25/00 -0500, Robert Olson wrote:
>Quit vic with the quit button once -- that will write the information out
>to the file.
>--bob
>At 10:39 AM 10/25/2000 -0500, George Estes wrote:
>>Thanks Allan,
>> The name and email info is being written to .RTPdefaults, but not being
>>read? when I change VV rooms.
>>George
>>At 09:52 AM 10/25/00 -0500, Allan Kenneth Spale wrote:
>> >George,
>> >In the slides for installing a new AG
>> >( http://www-fp.mcs.anl.gov/fl/accessgrid/ag-tutorial-sept00.htm ), there
>> >is a program that you run called setup-config. This will allow you to
>> >name the video windows and have their names stored when you change rooms.
>> >For specifics of how this program works, check out the Powerpoint slides
>> >We had the same problem at EVL/UIC until we ran that program.
>> >Best wishes,
>> >Allan Spale
>> >EVL/UIC node-op
>> >On Tue, 24 Oct 2000, George Estes wrote:
>> >> I have a situation where the rtpNAME is not read from .RTPdefaults, so
>> >> every time I change vv rooms I have to retype the rtp name before I can
>> >> send video. Any suggestions.
>> >> George
