JPEG VIC/Video Capture Card Problems
Allan Kenneth Spale
aspale1 at uic.edu
Tue Nov 14 13:43:49 CST 2000
EVL/UIC recently updated its audio machine with the software and hardware
needed to run the new jpeg capturidg vic. owever, the main problem is
that I cannot get any video.
I have checked the obvious (check the cable, put the cable in the video in
part of the video capture card). Everything seems to be as it should.
I did all of the known steps for updating the kernel and installing
additional software. I just do not know what I am doing wrong.
Also, one error message that tends to appear is the following:
ioctl BUZIOC_SYNC after loop: Timer expired
Sometimes around the time vic may crash (and this happens if I try to
push the program too much), I get this message repeatedly:
ioctl BUZIOC_SYNC_NONBLOCKING: Invalid argument
Does anyone have any suggestions?
Thanks.
Allan Spale
node-op
