Video Conf. Task Force (fwd)
Daniel Sandin dan at uic.edu
Wed Jan 12 10:55:44 CST 2000
Hi.
At The end of the month ( during SPIE) I will be having meetings with
engineers at Pinnacle to evaluate using the 3000 series PCI card as a multi
stream  encoder decoder to do mpeg, jpeg or DVcam-DVpro. The concept is to
hardware accelerate VIC.  Since there is software to be developed, the
earliest this solution could be applied is in the summer of 00 .
I am also interested in getting pointer to encoder-decoder boxes.
At 12:10 PM 1/11/00 -0600, Rick Stevens wrote:
>Do we have specs on these MPEG-2 systems ?
>---------- Forwarded message ----------
>Date: Tue, 11 Jan 2000 11:36:11 -0500
>From: "W. R. Wing" <wrw at cosmail1.ctd.ornl.gov>
>To: escc at es.net
>Cc: ESSC at es.net, wrw at ornl.gov
>Subject: Video Conf. Task Force
>I like to put out a call for interested volunteers who could
>contribute time (and potentially direct some local equipment dollars)
>to exploring the current generation of video conferencing gear.
>We are all aware (painfully aware) of the capabilities of H.320 based
>video conferencing solutions.  The limitations are real, substantial,
>and frequently impede the conduct of business.
>In the meanwhile, a new generation of gear from companies like
>Minerva and Polycom is arriving on the scene.  These boxes are able
>to generate very high quality video (MPEG-2 quality in the case of
>the Minerva) in real time, packetize this stream into IP (point to
>point or multicast) and potentially serve as a relief valve for some
>of the travel restrictions we all find ourselves dealing with.
>Some of these systems can chew up a lot of network bandwidth (up to 8
>Mbs in each direction) but in the context of ESnet3, this may be less
>of a problem than in the past.
>If you are interested, and particularly if your site is interested,
>please let me know.
>                         Bill
>William R. Wing    wrw at ornl.gov     423-574-8839
>Network Architect for the Oak Ridge National Lab
Daniel J. Sandin
Director, Electronic Visualization Laboratory (M/C 154)
The University of Illinois at Chicago
851 S. Morgan St. Rm 1120 SEO
Chicago IL 60607-7053
ph) 312-996-3002
fax) 312-413-7585
URL) http://www.evl.uic.edu
URL)http://www.evl.uic.edu/dan
dan at uic.edu
More information about the ag-tech mailing list
