Multicast Reachability Monitor
Robert Olson
olson at mcs.anl.gov
Tue Oct 26 08:58:33 CDT 1999
Aha. This looks like what we've been wanting. I don't see any
implementations, unfortunately.
--bob
http://www.ietf.org/internet-drafts/draft-ietf-mboned-mrm-00.txt
MBone Deployment Working Group Kevin Almeroth (ed)
Internet Engineering Task Force UCSB
Internet Draft Liming Wei
October 1999 Siara Systems, Inc.
Expires: April 1999 Dino Farinacci
Cisco
Multicast Reachability Monitor (MRM)
<draft-ietf-mboned-mrm-00.txt>
Status of this Memo
This document is an Internet-Draft and is in full conformance
with all provisions of Section 10 of RFC2026.
Internet-Drafts are working documents of the Internet Engineering
Task Force (IETF), its areas, and its working groups. Note that
other groups may also distribute working documents as
Internet-Drafts.
Internet-Drafts are draft documents valid for a maximum of six
months and may be updated, replaced, or obsoleted by other
documents at any time. It is inappropriate to use Internet-
Drafts as reference material or to cite them other than as
"work in progress."
The list of current Internet-Drafts can be accessed at
http://www.ietf.org/ietf/1id-abstracts.txt
The list of Internet-Draft Shadow Directories can be accessed at
http://www.ietf.org/shadow.html.
Abstract
MRM facilitates automated fault detection and fault isolation in a
large multicast routing infrastructure. It is designed to alarm a
network administrator of multicast reachability problems in close
to real-time.
There are two basic types of components in MRM, MRM manager and MRM
testers. This document specifies the protocol with which the two MRM
components communicate, the types of operations the testers perform,
and information an MRM manager can obtain.
Almeroth, Wei, Farinacci [Page 1]
Internet Draft <draft-ietf-mboned-mrm-01.txt> October 1999
Table of Contents
Abstract . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1
1. Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . 3
1.1 Partitioning Network Monitoring Tasks . . . . . . . . . . . . 3
2. Functions of the MRM Mechanism . . . . . . . . . . . . . . . . . . 4
2.1 Fault Detection . . . . . . . . . . . . . . . . . . . . . . . 4
2.2 Fault Isolation . . . . . . . . . . . . . . . . . . . . . . . 5
2.3 The Protocol . . . . . . . . . . . . . . . . . . . . . . . . . 5
2.3.1 MRM Manager Requests . . . . . . . . . . . . . . . . . . 6
2.3.1.1 MRM Manager Beacon Message . . . . . . . . . . . . . 7
2.3.1.2 Test Sender Requests (TSRs) . . . . . . . . . . . . 7
2.3.1.3 Test Receiver Requests (TRRs) . . . . . . . . . . . 8
2.3.2 Status Reports . . . . . . . . . . . . . . . . . . . . . 10
3. Use of MRM Well Known Addresses and Ports . . . . . . . . . . . . 11
4. Message Formats . . . . . . . . . . . . . . . . . . . . . . . . . 11
4.1 MRM Message Header . . . . . . . . . . . . . . . . . . . . . . 12
4.2 MRM Manager Beacon Message . . . . . . . . . . . . . . . . . . 13
4.3 Test Sender Request (TSR) . . . . . . . . . . . . . . . . . . 13
4.4 Test Receiver Requests (TRR) . . . . . . . . . . . . . . . . . 14
4.5 Status Report to the MRM Manager . . . . . . . . . . . . . . . 16
4.6 MRM Test Packet . . . . . . . . . . . . . . . . . . . . . . . 17
4.7 MRM Request-Ack Messages . . . . . . . . . . . . . . . . . . . 17
5. Authenticating MRM Messages . . . . . . . . . . . . . . . . . . . 17
5.1 Generating Authenticated Messages . . . . . . . . . . . . . . 18
5.2 Receiving Authenticated Messages . . . . . . . . . . . . . . . 18
5.3 Key Management . . . . . . . . . . . . . . . . . . . . . . . . 18
6. Security Considerations . . . . . . . . . . . . . . . . . . . . . 19
7. Different Approaches to Implement MRM . . . . . . . . . . . . . . 19
8. Example of an MRM Setup . . . . . . . . . . . . . . . . . . . . . 19
9. Acknowledgment . . . . . . . . . . . . . . . . . . . . . . . . . . 21
10. Authors addresses . . . . . . . . . . . . . . . . . . . . . . . . 21
11. References . . . . . . . . . . . . . . . . . . . . . . . . . . . 22
Appendix A - Change History . . . . . . . . . . . . . . . . . . . . . 22
Almeroth, Wei, Farinacci [Page 2]
1. Introduction
The Multicast Reachability Monitor (MRM) is a network fault detection
and isolation mechanism for administering a multicast routing
infrastructure. It is proposed in response to requests from network
managers and users who need more systematic ways to get up-to-date
multicast reachability status. For these purposes, existing tools are
inefficient and inconvenient to use across large numbers of systems.
The companion document [mrm-use] contains additional information on
justification and usage guidelines for MRM.
The design goals for MRM include:
(1) Close to real-time detection and alarm of network problems,
independent of user input;
(2) Good coverage over the network, both in terms of the number of
systems to be monitored, and the types of diagnostics to be
performed;
(3) Good extensibility and relative independence of other specific
diagnostic tools and protocols (we borrow packet formats from
RTPv2, but almost nothing else from the RTP protocol). This makes
it easy to incorporate newer diagnostic tools as they become
available.
Functionally, the task of monitoring a multicast domain can be
divided into two subtasks:
(1) Fault detection
(2) Fault isolation
In the fault detection phase, the participating MRM systems do not
need much detail about the nature of the fault. The mechanism can
be very simple and brute force. Data packets can be originated
from designated locations in the network and reception conditions
monitored from other locations.
In the fault isolation phase, depending on the types of fault
identified, the MRM manager can use proper tools to isolate the
fault and hopefully pin-point the location or reasons of the fault.
The rest of this document is organized as follows, Section 2
describes the MRM framework and details of the MRM protocol; Section
3 describes the usage of the well known MRM addresses and ports;
Section 4 specifies packet formats; Sections 5 discusses the MRM
authentication mechanisms; Section 6 discusses a few security issues;
and Section 8 gives an example of MRM setup.
Almeroth, Wei, Farinacci [Page 3]
An MRM based fault monitoring system consists of two types of
components: (1) an MRM manager that configures tests, collects and
presents fault information, and (2) MRM testers that source or sink
test traffic. These components collaborate to accomplish the two
functions of MRM: fault detection and fault isolation.
The MRM testers can be any routing devices or trusted end hosts.
They provide statistics about received data packets, to be used to
derive the network reachability status. These data packets can be
sourced by a router acting as an MRM tester, in response to a request
from the MRM manager. A system originating MRM data packets for
testing purposes is also called a Test Source (TS). A configured
set of MRM testers receiving the test traffic, and collecting
receiver statistics are also called Test Receivers (TRs).
An MRM manager initiates configuration requests to the MRM testers
and assigns the roles of TSs and TRs. The MRM manager informs the TSs
and TRs the types of monitoring or diagnostic tests to run. The MRM
manager also specifies the type of reports the TRs should send.
To guard against attacks on the MRM systems, IPsec Authentication
Header (AH) [AH] is used with HMAC-MD5 transformation as the standard
authentication algorithm. Authentication should always be enabled,
especially when MRM is used to monitor production services.
Note that this document only specifies the types of information an MRM
manager can obtain, and the protocol used to acquire such
information. How an MRM manager processes or presents the diagnostic
information is an implementation issue. An MRM manager can be as
simple as a command line wrapper of requests with simple display
functions, it can also be more sophisticated and incorporated as part
of a operational network monitoring tool in daily use by a network
operation center (NOC).
2.1 Fault Detection
Multicast routing can behave abnormally in different ways. The
following are a few common types of faults:
(1) Topological disconnectivity
The network topology for multicast routing is disconnected. For
example when a route for a subset of the networks are not in the
topology table.
Almeroth, Wei, Farinacci [Page 4]
(2) Black holes in forwarding path
No multicast packets can get through to certain receivers, even
though the network topology is perhaps intact. A possible cause
could be disabled multicast forwarding. Another possibility is
pruning errors,n e.g. due to inconsistent actions and timer
values on a multi-access LAN.
(3) Excessive/persistent Losses
Packets flow, but with excessive losses over extended period of
time. The possible causes include heavy congestion, line errors
or misuse of forwarding modes, etc.
(4) Excessive duplicates
Packets arrive at the receivers, but with large numbers of
duplicates.
(5) Others
Other types of fault that can be detected, e.g. non-pruners
as a failure mode. A non-pruning neighbor can be a sink for all
multicast traffic at all times, even if no receivers exist behind
that neighbor. This is "outlawed" by the "MBONE-community" [jhawk].
Detecting the existence of such system in an inter-domain scenario,
however, is not trivial. We leave this task to the next iteration
of MRM refinement.
2.2 Fault Isolation
Fault isolation is initiated by the MRM manager. For different types
of faults detected, various tools can be used to isolate the faults
to small areas in the network. Currently, the tools available for
this purpose includes but not limited to mtrace [MTRACE}, MIBs based
debugging tools based, http-based status report mechanism and remote
execution mechanisms.
When one tool is not sufficient, a combination of tools can be
applied. In general, MRM is designed to be flexible about the types
of tools it can utilize. Integrating the functionality of other
tools into MRM is an implementation issue for the MRM manager.
2.3 The Protocol
As stated above, the task of monitoring multicast reachability is
accomplished by letting an MRM manager configure the MRM testers to
perform fault detection and isolation tests. The MRM manager
summarizes or displays the collected reports for the network
operators, in an implementation specific way.
Almeroth, Wei, Farinacci [Page 5]
The MRM manager keeps a list of tester addresses. The relevant
routing devices are administratively configured as candidate MRM
testers. These testers will become active TSs and TRs once they
accept and process requests from an MRM manager.
We chose to use RTPv2 encapsulation for the following MRM messages:
fault report messages from TRs and optionally some test data packets.
This is to allow re-use of existing RTP based reception mechanisms.
Note that despite the use of the RTPv2 packet format, the design
goals and rules for the MRM message exchange protocol are entirely
different from those specified in RTP.
An MRM manager sends Test Sender requests to the TSs, and Test
Receiver requests to the TRs.
The MRM manager optionally transmits periodic beacon requests
to the well-known MRM multicast address MRM-ADDR (224.0.1.111)
that all TSs and TRs listen to. This beacon mechanism has three
purposes:
(1) For the TSs and TRs to learn the liveness of the MRM manager;
(2) As a medium to periodically refresh requests, in order for
testers to recover lost MRM messages, configurations or state
(e.g. across reboots).
(3) Inform a large group of test participants that an MRM session
has been changed or cancelled.
The use of beacon messages by the manager is optional primarily
because multicast connectivity between the manager and TSs and
TRs may not exist. As a result, while beacon messages may add
robustness, they should not be relied on to provide critical
functionality. While the manager chooses whether or not to
send beacon messages, TSs and TRs must be prepared to handle
these messages.
The MRM manager may send a request to either a unicast address,
or multicast address 224.0.1.111. When the message is sent via
unreliable unicast transport (UDP), the recipient must send a
positive acknowledgement after it has received that request.
Unacknowledged request messages are retransmitted.
Almeroth, Wei, Farinacci [Page 6]
The MRM manager periodically transmits beacon messages to advertise its
liveness to all MRM testers. This message is UDP-encapsulated. The
sender's timestamp can be used to calculate the jitters in delay
between subsequent beacon messages.
The recommended default Beacon message interval is 1 minute. The MRM
manager may piggyback the manager requests on the beacon messages.
This potentially reduces the need to individually check and repair
each tester's setup state, while still able to provide reliability
through a soft-state refresh mechanism.
A Test Sender request is first unicast delivered to a TS, then
refreshed through multicast delivery via the MRM beacon mechanism.
A Test Sender request specifies one of the following two ways to
generate test packets:
(1) Local packet trigger. This request includes the following
parameters:
(a) intervals between two consecutive test packets;
(b) format and length of test packets (e.g. RTP/UDP);
(c) multicast address for the test group.
If a TS accepts this local packet trigger, it will start sending
periodic test packets, at intervals specified in the MRM request
message. The IP address of the MRM manager will be used as the ID
for all test packets originated by the TS under this request. To
detect loops and packet losses, all test packets also contain a
monotonically increasing sequence number (if encapsulated in RTP,
this would be the RTP sequence number).
(2) Proxy packet trigger (see Section 5 for security impacts).
This request lets a TS send a (sequence of) MRM test packet(s),
using the IP source address provided by the manager request
message. This request contains all parameters a local packet
trigger has, plus a proxy-source address.
This request is useful for monitoring intra-domain multicast
connectivity for external sources. A proxy packet trigger can be
used to inject packets into the local domain, pretending there is
an active source external of the local domain. Inside the domain,
as far as forwarding is concerned, these packets are
indistinguishable from packets originated from a real external
source. For security reasons, proxy packet triggers should be
enabled very carefully.
Almeroth, Wei, Farinacci [Page 7]
TSR messages are also used to stop ongoing tests. By re-sending
the original TSR packet, but with a holdtime of zero, a test can
be stopped. NOTE: TRR messages with a holdtime of zero should
also be sent to each test receiver participating in the test.
An MRM status request is first addressed to a unicast address of a
TR, and subsequently should be carried in the MRM manager beacon
messages sent to 224.0.1.111.
Each such request carries a holdtime of the request, after which the
TR can safely discard any information collected. A TRR with a
holdtime of zero implies that an ongoing test should be terminated.
The TRR specifies how each TR should collect the reception data.
The following are the request types for the TRs:
(1) Monitor multicast group. This request has the following fields:
(a) J-bit. If set, the TR will join the specified group, as if it
were a host with a member of that group.
If a tester did an IGMP join at the beginning of a test, when
the MRM request expires, the IGMP group membership should be
withdrawn.
When a TR is instructed to join a data group of an existing
application (e.g. a heartbeat [heartbeat] group), it is wise
to assess the impact on the TR system if the data rate is
non-trivial.
Furthermore, the use of existing groups introduces uncertainty
as to whether the source is actually transmitting. Because
TRs expect a constant flow of packets, using existing group
traffic, which may be bursty, introduces uncertainty at the
receiver as to whether traffic is flowing but is being lost
or not being sent.
(b) The address of the group to be monitored;
(c) List of source addresses to record reception quality
information;
(d) Threshold description for triggering fault reports.
Almeroth, Wei, Farinacci [Page 8]
This draft revision only specifies packet loss based
threshold. A fault is detected if the packet loss percentage
has reached the threshold during the specified time window for
measurement. Once set, the width of this window is fixed. But
the starting point (or left edge) of the window keeps moving
forward.
Reception quality data within the measurement window should be
kept so that threshold calculations can be made continuously
as the window moves forward in time.
(e) Maximum and minimum delays to trigger fault report. The report
is sent at a randomized delay between the minimum and the
maximum value.
(f) Type of error reports solicited. It is possible to specify an
RTCP report (as if the test session uses RTP), or a native MRM
report. Currently, MRM only supports RTP-based reports.
(2) Fault isolation request. This request is sent after a fault is
detected and identified by the MRM manager. It specifies the tool
and its associated parameters.
Details about this request message will be added in a future
revision of the MRM specification.
(3) Poll for receiver statistics. This instructs the TR to report the
statistics (historic data) it has collected via Status Reports.
The TR will send Status Reports, even if the fault threshold has
not been reached. Section 2.3.2 describes the status report
mechanism in detail.
When large numbers of TRs are activated, a fault in the upstream of a
tree may result in many TRs sending reports at the same time. To
address the issue of possible report implosion, each TR may use one
of the following two strategies:
(1) Report via unicast message. The MRM manager assigns a pre-
determined report-delay (as part of the configuration design
task) to each TR. Each TR upon detecting a fault, will randomly
delay the sending of its report based on the pre-set delay
period. This would allow an MRM system to monitor networks with
up to thousands of systems without unreasonable compromises in
detection response times.
(2) Each TR may be instructed to report the detected faults to the
well-known MRM group address 224.0.1.111 using the RTCP format
[RFC1889] and does back-off or suppression when duplicate reports
from other Testers are seen. If using this strategy the manager
should realize that using multicast to report a problem with
multicast may not be particularly robust.
Almeroth, Wei, Farinacci [Page 9]
This method allows the use of existing RTP-based monitoring tools
in the initial deployment and experiments with MRM. However, it
will prevent the MRM manager from learning a complete list of
receivers affected by a specific fault. When multicast routing is
not working correctly, these reports may not be heard by the MRM
manager, leaving faults undetected and not alarmed by the MRM
manager. It is recommended that all designs include at least a
subset of TRs that (take turns to) unicast their reports.
There is ambiguity in MRM not hearing any fault report from a certain
TR. It could be due to fault-free network status, the crash of the
TR, or problems in the transport mechanism between the TR and the MRM
manager. Requiring each TR to frequently report its liveness and to
only do unicast fault report may work for a moderate number of
testers, but may put undue burden on the network for larger numbers
of testers. A compromising solution is to only report liveness from
a critical portion of the network and do unicast fault report from a
subset of the testers. The periodic liveness reports serve two
purposes: (1) it provides evidence that the tester is still alive;
(2) it indicates the conditions of the tester functions. The
request-ack messages are used as tester liveness reports.
Note that the fault isolation phase does not necessarily require the
MRM manager to send a Fault Isolation Request to a TR. E.g, in a
typical network today, a third party mtrace issued by the MRM manager
may be sufficient to identify the faulty hop excessively dropping
packets if the tester is not completely blacked out.
These reports are sent by the TRs to the MRM manager, in response to
a status request.
For now, we use RTP [RFC1889] "receiver report (RR)" packet format to
carry receiver's status reports. It is expected that the MRM-native
report format (to be defined in future draft revisions) will carry
more useful information about the routing state and statistics.
Please refer to RFC1889 for details on the packet formats. Here we
define the few RTCP items used by MRM (or loosely referred to as RTP
profile for MRM):
SSRC (Synchronization source) of packet sender:
IP address of the Test Sender.
Extended highest sequence number received:
Highest sequence number seen by the Test Receiver.
Fraction loss:
Percent loss of Test Sender data.
Almeroth, Wei, Farinacci [Page 10]
Cumulative number of packets lost:
Total number of RTP data packets from SSRC lost within this
reception window period.
Inter-arrival Jitter:
Set to zero when sent, ignored when received.
When this report is UDP encapsulated and unicast addressed to the MRM
manager, it is explicitly acknowledged. The acknowledgement packet
contains the RTCP header portion of the original packet after the MRM
header.
Once all TS and TR systems are configured, they join the well-known
MRM control group MRM-ADDR (224.0.1.111) and listen to the well-known
MRM UDP port MRM-MANAGER-PORT (679).
The MRM beacon messages are periodically sent to 224.0.1.111 UDP
port 679.
4. Message Formats
By default, MRM control messages are encapsulated inside UDP, and an
IP authentication header (AH) [KA98], is inserted in between the IP
header and the UDP header, as shown below:
| IP Header | AH | UDP header | MRM header | MRM payload |
The MRM status report in RTCP format is:
| IP Header | AH | UDP header | RTCP Rcvr Report | MRM header |
The MRM ACK packet format is:
| IP Header | AH | UDP header | MRM header | RTCP Header |
Almeroth, Wei, Farinacci [Page 11]
The inserted AH is reproduced below:
0 1 2 3 4 5 6 7 8 9 0 1 2 3 4 5 6 7 8 9 0 1 2 3 4 5 6 7 8 9 0 1
| Next Header | Payload Len | RESERVED |
| Security Parameters Index (SPI) |
| Sequence Number |
| Authentication Data (variable) |
As specified in [KA98], the following are the default values for the
fields above:
Next Header: 17, the value for UDP protocol.
Payload Len: 5, when MD5 is used (total length is 7 32-bit words).
RESERVED: 0 when sent, ignored when received.
SPI: 0 - 50, when using configured MD5 keys
Sequence Number: the sequence number
Authentication Data: message digest
The MRM message header contains 4 32-bit words.
|Version| Type | Code | Holdtime |
| Target IP address |
|M| Reserved | MRM message length |
| Timestamp (in milliseconds) |
Version: 4 bits
This revision defines version 1 of MRM.
Almeroth, Wei, Farinacci [Page 12]
Type: 4 bits
The defined message types are:
0 = Beacon (from MRM manager to all testers)
1 = TS Request (from MRM manager to Test Senders)
2 = TR Request (from MRM manager to Test Receivers)
3 = Status Response (from TR to the MRM manager)
4 = TS Request Ack (from TS to MRM manager)
5 = TR request Ack (from TR to MRM manager)
6 = Status Response Ack (from MRM manager to TR)
Code: 8 bits
Defined according to each packet type.
Holdtime: 16 bits
Maximum duration in seconds this message should be honored.
Target IP address: 32 bits
The unicast address of the intended recipient of this message.
M: 1 bit,
0: last MRM request message in this packet.
1: more MRM request messages follow in the same packet.
When multiple MRM messages are grouped into one packet, the IP/AH/UDP
headers of the second and all subsequent MRM messages are omitted. The
total length of the IP packet will reflect the the sum of lengths of
all MRM messages in the packet.
This message is UDP encapsulated, addressed to UDP port MRM-MANAGER-
PORT. The outstanding Test Sender Requests and Test Receiver
Requests are included in the beacon message. The individual MRM
headers are included with these TSR/TRRs.
There are two code values for a TSR:
0: Local packet trigger
1: Proxy packet trigger
NOTE: A host-based implementation is not expected to provide
proxy packet capability.
Following the MRM message header are the fields for the source
specification request:
Almeroth, Wei, Farinacci [Page 13]
| UDP port of test packets |R| S | LEN | Reserved |
| Test group address |
| Inter-packet delay (millisecond) |
| Proxy source IP address (for proxy packet trigger) |
UDP port of test packets: 16 bits
UDP port of test packets.
R: 1 bit
0: Tester will originate RTP/UDP encapsulated test packets
1: Tester will originate another kind of packet (not used)
S: 2 bits
00: send on the targeted interface only
01: send on all the multicast enabled interfaces
10: send on test-send enabled interfaces
11: Unused
LEN: 3 bits (optional)
Size of the packets to be sourced. The length field represents
a multiple of 16 bytes. The range of possible packet sizes is
16 bytes to 2048 bytes (2^7)*(16 bytes). The LEN field is
optional. If ignored, test senders should send 16 byte packets.
Reserved: 10 bits
Set to zero when sent. Ignored with received.
Inter-packet delay: 32 bits
Number of milliseconds between consecutive test packets.
Test group address: 32 bits
Multicast address of the test group.
Proxy source IP address: 32 bits
IP address of the source to proxy packet for. This field
exists only for a proxy packet trigger request.
The following are code values for status request messages:
0: Monitor multicast group (Monitor request)
1: Poll for receiver statistics (Poll request)
2: Fault isolation request (not used in this revision)
Almeroth, Wei, Farinacci [Page 14]
Message format for monitor and poll requests:
|J|R| Reserved | Number of sources to monitor |
|Thres index (0)| Pkt loss (%) | Reception window (seconds) |
| Min report delay (seconds) | Max report delay (seconds) |
| Max startup delay (seconds) | Reserved |
| UDP port of test packets | UDP port for status reports |
/ Threshold description block /
| IP address of Source 1 |
| Inter-Packet delay interval from source 1 |
| IP address of Source n |
| Inter-Packet delay from source n |
J: 1 bit
0: Don't join the multicast group to be monitored.
1: Join the multicast group to be monitored.
R: 1 bit
0: Fault report should be sent in RTCP format
1: Fault report should be sent in native MRM format (not used).
Reserved:
Zeroed when sent, ignored when received.
Number of sources to monitor: 16 bit
The number of sources this target tester should monitor. When
all sources for the test group are monitored, this field is
set to 1, and the corresponding source address field is set
to 0.0.0.0.
Thres index: 8 bits
Always 0. Index of the criteria for determining a threshold
for a fault. The value of this index determines the content
for the "Threshold description Block".
Almeroth, Wei, Farinacci [Page 15]
Pkt loss (%): 8 bits
Percentage of packet loss. A criteria to determine whether a
fault has occurred.
Max report delay (seconds): 16 bits
Maximum number of seconds within which a fault report must be
sent after it is detected.
Min report delay (seconds): 16 bits
Minimum number of seconds a fault report needs to be sent after
it is detected. A report should not be sent in less than this
delay.
Max startup delay (seconds): 16 bits
Max number of seconds the TR can wait before the start of the
test. The test is considered started if a test packet is
received, or the "max startup delay" has passed after the
receipt of this request.
Reception window (seconds): 16 bits
Number of seconds used for calculating packet loss percentage.
UDP port of data packets: 16 bits
UDP port test data packets use.
UDP port of status report packets: 16 bits
UDP port of status report packets.
Threshold description block: 0 bit
Variable length, depending on "Thres index". This revision only
defines threshold index 0, with no threshold description block.
The IP multicast address for the test group.
IP address of source 1 .. n: 32 bits
The IP address of the sources the targeted tester should monitor.
When the address is 0.0.0.0, all sources to this group will be
monitored.
Inter-packet delay from source 1 .. n: 32 bits
Intervals between consecutive packets from the source
(milliseconds).
This MRM revision uses the reception report (RTCP) format based on
Section 2.3.2. Future revisions will define MRM specific report
formats.
Almeroth, Wei, Farinacci [Page 16]
4.6 MRM Test Packet
MRM test packets are RTPv2/UDP encapsulated. The RTPv2 packet header
is replicated below for easy of description.
|V=2|P|X| CC |M| PT | sequence number |
| timestamp |
| synchronization source (SSRC) identifier |
| IP address of MRM manager |
CC:
Set to 0 when sent, ignored when received.
M:
PT:
Sequence number:
Sequence number. Set to 0, when a tester is activated.
Timestamp:
System timestamp, in milliseconds.
SSRC:
IP address of the tester, or a configured 32-bit number that
uniquely identifies the tester.
The Acknowledgement messages for the Test Sender Request and the
Status Request provide guarantees that the requests are indeed
received by the testers, instead of being lost. The acknowledgement
packets contain the MRM header and trailer for the respective
messages, except that the message length and authentication data
fields are recalculated.
All MRM messages should be authenticated with the MD5 mechanism
specified here. The fields in the messages are transmitted in the
clear. Packets that fail the authentication check are discarded by
the receivers.
Almeroth, Wei, Farinacci [Page 17]
The sender of the MRM message decides which authentication key
is used.
(1) The MRM message length field is filled with the number of
bytes in the message;
(2) The rest of the message is composed;
(3) The IPSEC AH is constructed;
(4) The "authentication data" field is zeroed;
(5) The MRM authentication Key (16 byte long) is appended
to the MRM message.
(6) The pad for the key is added. The digest is calculated and
written into the "authentication data" field.
The part with the MD5 secret is not transmitted.
The receiver follows the following steps when processing an incoming
message:
(1) The digest is stored away and the "authentication data"
field zeroed;
(2) It finds the key according to the value of "Key ID", and
the key is appended and the packet properly padded;
(3) A new digest is calculated.
A message is discarded if the new digest is different from the one
carried in the packet.
5.3 Key Management
We expect to rely on manual key distribution in the initial stages.
And MRM should be able to utilize the standard secure key management
mechanism when it becomes available.
Almeroth, Wei, Farinacci [Page 18]
The strength of the security mechanism here depends on the strength
of the key and the MD5 algorithm.
Insufficiently protected TSs and TRs (e.g. by weak keys) can be
subject to attacks that can cause the TSs and TRs to take actions
causing harm to the network.
MRM is originally targeted at two types of users: network operation
centers that provide production quality services; and network
administrators who oversee semi-production or experimental multicast
services. The former often rely on SNMP-based tools for management
tasks and typically desire all types of monitoring functionalities to
be wrapped into the same set of tools. While the later, who usually
set the stage for production quality offerings, do not normally rely
on SNMP-based tools and favor task-oriented tools.
For this reason, this document specifies the native MRM messages and
operations. A companion document will define the MRM MIB that can
accomplish the majority of the native MRM tasks.
The example shown in this section is for illustration purpose only,
and does not cover all possible functionalities of the MRM framework.
Neighbor. T1 T2 . Neighbor
Domain . +----+ +----+ +-----+ . Domain
----| BR1|-----------| R2 |-----------| BR3 |--------
| R4 | | R5 |
. T3 /
--------| R6 |-----------/
| MRM Manager |
Almeroth, Wei, Farinacci [Page 19]
The above is a simple topology used to demonstrate the use of various
MRM features. Border routers BR1, BR3 and an internal router R6 are
administratively configured as candidate MRM Testers. The MRM manager
configures T1 to be a TS, and T2,T3 to be TRs. The following are the
messages sent by the MRM components.
(1) MRM manager sends Test Sender request (TSR) to T1.
Req1 = {Local packet trigger,
test packet interval = 60,000 (ms),
RTP/UDP test packet = TRUE,
Test group = 239.255.255.2}
T1 acknowledges receipt of Req1.
(2) MRM manager sends TR request Req2 to T2. Req2 has the following
content:
J-bit = TRUE,
list of source addresses = {T1's IP address},
threshold for fault detection = {20% loss over 10 minutes},
max delay for fault report = 10 seconds,
min delay for fault report = 0 seconds,
Test group = 239.255.255.2,
T2 acknowledges receipt of Req2. Req2 is retransmitted if the
retransmission timer expires.
(3) MRM manager sends TR request Req3 to T3. Similar to Req2,
except the target is T3, and,
max delay for fault report = 20 seconds,
min delay for fault report = 10 seconds
By using different (min, max) report times, it can avoid report
implosion at the MRM manager, when a fault is detected by T2 and T3
at the same time.
(4) MRM manager periodically sends beacon messages, carrying Req1 and
Req2, Req3. The holdtime is set to the remaining lifetime of the
original request.
Assume T1 has a fault such that it can only forward 1% of all
multicast packets, the fault is detected by T2 and T3. T2 randomly
delays between 0-10 seconds, and sends a fault report to the MRM
manager. The MRM manager acknowledges this report. T3 randomly
delays between 10-20 seconds, and sends its fault report to the MRM
manager, which is also acknowledged. This concludes the fault
detection phase.
Almeroth, Wei, Farinacci [Page 20]
In the fault isolation phase, assume the MRM manager sends a third
party mtrace request to T2 or T3, and isolates the fault to between
T1, R2 and T1, R4. The MRM manager can then issue an an alarm to the
network operator, with proper descriptions of the problem.
The operation for fault isolation phase might be more complicated for
other types of fault, e.g. if T1 has lost the ability to forward
multicast packets completely, T2 and T3 wouldn't have any multicast
routing state or statistics for mtrace to work, some other mechanisms
would have to be put in use.
9. Acknowledgment
We'd like to thank John Meylor, Beau Williamson, Stephen Deering,
Ishan Wu, Louis Mamakos, Manoj Leelanivas, David Meyer, Bill Fenner
and Dave Thaler for their comments and suggestions. We'd like to
especially TY Lin and Kamil Sarac for filling in missing details from
the previous version of the specification.
Kevin Almeroth
Department of Computer Science
University of California
Santa Barbara, CA 93106-5110
almeroth at cs.ucsb.edu
Liming Wei
Siara Systems, Inc.
300 Ferguson Drive
Mountain View, California 94043
lwei at siara.com
Dino Farinacci
cisco Systems, Inc.
170 West Tasman Drive
San Jose, CA 95134
dino at cisco.com
Almeroth, Wei, Farinacci [Page 21]
11. References
[mtrace] Steven Casner, Bill Fenner et al. The mtrace tool.
[mrm-use] Kevin Almeroth, Liming Wei, "Justification and Use of MRM",
draft, Jan 15, 1999.
[aboba] Bernard Aboba, "The Use of SNTP as a Multicast Heartbeat",
Draft, draft-ietf-mboned-sntp-heart-02.txt.
[ping] Jon Postel, "Internet Control Message Protocol", RFC792,
Information Sciences Institute, 1981.
[UDP] Jon Postel, "User Datagram Protocol", RFC768. Information
Sciences Institute.
[scope] Dave Meyer, "Administratively Scoped IP Multicast",
Draft, draft-ietf-mboned-admin-ip-space-03.txt.
[MD5] R. Rivest, "The MD5 Message-Digest Algorithm", RFC1321,
April, 1992
[KA98] Kent Stephen, Randall Atkinson, "IP Authentication Header",
"draft-ietf-ipsec-auth-header-07.txt", July 1998
October 1999 -- revisions since draft-ietf-mboned-mrm-00.txt
(1) Added a TS length field to allow test send packets to be
specified between 16 bytes and 2048 bytes in 16 byte
increments.
(2) Made usage of beacon messages by the manager optional.
Test agents are required to be able to process beacon
messages.
(3) Monitoring existing groups is relegated to a later version
because of the difficulty in monitoring the source to
determine if it is sending a packet. When an MRM Test
Source is used, Test Receivers know when, how many, and
for how long packets will be sent. If no packets are
received the test receiver knows to report 100% loss.
This assumption is not possible when monitoring existing
groups.
(4) Added additional detail about packet formats and packet
handling procedures to reduce ambiguity.
Almeroth, Wei, Farinacci [Page 22]
