[AG-DEV] ANL Bridge registry turned off ?
Christoph Willing
c.willing at uq.edu.au
Mon Jun 11 20:41:25 CDT 2012
On 12/06/2012, at 11:20 AM, Jason Bell wrote:
> G'day all
> With the recent DNS moves - do we need to restart our unicast
> bridges???
Shouldn't need to. However if you're asking because you're not seeing
bridges now after a purge, its because the registry itself isn't
running for some reason. I'm looking at it now - actually,
immediately after an appointment I have right now ...
chris
> -----Original Message-----
> From: ag-dev-bounces at lists.mcs.anl.gov [mailto:ag-dev-bounces at lists.mcs.anl.gov
> ] On Behalf Of David Allingham
> Sent: Thursday, 7 June 2012 02:44 PM
> To: Graeme Glen; Christoph Willing
> Cc: ag-dev
> Subject: Re: [AG-DEV] ANL Bridge registry turned off ?
> Not sure if it'll help with testing, but I've just found out that
> there's a www.accessgrid.com, which still points to the old ANL
> server (and returns the original peers.txt with its "vv3.mcs.anl.gov:
> 8030" entry.
> Note that this will soon be redirected to the new site where www.accessgrid.org
> lives.
> David
>>>> Christoph Willing <c.willing at uq.edu.au> 7/06/2012 11:25 am >>>
> On 07/06/2012, at 11:17 AM, Graeme Glen wrote:
>> Hi All,
>> Restarted the Auckland Bridge (because lots of errors, couldn't
>> connect to the URL any more, unhealthy CPU usage around 60%).
>> After restart no errors, you will hopefully see it in the new
>> registry.
> Thanks Graeme,
> I see the Auckland bridge again now.
> In fact, after a "Find Additional Bridges", I now see a number of
> the "old" bridges again. I guess they have also been restarted. The
> list of bridges is now looking much more like it used to.
> chris
>>> From: Christoph Willing [mailto:c.willing at uq.edu.au]
>>> Sent: Thursday, 7 June 2012 12:52 p.m.
>>> To: Lloyd Pearson
>>> Cc: ag-dev; Graeme Glen
>>> On 07/06/2012, at 10:20 AM, Lloyd Pearson wrote:
>>>> Thanks Chris,
>>>> Currently using only http://www.ap-accessgrid.org/registry/
>>>> peers.txt
>>>> I get only the APAG bridge.
>>>> Deleting that http://www.ap-accessgrid.org/registry/peers.txt and
>>>> using only http://www.accessgrid.org/registry/peers.txt I get 7
>>>> bridges but not APAG.
>>>> UQ-RCC
>>>> ARCS-Melbourne
>>>> Westgrid
>>>> LSU
>>>> UPSAG
>>>> And 2 x NDHU bridges which are disabled.
>>>> Using both entries I get APAG as well to give a total of 8 bridges.
>>> Great - all the above is consistent with how I think it should work.
>>>> (Graeme Glen looks after the Auckland bridge, so I'm sure he'll see
>>>> this discussion and hopefully restart.
>>> I'm cc'ing Graeme too ...
>>> chris
>>>> - There are a few uni's in NZ that are running unicast so they'll
>>>> probably raise a question soon.)
>>>> Regards,
>>>> Lloyd Pearson
>>>> AVC Operator
>>>> University of Otago
>>>> Ph +64 3 479 8997
>>>> lloyd.pearson at otago.ac.nz
>>>> Sent: Thursday, 7 June 2012 11:18 a.m.
>>>> To: Lloyd Pearson
>>>> Cc: ag-dev
>>>> On 07/06/2012, at 8:02 AM, Lloyd Pearson wrote:
>>>>> Hello team,
>>>>> Currently I get 7 bridges after a purge with only
>>>>> as a bridge registry.
>>>>> APAG
>>>>> UQ-RCC
>>>>> ARCS-Melbourne
>>>>> Westgrid
>>>>> LSU
>>>>> Using only http://www.ap-accessgrid.org/registry/peers.txt the
>>>>> result is the same.
>>>> Lloyd,
>>>> I think there's some sort of timeout or ageing mechanism such that
>>>> if you did a purge before removing www.accessgrid.org/... and then
>>>> another purge, the list of bridges will remain the same as
>>>> before. I
>>>> think if you were to wait 5 (or 10, or 15, whatever ....), another
>>>> purge would produce fewer bridges. Also, I think you'll need to
>>>> Save
>>>> after deletions to the peers.txt entries.
>>>>> Another PC which has not been purged for several weeks currently
>>>>> lists about 26 bridges.
>>>> Yes we've found that too. As soon as you do a purge on that
>>>> machine,
>>>> it will look through the bridge registries for bridges to test and
>>>> add to the list of bridges - also removing bridges not registered
>>>> with whatever registries you have enabled (bearing in mind the
>>>> ageing mechanism for remembering them).
>>>>> The Auckland bridge doesn't show on the recently purged PC, even
>>>>> though it appears on the unpurged PC and it does appear to be
>>>>> useable when selected. (That PC normally runs multicast.)
>>>> Most of the previous bridges are still running and will work if
>>>> their existence is still recognised e.g. by unpurged
>>>> VenueCLients. I
>>>> think they probably need to be restarted so that they're registered
>>>> with the new registry. Do you know who runs that bridge to ask them
>>>> to restart it?
>>>> chris
>>>>> ] On Behalf Of Christoph Willing
>>>>> Sent: Thursday, 7 June 2012 9:25 a.m.
>>>>> To: Todd Zimmerman
>>>>> Cc: ag-dev
>>>>> On 07/06/2012, at 12:33 AM, Todd Zimmerman wrote:
>>>>>> On 06/06/2012 03:52 AM, Christoph Willing wrote:
>>>>>>> Until the DNS is transferred and we can create an entry for
>>>>>>> vv3.accessgrid.org, I wonder if a plain IP address would work
>>>>>>> there instead? Todd, could we try this by you changing the
>>>>>>> peers.txt file to be:
>>>>>>> 130.102.78.188:8030
>>>>>>> please?
>>>>>> Done
>>>>> Thanks. It seems to have worked; I see a lot more bridges now -
>>>>> although not yet as many as in the old days ...
>>>>> chris
>>>>> Christoph Willing +61 7 3365 8316
>>>>> Research Computing Centre
>>>>> University of Queensland
