[AG-DEV] ANL Bridge registry turned off ?
Christoph Willing
c.willing at uq.edu.au
Wed Jun 6 20:25:59 CDT 2012
On 07/06/2012, at 11:17 AM, Graeme Glen wrote:
> Hi All,
> Restarted the Auckland Bridge (because lots of errors, couldn't
> connect to the URL any more, unhealthy CPU usage around 60%).
> After restart no errors, you will hopefully see it in the new
> registry.
Thanks Graeme,
I see the Auckland bridge again now.
In fact, after a "Find Additional Bridges", I now see a number of the
"old" bridges again. I guess they have also been restarted. The list
of bridges is now looking much more like it used to.
chris
>> -----Original Message-----
>> From: Christoph Willing [mailto:c.willing at uq.edu.au]
>> Sent: Thursday, 7 June 2012 12:52 p.m.
>> To: Lloyd Pearson
>> Cc: ag-dev; Graeme Glen
>> Subject: Re: [AG-DEV] ANL Bridge registry turned off ?
>> On 07/06/2012, at 10:20 AM, Lloyd Pearson wrote:
>>> Thanks Chris,
>>> Currently using only http://www.ap-accessgrid.org/registry/peers.txt
>>> I get only the APAG bridge.
>>> Deleting that http://www.ap-accessgrid.org/registry/peers.txt and
>>> using only http://www.accessgrid.org/registry/peers.txt I get 7
>>> bridges but not APAG.
>>> UQ-RCC
>>> ARCS-Melbourne
>>> Westgrid
>>> LSU
>>> UPSAG
>>> And 2 x NDHU bridges which are disabled.
>>> Using both entries I get APAG as well to give a total of 8 bridges.
>> Great - all the above is consistent with how I think it should work.
>>> (Graeme Glen looks after the Auckland bridge, so I'm sure he'll see
>>> this discussion and hopefully restart.
>> I'm cc'ing Graeme too ...
>> chris
>>> - There are a few uni's in NZ that are running unicast so they'll
>>> probably raise a question soon.)
>>> Regards,
>>> Lloyd Pearson
>>> AVC Operator
>>> University of Otago
>>> Ph +64 3 479 8997
>>> lloyd.pearson at otago.ac.nz
>>> Sent: Thursday, 7 June 2012 11:18 a.m.
>>> To: Lloyd Pearson
>>> Cc: ag-dev
>>> On 07/06/2012, at 8:02 AM, Lloyd Pearson wrote:
>>>> Hello team,
>>>> Currently I get 7 bridges after a purge with only
>>>> as a bridge registry.
>>>> APAG
>>>> UQ-RCC
>>>> ARCS-Melbourne
>>>> Westgrid
>>>> LSU
>>>> Using only http://www.ap-accessgrid.org/registry/peers.txt the
>>>> result
>>>> is the same.
>>> Lloyd,
>>> I think there's some sort of timeout or ageing mechanism such that
>>> if
>>> you did a purge before removing www.accessgrid.org/... and then
>>> another purge, the list of bridges will remain the same as before. I
>>> think if you were to wait 5 (or 10, or 15, whatever ....), another
>>> purge would produce fewer bridges. Also, I think you'll need to Save
>>> after deletions to the peers.txt entries.
>>>> Another PC which has not been purged for several weeks currently
>>>> lists about 26 bridges.
>>> Yes we've found that too. As soon as you do a purge on that machine,
>>> it will look through the bridge registries for bridges to test and
>>> add
>>> to the list of bridges - also removing bridges not registered with
>>> whatever registries you have enabled (bearing in mind the ageing
>>> mechanism for remembering them).
>>>> The Auckland bridge doesn't show on the recently purged PC, even
>>>> though it appears on the unpurged PC and it does appear to be
>>>> useable
>>>> when selected. (That PC normally runs multicast.)
>>> Most of the previous bridges are still running and will work if
>>> their
>>> existence is still recognised e.g. by unpurged VenueCLients. I think
>>> they probably need to be restarted so that they're registered with
>>> the
>>> new registry. Do you know who runs that bridge to ask them to
>>> restart
>>> it?
>>> chris
>>>> From: ag-dev-bounces at lists.mcs.anl.gov
>>>> [mailto:ag-dev-bounces at lists.mcs.anl.gov
>>>> ] On Behalf Of Christoph Willing
>>>> Sent: Thursday, 7 June 2012 9:25 a.m.
>>>> To: Todd Zimmerman
>>>> Cc: ag-dev
>>>> On 07/06/2012, at 12:33 AM, Todd Zimmerman wrote:
>>>>> On 06/06/2012 03:52 AM, Christoph Willing wrote:
>>>>>> Until the DNS is transferred and we can create an entry for
>>>>>> vv3.accessgrid.org, I wonder if a plain IP address would work
>>>>>> there
>>>>>> instead? Todd, could we try this by you changing the peers.txt
>>>>>> file
>>>>>> to be:
>>>>>> 130.102.78.188:8030
>>>>>> please?
>>>>> Done
>>>> Thanks. It seems to have worked; I see a lot more bridges now -
>>>> although not yet as many as in the old days ...
>>>> chris
>>>> Christoph Willing +61 7 3365 8316
>>>> Research Computing Centre
>>>> University of Queensland
