[AG-DEV] ANL Bridge registry turned off ?
Christoph Willing
c.willing at uq.edu.au
Wed Jun 6 19:14:31 CDT 2012
On 07/06/2012, at 9:52 AM, Jason Bell wrote:
> G'day all
> Simple question - but in regards to running my unicast bridge (which
> is down while we solve local multicast issues), do I need to point
> it to a different registry and if so - what should I use?
I'm pretty sure that using the http://www.accessgrid.org/registry/peers.txt
as the registryUrl will work if you start a bridge now, since the
DNS pointer for www.accessgrid.org has been changed to the new site
and the new site's registry/peers.txt contains the correct address of
the registry itself.
Long running bridges started with the same registryUrl but before the
DNS redirection are registered with the old registry and therefore
don't appear after a purge in the VenueClient. Restarting those
bridges should make them visible again after VenueCLient purges.
chris
> -----Original Message-----
> From: ag-dev-bounces at lists.mcs.anl.gov [mailto:ag-dev-bounces at lists.mcs.anl.gov
> ] On Behalf Of Christoph Willing
> Sent: Thursday, 7 June 2012 09:18 AM
> To: Lloyd Pearson
> Cc: ag-dev
> Subject: Re: [AG-DEV] ANL Bridge registry turned off ?
> On 07/06/2012, at 8:02 AM, Lloyd Pearson wrote:
>> Hello team,
>> Currently I get 7 bridges after a purge with only
>> as a bridge registry.
>> APAG
>> UQ-RCC
>> ARCS-Melbourne
>> Westgrid
>> LSU
>> And 2 x NDHU bridges which are disabled.
>> Using only http://www.ap-accessgrid.org/registry/peers.txt the result
>> is the same.
> Lloyd,
> I think there's some sort of timeout or ageing mechanism such that
> if you did a purge before removing www.accessgrid.org/... and then
> another purge, the list of bridges will remain the same as before. I
> think if you were to wait 5 (or 10, or 15, whatever ....), another
> purge would produce fewer bridges. Also, I think you'll need to Save
> after deletions to the peers.txt entries.
>> Another PC which has not been purged for several weeks currently
>> lists
>> about 26 bridges.
> Yes we've found that too. As soon as you do a purge on that machine,
> it will look through the bridge registries for bridges to test and
> add to the list of bridges - also removing bridges not registered
> with whatever registries you have enabled (bearing in mind the
> ageing mechanism for remembering them).
>> The Auckland bridge doesn't show on the recently purged PC, even
>> though it appears on the unpurged PC and it does appear to be useable
>> when selected. (That PC normally runs multicast.)
> Most of the previous bridges are still running and will work if
> their existence is still recognised e.g. by unpurged VenueCLients. I
> think they probably need to be restarted so that they're registered
> with the new registry. Do you know who runs that bridge to ask them
> to restart it?
> chris
>> Sent: Thursday, 7 June 2012 9:25 a.m.
>> To: Todd Zimmerman
>> Cc: ag-dev
>> On 07/06/2012, at 12:33 AM, Todd Zimmerman wrote:
>>> On 06/06/2012 03:52 AM, Christoph Willing wrote:
>>>> Until the DNS is transferred and we can create an entry for
>>>> vv3.accessgrid.org, I wonder if a plain IP address would work there
>>>> instead? Todd, could we try this by you changing the peers.txt file
>>>> to be:
>>>> 130.102.78.188:8030
>>>> please?
>>> Done
>> Thanks. It seems to have worked; I see a lot more bridges now -
>> although not yet as many as in the old days ...
>> chris
>> Christoph Willing +61 7 3365 8316
>> Research Computing Centre
>> University of Queensland
