[AG-DEV] ANL Bridge registry turned off ?
Christoph Willing
c.willing at uq.edu.au
Wed Jun 6 18:17:53 CDT 2012
On 07/06/2012, at 8:02 AM, Lloyd Pearson wrote:
> Hello team,
> Currently I get 7 bridges after a purge with only http://www.accessgrid.org/registry/peers.txt
> as a bridge registry.
> APAG
> UQ-RCC
> ARCS-Melbourne
> Westgrid
> LSU
> And 2 x NDHU bridges which are disabled.
> Using only http://www.ap-accessgrid.org/registry/peers.txt the
> result is the same.
Lloyd,
I think there's some sort of timeout or ageing mechanism such that if
you did a purge before removing www.accessgrid.org/... and then
another purge, the list of bridges will remain the same as before. I
think if you were to wait 5 (or 10, or 15, whatever ....), another
purge would produce fewer bridges. Also, I think you'll need to Save
after deletions to the peers.txt entries.
> Another PC which has not been purged for several weeks currently
> lists about 26 bridges.
Yes we've found that too. As soon as you do a purge on that machine,
it will look through the bridge registries for bridges to test and add
to the list of bridges - also removing bridges not registered with
whatever registries you have enabled (bearing in mind the ageing
mechanism for remembering them).
> The Auckland bridge doesn't show on the recently purged PC, even
> though it appears on the unpurged PC and it does appear to be
> useable when selected. (That PC normally runs multicast.)
Most of the previous bridges are still running and will work if their
existence is still recognised e.g. by unpurged VenueCLients. I think
they probably need to be restarted so that they're registered with the
new registry. Do you know who runs that bridge to ask them to restart
it?
chris
> -----Original Message-----
> From: ag-dev-bounces at lists.mcs.anl.gov [mailto:ag-dev-bounces at lists.mcs.anl.gov
> ] On Behalf Of Christoph Willing
> Sent: Thursday, 7 June 2012 9:25 a.m.
> To: Todd Zimmerman
> Cc: ag-dev
> Subject: Re: [AG-DEV] ANL Bridge registry turned off ?
> On 07/06/2012, at 12:33 AM, Todd Zimmerman wrote:
>> On 06/06/2012 03:52 AM, Christoph Willing wrote:
>>> Until the DNS is transferred and we can create an entry for
>>> vv3.accessgrid.org, I wonder if a plain IP address would work there
>>> instead? Todd, could we try this by you changing the peers.txt file
>>> to be:
>>> 130.102.78.188:8030
>>> please?
>> Done
> Thanks. It seems to have worked; I see a lot more bridges now -
> although not yet as many as in the old days ...
> chris
> Christoph Willing +61 7 3365 8316
> Research Computing Centre
> University of Queensland
