[AG-DEV] UCL common lib rtp_recv & frame timing
Andrew Ford
andrew.ford at rit.edu
Wed Jul 28 10:41:41 CDT 2010
Hi Rhys,
I've tried calling rtp_recv once with both 10ms and 1ms timeout times (as
well as no timeout at all) and it looks like it doesn't make a difference. I
also tried changing the system UDP buffer sizes to see if that had any
effect, but it doesn't seem to.
--Andrew
2010/7/27 Rhys Hawkins <rhys.hawkins at anu.edu.au>
> On Tue, 27 Jul 2010 14:12:37 -0400
> Andrew Ford <andrew.ford at rit.edu> wrote:
> > timeout.tv_sec = 0;
> > timeout.tv_usec = 10000;
> > for (int i = 0; i < 1000 && rtp_recv(session, &timeout, _timestamp); i
> > timeout.tv_sec = 0;
> > timeout.tv_usec = 10;
> Hi Andrew,
> All that code is doing is a crude version of:
> while (elapsed_time < 10ms) {
> process incoming packets
> You could try and replace the for loop with just one call to the rtp_recv
> function, ie:
> timeout.tv_sec = 0;
> and see if that fixes your problem.
> The code above was to handle an issue with DV decoding in that decoding an
> entire frame of DV took a certain length of time and during that time the
> UDP buffer (kernel side) could overflow causing loss of data. I don't think
> it should be the cause of your problems, but things are pretty foggy that
> far back in time so it may have other ramifications I've forgotten about.
> Cheers,
> Rhys
URL: <http://lists.mcs.anl.gov/pipermail/ag-dev/attachments/20100728/e941ac42/attachment.htm>
