[AG-DEV] Access Grid 3.0 Release Available
Andrew A Rowley
Andrew.Rowley at manchester.ac.uk
Fri May 5 04:11:51 CDT 2006
I have attached the log file for the AudioService.
The idea for the fix was from:
http://www.answermysearches.com/index.php/category/python/page/2/
http://support.microsoft.com/?id=812486
This does not appear to be a python-specific problem, but a problem in windows in general.
Andrew :)
Access Grid Support Centre,
RSS Group,
Manchester Computing,
Kilburn Building,
University of Manchester,
Oxford Road,
Manchester,
M13 9PL,
UK
Tel: +44(0)161-275 0685
Email: Andrew.Rowley at manchester.ac.uk
> -----Original Message-----
> From: Thomas D. Uram [mailto:turam at mcs.anl.gov]
> Sent: 04 May 2006 19:20
> To: Andrew.Rowley at manchester.ac.uk
> Cc: ag-dev at mcs.anl.gov
> Subject: Re: [AG-DEV] Access Grid 3.0 Release Available
> Could you provide some more information? We haven't seen this be a
> problem
> on other Windows machines. Logfiles would be very helpful.
> Thanks,
> Tom
> On 5/4/06 5:48 AM, Andrew A Rowley wrote:
> > Hi,
> > I installed this, and it worked, but vic and rat were not starting in
> the venue. I found that the Logs contained the line
> > "%1 is not a valid application"
> > On looking in AccessGrid\Platform\win32\ProcessManager.py I found that
> the problem was that while the arguments with spaces were put in inverted
> commas, the same was not true for the command.
> > So I added:
> > if command.find(" ") != -1:
> > command = '"' + command + '"'
> > to the start of the StartProcess function (line 46). This seems to make
> it work again.
> > Andrew :)
> > RSS Group,
> > Kilburn Building,
> > Oxford Road,
> > Manchester,
> > M13 9PL,
> > UK
> >> From: owner-ag-dev at mcs.anl.gov [mailto:owner-ag-dev at mcs.anl.gov] On
> Behalf
> >> Of Thomas D. Uram
> >> Sent: 03 May 2006 17:00
> >> To: ag-dev at mcs.anl.gov
> >> Subject: [AG-DEV] Access Grid 3.0 Release Available
> >> The Access Grid 3.0 software is available for download at:
> >> http://www.mcs.anl.gov/fl/research/accessgrid/software/releases/3.0
> >> This is a major new release of the Access Grid software. (Note that
> AG3
> >> is not compatible with AG2 releases; specifically, AG3 clients and
> servers
> >> do not work with AG2 clients and servers.)
> >> Release Highlights
> >> o Jabber client integration
> >> o Integrated meeting schedule viewer
> >> o Improved venue navigation
> >> + View all Venues on server, exits from current Venue,
> or
> >> MyVenues
> >> + Tree-based perusal of Venue space (without entering)
> >> o Added VenueClient user preferences
> >> o Certificate no longer required by VenueClient
> >> o Improved control of media tools through VenueClient
> >> o Multicast indicator on VenueClient
> >> o Integrated per-Venue Multicast Beacon client
> >> o Integrated beacon matrix
> >> o New bridging facility (available in any venue)
> >> o Encrypted network communications throughout
> >> o Simplified node configuration through discovery of node
> >> services
> >> and service managers on the local subnet (via Bonjour)
> >> o RAT: silence suppression off by default
> >> o VIC: stale streams time out and are removed
> >> o VIC: try to match source port to destination port before
> >> using
> >> ephemeral port as source (simplifies firewall handling
> for
> >> vic)
> >> o Windows users: WDM capture device support, enabling use
> of
> >> capture cards with newer drivers (e.g. Winnov, iTuner)
> >> For full information on this release, and a complete listing of the
> bugs
> >> fixed, see the official release page. For a tour of the new
> >> functionality,
> >> refer to the testing tips at
> http://www.mcs.anl.gov/fl/research/accessgrid/software/releases/3.0/testin
> >> g.html
> >> As part of this release, the default AG3 venue server at
> >> https://vv3.mcs.anl.gov:8000/Venues/default
> >> has been updated to the released AG3 code. Note that AG3 beta Venue
> >> Clients are incompatible with this server.
> >> As always, user feedback is welcome. Please file feature requests, bug
> >> reports, and enhancements via the Access Grid Bugzilla page at
> >> http://bugzilla.mcs.anl.gov/accessgrid.
> >> Thanks,
> >> The AG Developers
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.mcs.anl.gov/pipermail/ag-dev/attachments/20060505/bf067e54/attachment.diff>
