[AG-DEV] AccessGrid3.interfaces??
Susanne Lefvert
lefvert at mcs.anl.gov
Fri Jan 13 11:13:25 CST 2006
Hello Chris,
You are right, setup.py was missing code for generating interfaces. We
have added that to cvs now and are also working on other parts of
packaging for 3.0. The code for packaging in cvs will be changing over the
next few days while we are getting everything worked out.
Thanks for letting us know,
Susanne
On Fri, 13 Jan 2006, Christoph Willing wrote:
> On 13/01/2006, at 7:41 PM, Michael Braitmaier wrote:
> > You should get the interfaces directory when running CVSSetup.py -a
> > from the tools directory.
> > This way the wsdl files from the wsdl directory are compiled to
> > python files which are put into a directory called interfaces.
> > These files provide the "stubs" for the webservices, as far as I
> > understood it.
> Thanks Michael. If that is the case, then this step (or something
> similar that produces the interfaces directory) is missing from
> AccessGrid/setup.py and needs to be added. I gather running
> CVSSetup.py is necessary to run live from CVS, but its never been
> part of the packaging procedure so far.
> chris
> > Christoph Willing schrieb:
> >> I'm just starting to look at building AccessGrid/packaging/
> >> BuildSnapshot.py
> >> The first problem is when it runs AccessGrid/setup.py, where there
> >> is a list named 'packages' containing an element
> >> AccessGrid3.interfaces. All the elements in that list have a
> >> corresponding directory with the same name, however there is no
> >> interfaces directory.
> >> Am I missing an interfaces directory, or can I safely remove
> >> AccessGrid3.interfaces from the list?
> >> chris
> >> Christoph Willing +61 7 3365 8350
> >> QPSF Access Grid Manager
> >> University of Queensland
> > Dipl.-Inf. Michael Braitmaier
> > HLRS - Visualization / Video Conferencing
> > University of Stuttgart
> > Germany
> > Phone: ++49 711 685 5996
> > Fax : ++49 711 682 357
> > Website: http://www.hlrs.de/people/braitmaier/
