[AG-DEV] Getting more than one service stream
Thomas D. Uram
turam at mcs.anl.gov
Fri Jan 13 09:42:45 CST 2006
Hi Derek:
You should find that the ConfigureStream method is called for each
stream. Given that your service needs access to each of these streams,
you would have to collect them as they come in. The default behavior
of services is to expect a single stream, so only one is stored; your
service would be a specialization of this behavior.
An alternative, which I think I'd prefer, is that the recorder be integrated
as a stand-alone application instead of a service. It could, on command, find
the running
VenueClient (see bin/GoToVenue.py for details) and make SOAP calls to
it to get the list of streams, or even the venue URL if you wanted to make calls
directly there. You might want to do the latter, because the venue client's
list of streams is dependent on services that the user has installed, so the
streams you get from it may be a subjective subset of those in the venue.
I've been wanting to talk with you about integration of agvcr. I'm glad to see
you're doing it.
Tom
On 1/13/06 8:19 AM, Derek Piper wrote:
> Hi,
> I'm trying to write a service script (for 2.3 or 2.4) for passing
> parameters to AGVCR, to make it simple for people to use. I've started
> hacking at a service script but I need some help in trying to use the
> details of the service structure.
> I need to be able to get all the info that is in the venue client
> 'properties' dialog.
> i.e.
> stream type name (i.e. audio, video, mlb, screenstreamer)
> host/port/ttl
> I see how to get the encryption key, so that's not a problem. My
> problem is that I don't see how to reference more than one stream. I see
> self.streamDescription.location.host, but that only indicates one. I've
> added capabilities for audio and video, both consumer and producer, but
> it's not apparent how to get those streams' configuration. I'm also
> missing the 'type' field too, I don't know if it's
> self.streamDescription.location.type ? or something else.
> Help would be appreciated.
> Thanks,
> Derek
