[AG-DEV] Using webservices in AG3.0 - How?
Michael Braitmaier braitmaier at hlrs.de
Fri Jan 13 03:44:32 CST 2006
If you have a look at the Accessgrid website under the follwing link
http://www-unix.mcs.anl.gov/fl/research/accessgrid/software/cvs-instructions.html
You will find detailed instructions on how to get the latest
CVS-Snapshot from the repository as well as instructions to install all
the dependencies necessary.
Once you have everything installed, the Snapshot checked out and
followed the instructions for setup, you should be able to run your own
local VenueServer and VenueClient.
Michael
bdr schrieb:
> where can I find the AG 3.0 stuff?
> thanks!
> Eric Olson wrote:
>> Hi Michael,
>> The interfaces for AG 3.0 are generated from wsdl using zsi.
>> You'll find the generated files in AccessGrid/AccessGrid/interfaces.
>> You can locate VenueI and VenueIW by looking at the following to
>> imports in Venue.py:
>> from AccessGrid.interfaces.Venue_client import VenueIW
>> from AccessGrid.interfaces.Venue_interface import Venue as VenueI
>> Since we're all running from cvs until there's a release, these files
>> are generated when you run CvsSetup.py (which runs
>> tools/GenerateInterfaces.py).
>> If you want to see the wsdl sources, you can look in
>> AccessGrid/AccessGrid/wsdl.
>> At the moment a few recent code changes to zsi are causing problems
>> running the AccessGrid 3.0 code.  I'm working on fixing that.
>> Eric
>> Michael Braitmaier wrote:
>>> I am currently trying to use methods implemented in the Venue on the
>>> VenueServer-side in AG3.
>>> With the new AG3 version the "self.venueClient" seems to be the only
>>> access point to the webservice methods of the Venue.
>>> In AG2.4 you used a "self.__venueProxy" to access them which made it
>>> necessary to have the webservice methods defined in the interface
>>> classes "VenueI" and "VenueIW". As they don't exist anymore, is
>>> there something that has to be obbeyed calling webservice methods
>>> through the VenueClient object? Are the Venue methods automatically
>>> available through the VenueClient class, so I can access them like
>>> self.venueclient.myNewWebserviceMethodImplementedAtTheServer()
>>> ? Or do I have to prototype the method in the VenueClient first so
>>> it becomes available in the VenueClient?
>>> Thanks in advance
>>> Michael
Dipl.-Inf. Michael Braitmaier
HLRS - Visualization / Video Conferencing
University of Stuttgart
Germany
Phone: ++49 711 685 5996
Fax  : ++49 711 682 357
Website: http://www.hlrs.de/people/braitmaier/
More information about the ag-dev mailing list
