[AG-DEV] Potential bug in agpm or Node management?
Thomas D. Uram
turam at mcs.anl.gov
Mon Aug 21 14:17:49 CDT 2006
We've always named service packages with a '.zip', and have
been moving toward letting them be named either 'zip' or 'agpkg'
(or 'agpkg3' in AG3). The service manager, however, only looks for
service packages with a 'zip' extension. So, when you ran
agpy against the agpkg3 file, it did actually install it; it just wasn't
picked up by node management.
I've committed a fix to AGServiceManager.py so that it will
pick up agpkg or agpkg3 extensions also.
Meanwhile, the workaround is to use 'zip' for service
packages.
Tom
On 8/20/06 11:41 PM, Rhys Hawkins wrote:
> Hi,
> I just noticed that if I create a node service, but call it an agpkg3, that double
> click claims to have installed it but the new node service doesn't show up in the
> list of services when trying to add a new service in the Node Management dialog.
> Similarly if I run:
> runag3.py agpm3.py -s -p MyService.agpkg3
> It says its installed but is not visible in the list of services, whereas if I
> rename the file to .zip and do:
> runag3.py agpm3.py -s -p MyService.zip
> Everything works.
> Bug or should I not use the agpkg3 extension?
> Versions:
> Windows XP SP2, AGTK3.02, dependencies as per accessgrid.org web page.
> Cheers,
> Rhys
