[AG-DEV] Custom Node Service Enabling/Disabling Problem
Brian Corrie
bcorrie at sfu.ca
Thu Aug 10 14:55:38 CDT 2006
Hi All,
An interesting topic this...
One questions is what is the correct behaviour when a Service gets a
stream description it doesn't expect??? Should it throw an exception?
Should it ignore it? Not sure what the currently intended model is for
the AG 3.x implementation... Tom???
One of the things that it would be nice to be able to do is to make a
StreamDescription extensible. That is, as the creator of a new service
one may want to send stream descriptions that don't fit the current
definition. It would be nice if this was possible and that the low level
service classes didn't throw exceptions when this occurs (I think this
is what is happening here). Leave it up to the implementations of the
services to throw exceptions if they can't handle the Stream description.
Not sure if my description is clear, but this is something that Todd and
I have talked about a couple of times...
Is that possible/reasonable/feasible?
Brian
Todd Zimmerman wrote:
> Sorry for the spam - but just realized that it looks like this issue was identified and a fix was
> made by Michael Braitmaier.
> The problem was the default None values of rate and code in the Capabilities class. Michael made
> the default value of codec = "" and rate = 0 - which allows the match function to properly check for
> matches. This seems to alleviate the issue - but does it raise any other problems??
> Cheers,
> Todd
>> one more time WITH the logfiles... ;-)
>>> Oh... I sent them to ag-dev yesterday...
>>> Here's a resend.
>>> Looks like the relevent section is:
>>> 08/09/2006 11:15:40 AM -1208600896 NodeManagementUIClasses NodeManagementUIClasses.py:1043 ERROR
>>> Error enabling service
>>> Traceback (most recent call last):
>>> File "/usr/lib/python2.4/site-packages/AccessGrid3/AccessGrid/NodeManagementUIClasses.py", line
>>> 1037, in EnableService
>>> self.nodeServiceHandle.SetServiceEnabled(service.uri, 1)
>>> File "/usr/lib/python2.4/site-packages/AccessGrid/AGNodeService.py", line 278, in SetServiceEnabled
>>> self.__SendStreamsToService( serviceUri )
>>> File "/usr/lib/python2.4/site-packages/AccessGrid/AGNodeService.py", line 723, in
>>> raise SetStreamException(failedSends)
>>> SetStreamException: Error updating [producer, debug, None, None, None, 1, consumer, debug, None,
>>> None, None, 1]
>>> Cheers,
>>> Todd
>>> Thomas D. Uram wrote:
>>>> Any details from logfile?
>>>>>> Also, which platform?
>>>>> Fedora Core 5 running AccessGrid-3.0.2-0.1.20060727cvs
>>>>> Cheers,
>>>>> Todd
>>>>> 08/09/06 11:15:07 -1208117568 Toolkit Config.py:559 DEBUG System hostname of floyd.irmacs.sfu.ca is valid
>>>>> 08/09/06 11:15:07 -1208117568 Toolkit Toolkit.py:111 DEBUG Initializing AG Toolkit version 3.0.2
>>>>> 08/09/06 11:15:07 -1208117568 Toolkit Toolkit.py:112 INFO Command and arguments: ['/data/tz/.AccessGrid3/local_services/DebugService/DebugService.py', '--port', '64864', '--serviceManagerUri', 'http://floyd.irmacs.sfu.ca:11000/ServiceManager', '--token', '8e3a358332f86536e976086dbec2c57f']
>>>>> 08/09/06 11:15:07 -1208117568 VenueClient Preferences.py:180 DEBUG Preferences.LoadPreferences: open file
>>>>> 08/09/06 11:15:07 -1208117568 Toolkit Toolkit.py:161 INFO Logfile Name: DebugService.log
>>>>> 08/09/06 11:15:07 -1208117568 Toolkit Toolkit.py:650 INFO Service init: have profile None
>>>>> 08/09/06 11:15:07 -1208117568 Toolkit Toolkit.py:675 INFO Service Initialization Complete.
>>>>> 08/09/06 11:15:07 -1208117568 Toolkit AGService.py:363 INFO Starting Service URI: http://floyd.irmacs.sfu.ca:64864/Services/DebugService.8e3a3583333a6536e9540206adb5e731
>>>>> 08/09/06 11:15:07 -1208117568 Toolkit AGService.py:373 DEBUG Registering with service manager; url=http://floyd.irmacs.sfu.ca:11000/ServiceManager
>>>>> 08/09/06 11:15:07 -1225385056 Toolkit DebugService.py:68 INFO SetIdentity method called
>>>>> 08/09/06 11:15:12 -1225385056 Toolkit AGService.py:214 INFO AGService.SetEnabled : enabled = 0
>>>>> 08/09/06 11:15:12 -1225385056 Toolkit AGService.py:220 INFO Stopping service
>>>>> 08/09/06 11:15:12 -1225385056 Toolkit DebugService.py:50 INFO Stop method called
>>>>> 08/09/06 11:15:14 -1225385056 Toolkit AGService.py:214 INFO AGService.SetEnabled : enabled = 1
>>>>> 08/09/06 11:15:15 -1225385056 Toolkit AGService.py:214 INFO AGService.SetEnabled : enabled = 0
>>>>> 08/09/06 11:15:15 -1225385056 Toolkit AGService.py:220 INFO Stopping service
>>>>> 08/09/06 11:15:15 -1225385056 Toolkit DebugService.py:50 INFO Stop method called
>>>>> 08/09/06 11:15:17 -1225385056 Toolkit AGService.py:214 INFO AGService.SetEnabled : enabled = 1
>>>>> 08/09/06 11:15:23 -1225385056 Toolkit DebugService.py:50 INFO Stop method called
>>>>> 08/09/06 11:15:30 -1225385056 Toolkit AGService.py:214 INFO AGService.SetEnabled : enabled = 0
>>>>> 08/09/06 11:15:30 -1225385056 Toolkit AGService.py:220 INFO Stopping service
>>>>> 08/09/06 11:15:30 -1225385056 Toolkit DebugService.py:50 INFO Stop method called
>>>>> 08/09/06 11:15:38 -1225385056 Toolkit AGService.py:214 INFO AGService.SetEnabled : enabled = 0
>>>>> 08/09/06 11:15:38 -1225385056 Toolkit AGService.py:220 INFO Stopping service
>>>>> 08/09/06 11:15:38 -1225385056 Toolkit DebugService.py:50 INFO Stop method called
>>>>> 08/09/06 11:15:55 -1225385056 Toolkit DebugService.py:50 INFO Stop method called
>>>>> 08/09/06 11:15:58 -1225385056 Toolkit AGService.py:238 INFO Shut service down
>>>>> 08/09/06 11:15:58 -1225385056 Toolkit DebugService.py:50 INFO Stop method called
>>>>> 08/09/06 11:15:58 -1208117568 Toolkit AGService.py:238 INFO Shut service down
>>>>> 08/09/06 11:15:58 -1208117568 Toolkit DebugService.py:50 INFO Stop method called
>>>>> 08/09/2006 11:14:55 AM -1208600896 VenueClientController VenueClientController.py:432 DEBUG VenueClientController calling Venue.EnterVenue
>>>>> 08/09/2006 11:14:55 AM -1208600896 VenueClient VenueClient.py:1015 DEBUG EnterVenue; url=https://venueserver2.westgrid.ca:8000/Venues/default
>>>>> 08/09/2006 11:14:55 AM -1208600896 NodeService AGNodeService.py:658 INFO NodeService.GetCapabilities
>>>>> 08/09/2006 11:14:55 AM -1208600896 NodeService AGNodeService.py:257 INFO NodeService.GetServices
>>>>> 08/09/2006 11:14:55 AM -1225692256 ServiceManager AGServiceManager.py:218 INFO AGServiceManager.GetServices
>>>>> 08/09/2006 11:14:55 AM -1208600896 VenueClient VenueClient.py:1049 DEBUG calling __EnterVenue
>>>>> 08/09/2006 11:14:55 AM -1208600896 VenueClient VenueClient.py:806 DEBUG EnterVenue: Invoke Venue.Enter
>>>>> 08/09/2006 11:14:55 AM -1208600896 VenueClient VenueClient.py:808 DEBUG after Venue.Enter
>>>>> 08/09/2006 11:14:55 AM -1208600896 VenueClient VenueClient.py:810 DEBUG EnterVenue: Invoke Venue.getstate
>>>>> 08/09/2006 11:14:56 AM -1208600896 VenueClient VenueClient.py:812 DEBUG EnterVenue: done Venue.getstate
>>>>> 08/09/2006 11:14:57 AM -1208600896 VenueClient VenueClient.py:835 DEBUG Setting isInVenue flag.
>>>>> 08/09/2006 11:14:57 AM -1208600896 VenueClient VenueClient.py:1051 DEBUG after __EnterVenue
>>>>> 08/09/2006 11:14:57 AM -1208600896 VenueClient VenueClientUI.py:2577 DEBUG bin.VenueClient::EnterVenue: Enter venue with url: https://venueserver2.westgrid.ca:8000/Venues/default
>>>>> 08/09/2006 11:14:57 AM -1208600896 VenueClient VenueClientUI.py:2690 DEBUG Entered venue
>>>>> 08/09/2006 11:14:57 AM -1208600896 VenueClientController VenueClientController.py:434 DEBUG VenueClientController after Venue.EnterVenue
>>>>> 08/09/2006 11:14:57 AM -1225692256 VenueClient VenueClient.py:450 DEBUG Calling Heartbeat, time now: 1155147297
>>>>> 08/09/2006 11:14:57 AM -1208600896 VenueClient VenueClientUI.py:3324 DEBUG ContentListPanel.AddParticipant:: AddParticipant Todd Zimmerman (called from ('/usr/lib/python2.4/site-packages/wx-2.6-gtk2-unicode/wx/_core.py', 13535, '<lambda>', 'lambda event: event.callable(*event.args, **event.kw) )'))
>>>>> 08/09/2006 11:14:57 AM -1225692256 VenueClient VenueClient.py:474 DEBUG Next Heartbeat needed within 36s
>>>>> 08/09/2006 11:14:57 AM -1225692256 JabberClient JabberClient.py:33 INFO Connecting to Jabber Server 'jabber.mcs.anl.gov' ...
>>>>> 08/09/2006 11:14:57 AM -1225692256 bajjer.io io.py:100 DEBUG RECV: <?xml version='1.0'?><stream:stream xmlns:stream='http://etherx.jabber.org/streams' id='44DA2621' xmlns='jabber:client' from='jabber.mcs.anl.gov'>
>>>>> 08/09/2006 11:14:57 AM -1225692256 bajjer.serialize serialize.py:65 DEBUG feed parser initialized
>>>>> 08/09/2006 11:14:57 AM -1225692256 bajjer.serialize serialize.py:72 DEBUG start <{http://etherx.jabber.org/streams}stream> level=0
>>>>> 08/09/2006 11:14:57 AM -1225692256 JabberClient JabberClient.py:168 INFO Registering the user '8180087163ff65364de2ad59cc6ba1e9 at jabber.mcs.anl.gov/default' in jabber server ...
>>>>> 08/09/2006 11:14:57 AM -1225692256 bajjer.io io.py:122 DEBUG SEND: <iq type="get"><query xmlns="jabber:iq:register" /></iq>
>>>>> 08/09/2006 11:14:57 AM -1225692256 bajjer.io io.py:161 DEBUG RECV: <iq type='result'><query xmlns='jabber:iq:register'><password/><password/>
>>>>> <instructions>Choose a username and password to register with this server.</instructions>
>>>>> <name/>
>>>>> <email/>
>>>>> <username/></query></iq>
>>>>> 08/09/2006 11:14:57 AM -1225692256 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}iq> level=1
>>>>> 08/09/2006 11:14:57 AM -1225692256 bajjer.serialize serialize.py:72 DEBUG start <{jabber:iq:register}query> level=2
>>>>> 08/09/2006 11:14:57 AM -1225692256 bajjer.serialize serialize.py:72 DEBUG start <{jabber:iq:register}password> level=3
>>>>> 08/09/2006 11:14:57 AM -1225692256 bajjer.serialize serialize.py:86 DEBUG end <{jabber:iq:register}password> level=3
>>>>> 08/09/2006 11:14:57 AM -1225692256 bajjer.serialize serialize.py:72 DEBUG start <{jabber:iq:register}instructions> level=3
>>>>> 08/09/2006 11:14:57 AM -1225692256 bajjer.serialize serialize.py:86 DEBUG end <{jabber:iq:register}instructions> level=3
>>>>> 08/09/2006 11:14:57 AM -1225692256 bajjer.serialize serialize.py:72 DEBUG start <{jabber:iq:register}name> level=3
>>>>> 08/09/2006 11:14:57 AM -1225692256 bajjer.serialize serialize.py:86 DEBUG end <{jabber:iq:register}name> level=3
>>>>> 08/09/2006 11:14:57 AM -1225692256 bajjer.serialize serialize.py:72 DEBUG start <{jabber:iq:register}email> level=3
>>>>> 08/09/2006 11:14:57 AM -1225692256 bajjer.serialize serialize.py:86 DEBUG end <{jabber:iq:register}email> level=3
>>>>> 08/09/2006 11:14:57 AM -1225692256 bajjer.serialize serialize.py:72 DEBUG start <{jabber:iq:register}username> level=3
>>>>> 08/09/2006 11:14:57 AM -1225692256 bajjer.serialize serialize.py:86 DEBUG end <{jabber:iq:register}username> level=3
>>>>> 08/09/2006 11:14:57 AM -1225692256 bajjer.serialize serialize.py:86 DEBUG end <{jabber:iq:register}query> level=2
>>>>> 08/09/2006 11:14:57 AM -1225692256 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}iq> level=1
>>>>> 08/09/2006 11:14:57 AM -1225692256 bajjer.io io.py:122 DEBUG SEND: <iq type="set"><query xmlns="jabber:iq:register"><username>8180087163ff65364de2ad59cc6ba1e9</username><password>8180087163ff65364de2ad59cc6ba1e9</password></query></iq>
>>>>> 08/09/2006 11:14:58 AM -1225692256 bajjer.io io.py:161 DEBUG RECV: <iq type='result'/>
>>>>> 08/09/2006 11:14:58 AM -1225692256 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}iq> level=1
>>>>> 08/09/2006 11:14:58 AM -1225692256 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}iq> level=1
>>>>> 08/09/2006 11:14:58 AM -1208600896 GroupMsgClient GroupMsgClient.py:112 INFO Connected. Connection ID: 8180087163ff65364de2ad59cc6ba1e9
>>>>> 08/09/2006 11:14:58 AM -1208600896 EventClient InsecureVenueEventClient.py:60 INFO BaseVenueEventClient made connection.
>>>>> 08/09/2006 11:14:59 AM -1225692256 JabberClient JabberClient.py:177 INFO Attempting to log in as 8180087163ff65364de2ad59cc6ba1e9 at jabber.mcs.anl.gov/default ...
>>>>> 08/09/2006 11:14:59 AM -1225692256 bajjer.io io.py:122 DEBUG SEND: <iq type="get"><query xmlns="jabber:iq:auth"><username>8180087163ff65364de2ad59cc6ba1e9</username></query></iq>
>>>>> 08/09/2006 11:14:59 AM -1225692256 bajjer.io io.py:161 DEBUG RECV: <iq type='result'><query xmlns='jabber:iq:auth'><username>8180087163ff65364de2ad59cc6ba1e9</username><digest/><password/><resource/></query></iq>
>>>>> 08/09/2006 11:14:59 AM -1225692256 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}iq> level=1
>>>>> 08/09/2006 11:14:59 AM -1225692256 bajjer.serialize serialize.py:72 DEBUG start <{jabber:iq:auth}query> level=2
>>>>> 08/09/2006 11:14:59 AM -1225692256 bajjer.serialize serialize.py:72 DEBUG start <{jabber:iq:auth}username> level=3
>>>>> 08/09/2006 11:14:59 AM -1225692256 bajjer.serialize serialize.py:86 DEBUG end <{jabber:iq:auth}username> level=3
>>>>> 08/09/2006 11:14:59 AM -1225692256 bajjer.serialize serialize.py:72 DEBUG start <{jabber:iq:auth}digest> level=3
>>>>> 08/09/2006 11:14:59 AM -1225692256 bajjer.serialize serialize.py:86 DEBUG end <{jabber:iq:auth}digest> level=3
>>>>> 08/09/2006 11:14:59 AM -1225692256 bajjer.serialize serialize.py:72 DEBUG start <{jabber:iq:auth}password> level=3
>>>>> 08/09/2006 11:14:59 AM -1225692256 bajjer.serialize serialize.py:86 DEBUG end <{jabber:iq:auth}password> level=3
>>>>> 08/09/2006 11:14:59 AM -1225692256 bajjer.serialize serialize.py:72 DEBUG start <{jabber:iq:auth}resource> level=3
>>>>> 08/09/2006 11:14:59 AM -1225692256 bajjer.serialize serialize.py:86 DEBUG end <{jabber:iq:auth}resource> level=3
>>>>> 08/09/2006 11:14:59 AM -1225692256 bajjer.serialize serialize.py:86 DEBUG end <{jabber:iq:auth}query> level=2
>>>>> 08/09/2006 11:14:59 AM -1225692256 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}iq> level=1
>>>>> 08/09/2006 11:14:59 AM -1225692256 bajjer.stream stream.py:326 DEBUG Recv: <gov.lbl.dsd.bajjer.stanza.Iq object at 0xb46c2dcc>
>>>>> 08/09/2006 11:14:59 AM -1225692256 bajjer.stream stream.py:342 DEBUG performing 'digest' authentication
>>>>> 08/09/2006 11:14:59 AM -1225692256 bajjer.io io.py:122 DEBUG SEND: <iq type="set"><query xmlns="jabber:iq:auth"><resource>default</resource><username>8180087163ff65364de2ad59cc6ba1e9</username><digest>cf40bb3969d2778217e87b01c0948d0cf96ec019</digest></query></iq>
>>>>> 08/09/2006 11:14:59 AM -1225692256 bajjer.io io.py:161 DEBUG RECV: <iq type='result' id='pthsock_client_auth_ID'/>
>>>>> 08/09/2006 11:14:59 AM -1225692256 bajjer.stream stream.py:351 DEBUG Authorization succeeded
>>>>> 08/09/2006 11:14:59 AM -1225692256 bajjer.io io.py:122 DEBUG SEND: <iq from="8180087163ff65364de2ad59cc6ba1e9" type="get"><query xmlns="jabber:iq:roster" /></iq>
>>>>> 08/09/2006 11:14:59 AM -1225692256 bajjer.io io.py:161 DEBUG RECV: <iq from='8180087163ff65364de2ad59cc6ba1e9 at jabber.mcs.anl.gov/default' type='result'><query xmlns='jabber:iq:roster'/></iq>
>>>>> 08/09/2006 11:14:59 AM -1225692256 bajjer.serialize serialize.py:72 DEBUG start <{jabber:iq:roster}query> level=2
>>>>> 08/09/2006 11:14:59 AM -1225692256 bajjer.serialize serialize.py:86 DEBUG end <{jabber:iq:roster}query> level=2
>>>>> 08/09/2006 11:14:59 AM -1225692256 bajjer.io io.py:122 DEBUG SEND: <presence />
>>>>> 08/09/2006 11:14:59 AM -1225692256 JabberClient JabberClient.py:73 DEBUG Sending the presence to 'Main-Lobby(venueserver2.westgrid.ca)@conference.mcs.anl.gov/Todd Zimmerman' of type 'available'...
>>>>> 08/09/2006 11:14:59 AM -1225692256 bajjer.io io.py:122 DEBUG SEND: <presence to="Main-Lobby(venueserver2.westgrid.ca)@conference.mcs.anl.gov/Todd Zimmerman" type="available"><x /></presence>
>>>>> 08/09/2006 11:14:59 AM -1225692256 VenueClient VenueClient.py:959 INFO VenueClient.StartBeacon: Address 233.59.192.88/49482
>>>>> 08/09/2006 11:14:59 AM -1225692256 RTPBeacon RTPBeacon.py:278 DEBUG Called Start.
>>>>> 08/09/2006 11:14:59 AM -1225692256 VenueClient VenueClient.py:1231 INFO In UpdateStream: transport=unicast
>>>>> 08/09/2006 11:14:59 AM -1345344608 bajjer.io io.py:161 DEBUG RECV: <message from='jabber.mcs.anl.gov' to='8180087163ff65364de2ad59cc6ba1e9 at jabber.mcs.anl.gov'>
>>>>> <subject>Welcome!</subject>
>>>>> <body>Welcome to the Access Grid Jabber server @ jabber.mcs.anl.gov -- we hope you enjoy this service! For information about how to use Jabber, visit the Jabber User's Guide at http://jabbermanual.jabberstudio.org/</body>
>>>>> <x xmlns='jabber:x:delay' from='8180087163ff65364de2ad59cc6ba1e9 at jabber.mcs.anl.gov' stamp='20060809T18:14:57'>Offline Storage</x></message>
>>>>> 08/09/2006 11:14:59 AM -1345344608 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}message> level=1
>>>>> 08/09/2006 11:14:59 AM -1345344608 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}subject> level=2
>>>>> 08/09/2006 11:14:59 AM -1345344608 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}subject> level=2
>>>>> 08/09/2006 11:14:59 AM -1345344608 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}body> level=2
>>>>> 08/09/2006 11:14:59 AM -1345344608 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}body> level=2
>>>>> 08/09/2006 11:14:59 AM -1345344608 bajjer.serialize serialize.py:72 DEBUG start <{jabber:x:delay}x> level=2
>>>>> 08/09/2006 11:14:59 AM -1345344608 bajjer.serialize serialize.py:86 DEBUG end <{jabber:x:delay}x> level=2
>>>>> 08/09/2006 11:14:59 AM -1345344608 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}message> level=1
>>>>> 08/09/2006 11:14:59 AM -1345344608 JabberClient JabberClient.py:133 DEBUG jabber.mcs.anl.go: Welcome to the Access Grid Jabber server @ jabber.mcs.anl.gov -- we hope you enjoy this service! For information about how to use Jabber, visit the Jabber User's Guide at http://jabbermanual.jabberstudio.org/
>>>>> 08/09/2006 11:14:59 AM -1225692256 VenueClient VenueClient.py:1260 DEBUG Got location from bridge: unicast milton.mcs.anl.gov 53768
>>>>> 08/09/2006 11:14:59 AM -1345344608 bajjer.io io.py:161 DEBUG RECV: <presence to='8180087163ff65364de2ad59cc6ba1e9 at jabber.mcs.anl.gov/default' from='main-lobby(venueserver2.westgrid.ca)@conference.mcs.anl.gov/Todd Zimmerman'><x/><x xmlns='http://jabber.org/protocol/muc#user'><item affiliation='none' role='participant'/></x></presence>
>>>>> 08/09/2006 11:14:59 AM -1345344608 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}presence> level=1
>>>>> 08/09/2006 11:14:59 AM -1345344608 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}x> level=2
>>>>> 08/09/2006 11:14:59 AM -1345344608 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}x> level=2
>>>>> 08/09/2006 11:14:59 AM -1345344608 bajjer.serialize serialize.py:72 DEBUG start <{http://jabber.org/protocol/muc#user}x> level=2
>>>>> 08/09/2006 11:14:59 AM -1345344608 bajjer.serialize serialize.py:72 DEBUG start <{http://jabber.org/protocol/muc#user}item> level=3
>>>>> 08/09/2006 11:14:59 AM -1345344608 bajjer.serialize serialize.py:86 DEBUG end <{http://jabber.org/protocol/muc#user}item> level=3
>>>>> 08/09/2006 11:14:59 AM -1345344608 bajjer.serialize serialize.py:86 DEBUG end <{http://jabber.org/protocol/muc#user}x> level=2
>>>>> 08/09/2006 11:14:59 AM -1345344608 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}presence> level=1
>>>>> 08/09/2006 11:14:59 AM -1345344608 JabberClient JabberClient.py:145 DEBUG main-lobby(venueserver2.westgrid.ca)@conference.mcs.anl.gov/Todd Zimmerman is available (None / None)
>>>>> 08/09/2006 11:14:59 AM -1345344608 VenueClient VenueClientUI.py:2299 DEBUG add user: Todd Zimmerman
>>>>> 08/09/2006 11:14:59 AM -1345344608 bajjer.io io.py:161 DEBUG RECV: <message type='groupchat' to='8180087163ff65364de2ad59cc6ba1e9 at jabber.mcs.anl.gov/default' from='main-lobby(venueserver2.westgrid.ca)@conference.mcs.anl.gov'><body>main-lobby(venueserver2.westgrid.ca)</body></message>
>>>>> 08/09/2006 11:14:59 AM -1345344608 JabberClient JabberClient.py:133 DEBUG main-lobby(venueserver2.westgrid.ca)@conference.mcs.anl.go: main-lobby(venueserver2.westgrid.ca)
>>>>> 08/09/2006 11:14:59 AM -1345344608 bajjer.io io.py:161 DEBUG RECV: <message type='groupchat' to='8180087163ff65364de2ad59cc6ba1e9 at jabber.mcs.anl.gov/default' from='main-lobby(venueserver2.westgrid.ca)@conference.mcs.anl.gov'><body>This room supports the MUC protocol.</body></message>
>>>>> 08/09/2006 11:14:59 AM -1225692256 VenueClient VenueClient.py:1260 DEBUG Got location from bridge: unicast milton.mcs.anl.gov 52884
>>>>> 08/09/2006 11:14:59 AM -1345344608 bajjer.io io.py:161 DEBUG RECV: <message type='groupchat' from='main-lobby(venueserver2.westgrid.ca)@conference.mcs.anl.gov' to='8180087163ff65364de2ad59cc6ba1e9 at jabber.mcs.anl.gov/default'><body>Todd Zimmerman has joined this session</body></message>
>>>>> 08/09/2006 11:14:59 AM -1345344608 JabberClient JabberClient.py:133 DEBUG main-lobby(venueserver2.westgrid.ca)@conference.mcs.anl.go: This room supports the MUC protocol.
>>>>> 08/09/2006 11:14:59 AM -1345344608 JabberClient JabberClient.py:133 DEBUG main-lobby(venueserver2.westgrid.ca)@conference.mcs.anl.go: Todd Zimmerman has joined this session
>>>>> 08/09/2006 11:14:59 AM -1225692256 VenueClient VenueClient.py:1260 DEBUG Got location from bridge: unicast milton.mcs.anl.gov 52844
>>>>> 08/09/2006 11:14:59 AM -1225692256 RTPBeacon RTPBeacon.py:296 DEBUG Called Stop.
>>>>> 08/09/2006 11:14:59 AM -1225692256 VenueClient VenueClient.py:951 INFO Beacon being reconfigured, stopping running beacon
>>>>> 08/09/2006 11:14:59 AM -1225692256 VenueClient VenueClient.py:959 INFO VenueClient.StartBeacon: Address milton.mcs.anl.gov/52844
>>>>> 08/09/2006 11:14:59 AM -1225692256 VenueClient VenueClient.py:1190 DEBUG UpdateNodeService: Method UpdateNodeService called
>>>>> 08/09/2006 11:14:59 AM -1225692256 VenueClient VenueClient.py:1195 DEBUG Setting node service streams
>>>>> 08/09/2006 11:14:59 AM -1225692256 NodeService AGNodeService.py:328 INFO NodeService.SetStreams
>>>>> 08/09/2006 11:14:59 AM -1225692256 NodeService AGNodeService.py:257 INFO NodeService.GetServices
>>>>> 08/09/2006 11:14:59 AM -1387304032 ServiceManager AGServiceManager.py:218 INFO AGServiceManager.GetServices
>>>>> 08/09/2006 11:15:00 AM -1225692256 NodeService AGNodeService.py:695 INFO NodeService.__SendStreamsToService
>>>>> 08/09/2006 11:15:00 AM -1366324320 RTPBeacon RTPBeacon.py:289 INFO RTPBeacon.UpdateThread exiting
>>>>> 08/09/2006 11:15:00 AM -1225692256 NodeService AGNodeService.py:699 DEBUG service capabilities: [consumer, audio, 8e3a358333096536dec30af9596ae5ae, L16, 16000, 1, consumer, audio, 8e3a358333096536dec30af9596ae5ae, L16, 8000, 1, consumer, audio, 8e3a358333096536dec30af9596ae5ae, L8, 16000, 1, consumer, audio, 8e3a358333096536dec30af9596ae5ae, L8, 8000, 1, consumer, audio, 8e3a358333096536dec30af9596ae5ae, PCMU, 16000, 1, consumer, audio, 8e3a358333096536dec30af9596ae5ae, PCMU, 8000, 1, consumer, audio, 8e3a358333096536dec30af9596ae5ae, GSM, 16000, 1, consumer, audio, 8e3a358333096536dec30af9596ae5ae, GSM, 8000, 1, producer, audio, 8e3a358333096536dec30af9596ae5ae, L16, 16000, 1]
>>>>> 08/09/2006 11:15:00 AM -1225692256 NodeService AGNodeService.py:713 INFO Sending stream (type=[consumer, audio, 8180087163ff629be0bebd48a1912f0f, L16, 16000, 1, consumer, audio, 8180087163ff629be0bebd48a1912f0f, L16, 8000, 1, consumer, audio, 8180087163ff629be0bebd48a1912f0f, L8, 16000, 1, consumer, audio, 8180087163ff629be0bebd48a1912f0f, L8, 8000, 1, consumer, audio, 8180087163ff629be0bebd48a1912f0f, PCMU, 16000, 1, consumer, audio, 8180087163ff629be0bebd48a1912f0f, PCMU, 8000, 1, consumer, audio, 8180087163ff629be0bebd48a1912f0f, GSM, 16000, 1, consumer, audio, 8180087163ff629be0bebd48a1912f0f, GSM, 8000, 1]) to service: http://floyd.irmacs.sfu.ca:56488/Services/AudioService.8e3a358333096536decfdc29e8e7216d
>>>>> 08/09/2006 11:15:00 AM -1225692256 NodeService AGNodeService.py:699 DEBUG service capabilities: [consumer, video, 8e3a358333036536de76e51f5b703c18, H261, 90000, 1, producer, video, 8e3a358333036536de76e51f5b703c18, H261, 90000, 1]
>>>>> 08/09/2006 11:15:00 AM -1225692256 NodeService AGNodeService.py:713 INFO Sending stream (type=[consumer, video, 8180087163ff629be0bbbd489dcbd809, H261, 90000, 1]) to service: http://floyd.irmacs.sfu.ca:62272/Services/VideoService.8e3a358333036536de95b64fe81b7c08
>>>>> 08/09/2006 11:15:00 AM -1225692256 VenueClient VenueClient.py:914 DEBUG Updating client profile cache.
>>>>> 08/09/2006 11:15:00 AM -1208600896 VenueClient VenueClientUI.py:1291 DEBUG VenueClientFrame.ManageNodeCB: open node management
>>>>> 08/09/2006 11:15:00 AM -1208600896 VenueClient VenueClientUI.py:1292 DEBUG nodeservice url: <AccessGrid.AGNodeService.AGNodeService instance at 0xb6f3518c>
>>>>> 08/09/2006 11:15:00 AM -1208600896 NodeService AGNodeService.py:248 INFO NodeService.GetServiceManagers
>>>>> 08/09/2006 11:15:00 AM -1225692256 ServiceManager AGServiceManager.py:218 INFO AGServiceManager.GetServices
>>>>> 08/09/2006 11:15:07 AM -1225692256 ServiceManager AGServiceManager.py:102 INFO AGServiceManager.AddService
>>>>> 08/09/2006 11:15:07 AM -1225692256 ServiceManager AGServiceManager.py:339 INFO Installed service version: 1.1, package version: 1.1
>>>>> 08/09/2006 11:15:07 AM -1225692256 ServiceManager AGServiceManager.py:374 DEBUG Executing service DebugService
>>>>> 08/09/2006 11:15:07 AM -1225692256 ServiceManager AGServiceManager.py:406 INFO Running Service; options: ['/data/tz/.AccessGrid3/local_services/DebugService/DebugService.py', '--port', 64864, '--serviceManagerUri', 'http://floyd.irmacs.sfu.ca:11000/ServiceManager', '--token', '8e3a358332f86536e976086dbec2c57f']
>>>>> 08/09/2006 11:15:07 AM -1225692256 ServiceManager AGServiceManager.py:418 INFO Service registered: http://floyd.irmacs.sfu.ca:64864/Services/DebugService.8e3a3583333a6536e9540206adb5e731 8e3a358332f86536e976086dbec2c57f
>>>>> 08/09/2006 11:15:07 AM -1208600896 NodeManagementUIClasses NodeManagementUIClasses.py:1000 INFO No resources for service
>>>>> 08/09/2006 11:15:07 AM -1208600896 VenueClient VenueClientUI.py:1933 INFO OnNodeActivity: got action: add_service
>>>>> 08/09/2006 11:15:07 AM -1208600896 NodeService AGNodeService.py:248 INFO NodeService.GetServiceManagers
>>>>> 08/09/2006 11:15:07 AM -1225692256 ServiceManager AGServiceManager.py:218 INFO AGServiceManager.GetServices
>>>>> 08/09/2006 11:15:12 AM -1208600896 NodeService AGNodeService.py:275 INFO NodeService.SetServiceEnabled
>>>>> 08/09/2006 11:15:12 AM -1208600896 NodeService AGNodeService.py:248 INFO NodeService.GetServiceManagers
>>>>> 08/09/2006 11:15:12 AM -1225692256 ServiceManager AGServiceManager.py:218 INFO AGServiceManager.GetServices
>>>>> 08/09/2006 11:15:14 AM -1208600896 NodeManagementUIClasses NodeManagementUIClasses.py:1036 DEBUG NodeManagementClientFrame.EnableService: Enabling Service: DebugService
>>>>> 08/09/2006 11:15:14 AM -1208600896 NodeService AGNodeService.py:275 INFO NodeService.SetServiceEnabled
>>>>> 08/09/2006 11:15:14 AM -1208600896 NodeService AGNodeService.py:695 INFO NodeService.__SendStreamsToService
>>>>> 08/09/2006 11:15:14 AM -1208600896 NodeService AGNodeService.py:699 DEBUG service capabilities: [producer, debug, None, None, None, 1, consumer, debug, None, None, None, 1]
>>>>> 08/09/2006 11:15:14 AM -1208600896 NodeService AGNodeService.py:248 INFO NodeService.GetServiceManagers
>>>>> 08/09/2006 11:15:14 AM -1225692256 ServiceManager AGServiceManager.py:218 INFO AGServiceManager.GetServices
>>>>> 08/09/2006 11:15:15 AM -1208600896 NodeService AGNodeService.py:275 INFO NodeService.SetServiceEnabled
>>>>> 08/09/2006 11:15:15 AM -1208600896 NodeService AGNodeService.py:248 INFO NodeService.GetServiceManagers
>>>>> 08/09/2006 11:15:15 AM -1225692256 ServiceManager AGServiceManager.py:218 INFO AGServiceManager.GetServices
>>>>> 08/09/2006 11:15:16 AM -1208600896 NodeManagementUIClasses NodeManagementUIClasses.py:1036 DEBUG NodeManagementClientFrame.EnableService: Enabling Service: DebugService
>>>>> 08/09/2006 11:15:17 AM -1208600896 NodeService AGNodeService.py:275 INFO NodeService.SetServiceEnabled
>>>>> 08/09/2006 11:15:17 AM -1208600896 NodeService AGNodeService.py:695 INFO NodeService.__SendStreamsToService
>>>>> 08/09/2006 11:15:17 AM -1208600896 NodeService AGNodeService.py:699 DEBUG service capabilities: [producer, debug, None, None, None, 1, consumer, debug, None, None, None, 1]
>>>>> 08/09/2006 11:15:17 AM -1208600896 NodeService AGNodeService.py:248 INFO NodeService.GetServiceManagers
>>>>> 08/09/2006 11:15:17 AM -1225692256 ServiceManager AGServiceManager.py:218 INFO AGServiceManager.GetServices
>>>>> 08/09/2006 11:15:23 AM -1208600896 VenueClient VenueClient.py:1132 INFO ExitVenue
>>>>> 08/09/2006 11:15:23 AM -1208600896 VenueClient VenueClient.py:1173 INFO ExitVenue: Stopping node services
>>>>> 08/09/2006 11:15:23 AM -1208600896 NodeService AGNodeService.py:301 INFO NodeService.StopServices
>>>>> 08/09/2006 11:15:23 AM -1225692256 ServiceManager AGServiceManager.py:225 INFO AGServiceManager.StopServices
>>>>> 08/09/2006 11:15:24 AM -1208600896 NodeService AGNodeService.py:328 INFO NodeService.SetStreams
>>>>> 08/09/2006 11:15:24 AM -1208600896 NodeService AGNodeService.py:257 INFO NodeService.GetServices
>>>>> 08/09/2006 11:15:24 AM -1225692256 ServiceManager AGServiceManager.py:218 INFO AGServiceManager.GetServices
>>>>> 08/09/2006 11:15:24 AM -1208600896 NodeService AGNodeService.py:695 INFO NodeService.__SendStreamsToService
>>>>> 08/09/2006 11:15:24 AM -1208600896 NodeService AGNodeService.py:699 DEBUG service capabilities: [consumer, audio, 8e3a358333096536dec30af9596ae5ae, L16, 16000, 1, consumer, audio, 8e3a358333096536dec30af9596ae5ae, L16, 8000, 1, consumer, audio, 8e3a358333096536dec30af9596ae5ae, L8, 16000, 1, consumer, audio, 8e3a358333096536dec30af9596ae5ae, L8, 8000, 1, consumer, audio, 8e3a358333096536dec30af9596ae5ae, PCMU, 16000, 1, consumer, audio, 8e3a358333096536dec30af9596ae5ae, PCMU, 8000, 1, consumer, audio, 8e3a358333096536dec30af9596ae5ae, GSM, 16000, 1, consumer, audio, 8e3a358333096536dec30af9596ae5ae, GSM, 8000, 1, producer, audio, 8e3a358333096536dec30af9596ae5ae, L16, 16000, 1]
>>>>> 08/09/2006 11:15:24 AM -1208600896 NodeService AGNodeService.py:699 DEBUG service capabilities: [producer, debug, None, None, None, 1, consumer, debug, None, None, None, 1]
>>>>> 08/09/2006 11:15:24 AM -1208600896 NodeService AGNodeService.py:699 DEBUG service capabilities: [consumer, video, 8e3a358333036536de76e51f5b703c18, H261, 90000, 1, producer, video, 8e3a358333036536de76e51f5b703c18, H261, 90000, 1]
>>>>> 08/09/2006 11:15:25 AM -1208600896 VenueClient VenueClient.py:1103 DEBUG ExitVenue: Stop event client obj
>>>>> 08/09/2006 11:15:25 AM -1208600896 VenueClient VenueClient.py:1105 DEBUG ExitVenue: Remove event client reference
>>>>> 08/09/2006 11:15:25 AM -1208600896 VenueClient VenueClient.py:1110 INFO ExitVenue: Stopping text client
>>>>> 08/09/2006 11:15:25 AM -1208600896 JabberClient JabberClient.py:73 DEBUG Sending the presence to 'Main-Lobby(venueserver2.westgrid.ca)@conference.mcs.anl.gov/Todd Zimmerman' of type 'unavailable'...
>>>>> 08/09/2006 11:15:25 AM -1208600896 bajjer.io io.py:122 DEBUG SEND: <presence to="Main-Lobby(venueserver2.westgrid.ca)@conference.mcs.anl.gov/Todd Zimmerman" type="unavailable"><x /></presence>
>>>>> 08/09/2006 11:15:25 AM -1208600896 RTPBeacon RTPBeacon.py:296 DEBUG Called Stop.
>>>>> 08/09/2006 11:15:25 AM -1208600896 VenueClientController VenueClientController.py:432 DEBUG VenueClientController calling Venue.EnterVenue
>>>>> 08/09/2006 11:15:25 AM -1208600896 VenueClient VenueClient.py:1015 DEBUG EnterVenue; url=https://venueserver2.westgrid.ca:8000/Venues/8e3a35534ae01a166229939b5aed6d47
>>>>> 08/09/2006 11:15:25 AM -1208600896 NodeService AGNodeService.py:658 INFO NodeService.GetCapabilities
>>>>> 08/09/2006 11:15:25 AM -1208600896 NodeService AGNodeService.py:257 INFO NodeService.GetServices
>>>>> 08/09/2006 11:15:25 AM -1334854752 ServiceManager AGServiceManager.py:218 INFO AGServiceManager.GetServices
>>>>> 08/09/2006 11:15:25 AM -1345344608 bajjer.io io.py:161 DEBUG RECV: <presence to='8180087163ff65364de2ad59cc6ba1e9 at jabber.mcs.anl.gov/default' type='unavailable' from='main-lobby(venueserver2.westgrid.ca)@conference.mcs.anl.gov/Todd Zimmerman'><x/><x xmlns='http://jabber.org/protocol/muc#user'><item affiliation='none' role='none'/></x></presence>
>>>>> 08/09/2006 11:15:25 AM -1345344608 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}presence> level=1
>>>>> 08/09/2006 11:15:25 AM -1345344608 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}x> level=2
>>>>> 08/09/2006 11:15:25 AM -1345344608 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}x> level=2
>>>>> 08/09/2006 11:15:25 AM -1345344608 bajjer.serialize serialize.py:72 DEBUG start <{http://jabber.org/protocol/muc#user}x> level=2
>>>>> 08/09/2006 11:15:25 AM -1345344608 bajjer.serialize serialize.py:72 DEBUG start <{http://jabber.org/protocol/muc#user}item> level=3
>>>>> 08/09/2006 11:15:25 AM -1345344608 bajjer.serialize serialize.py:86 DEBUG end <{http://jabber.org/protocol/muc#user}item> level=3
>>>>> 08/09/2006 11:15:25 AM -1345344608 bajjer.serialize serialize.py:86 DEBUG end <{http://jabber.org/protocol/muc#user}x> level=2
>>>>> 08/09/2006 11:15:25 AM -1345344608 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}presence> level=1
>>>>> 08/09/2006 11:15:25 AM -1345344608 JabberClient JabberClient.py:148 DEBUG main-lobby(venueserver2.westgrid.ca)@conference.mcs.anl.gov/Todd Zimmerman is unavailable (None / None)
>>>>> 08/09/2006 11:15:25 AM -1345344608 VenueClient VenueClientUI.py:2313 DEBUG remove user: Todd Zimmerman
>>>>> 08/09/2006 11:15:25 AM -1208600896 VenueClient VenueClient.py:1049 DEBUG calling __EnterVenue
>>>>> 08/09/2006 11:15:25 AM -1208600896 VenueClient VenueClient.py:806 DEBUG EnterVenue: Invoke Venue.Enter
>>>>> 08/09/2006 11:15:25 AM -1376814176 RTPBeacon RTPBeacon.py:289 INFO RTPBeacon.UpdateThread exiting
>>>>> 08/09/2006 11:15:25 AM -1208600896 VenueClient VenueClient.py:808 DEBUG after Venue.Enter
>>>>> 08/09/2006 11:15:25 AM -1208600896 VenueClient VenueClient.py:810 DEBUG EnterVenue: Invoke Venue.getstate
>>>>> 08/09/2006 11:15:26 AM -1208600896 VenueClient VenueClient.py:812 DEBUG EnterVenue: done Venue.getstate
>>>>> 08/09/2006 11:15:26 AM -1208600896 VenueClient VenueClient.py:835 DEBUG Setting isInVenue flag.
>>>>> 08/09/2006 11:15:26 AM -1208600896 VenueClient VenueClient.py:1051 DEBUG after __EnterVenue
>>>>> 08/09/2006 11:15:26 AM -1208600896 VenueClient VenueClientUI.py:2577 DEBUG bin.VenueClient::EnterVenue: Enter venue with url: https://venueserver2.westgrid.ca:8000/Venues/8e3a35534ae01a166229939b5aed6d47
>>>>> 08/09/2006 11:15:26 AM -1208600896 VenueClient VenueClientUI.py:2690 DEBUG Entered venue
>>>>> 08/09/2006 11:15:26 AM -1208600896 VenueClientController VenueClientController.py:434 DEBUG VenueClientController after Venue.EnterVenue
>>>>> 08/09/2006 11:15:26 AM -1376814176 VenueClient VenueClient.py:450 DEBUG Calling Heartbeat, time now: 1155147326
>>>>> 08/09/2006 11:15:26 AM -1208600896 VenueClient VenueClientUI.py:3340 DEBUG ContentListPanel.RemoveParticipant: Remove participant
>>>>> 08/09/2006 11:15:26 AM -1208600896 VenueClient VenueClientUI.py:3324 DEBUG ContentListPanel.AddParticipant:: AddParticipant Todd Zimmerman (called from ('/usr/lib/python2.4/site-packages/wx-2.6-gtk2-unicode/wx/_core.py', 13535, '<lambda>', 'lambda event: event.callable(*event.args, **event.kw) )'))
>>>>> 08/09/2006 11:15:27 AM -1376814176 VenueClient VenueClient.py:474 DEBUG Next Heartbeat needed within 36s
>>>>> 08/09/2006 11:15:27 AM -1376814176 JabberClient JabberClient.py:73 DEBUG Sending the presence to 'AG-Tech-Room(venueserver2.westgrid.ca)@conference.mcs.anl.gov/Todd Zimmerman' of type 'available'...
>>>>> 08/09/2006 11:15:27 AM -1376814176 bajjer.io io.py:122 DEBUG SEND: <presence to="AG-Tech-Room(venueserver2.westgrid.ca)@conference.mcs.anl.gov/Todd Zimmerman" type="available"><x /></presence>
>>>>> 08/09/2006 11:15:27 AM -1376814176 VenueClient VenueClient.py:951 INFO Beacon being reconfigured, stopping running beacon
>>>>> 08/09/2006 11:15:27 AM -1376814176 RTPBeacon RTPBeacon.py:296 DEBUG Called Stop.
>>>>> 08/09/2006 11:15:27 AM -1376814176 VenueClient VenueClient.py:959 INFO VenueClient.StartBeacon: Address 233.59.192.114/63534
>>>>> 08/09/2006 11:15:27 AM -1376814176 RTPBeacon RTPBeacon.py:278 DEBUG Called Start.
>>>>> 08/09/2006 11:15:27 AM -1376814176 VenueClient VenueClient.py:1231 INFO In UpdateStream: transport=unicast
>>>>> 08/09/2006 11:15:27 AM -1345344608 bajjer.io io.py:161 DEBUG RECV: <presence to='8180087163ff65364de2ad59cc6ba1e9 at jabber.mcs.anl.gov/default' from='ag-tech-room(venueserver2.westgrid.ca)@conference.mcs.anl.gov/Todd Zimmerman'><x/><x xmlns='http://jabber.org/protocol/muc#user'><item affiliation='none' role='participant'/></x></presence>
>>>>> 08/09/2006 11:15:27 AM -1345344608 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}presence> level=1
>>>>> 08/09/2006 11:15:27 AM -1345344608 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}x> level=2
>>>>> 08/09/2006 11:15:27 AM -1345344608 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}x> level=2
>>>>> 08/09/2006 11:15:27 AM -1345344608 bajjer.serialize serialize.py:72 DEBUG start <{http://jabber.org/protocol/muc#user}x> level=2
>>>>> 08/09/2006 11:15:27 AM -1345344608 bajjer.serialize serialize.py:72 DEBUG start <{http://jabber.org/protocol/muc#user}item> level=3
>>>>> 08/09/2006 11:15:27 AM -1345344608 bajjer.serialize serialize.py:86 DEBUG end <{http://jabber.org/protocol/muc#user}item> level=3
>>>>> 08/09/2006 11:15:27 AM -1345344608 bajjer.serialize serialize.py:86 DEBUG end <{http://jabber.org/protocol/muc#user}x> level=2
>>>>> 08/09/2006 11:15:27 AM -1345344608 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}presence> level=1
>>>>> 08/09/2006 11:15:27 AM -1345344608 JabberClient JabberClient.py:145 DEBUG ag-tech-room(venueserver2.westgrid.ca)@conference.mcs.anl.gov/Todd Zimmerman is available (None / None)
>>>>> 08/09/2006 11:15:27 AM -1345344608 VenueClient VenueClientUI.py:2299 DEBUG add user: Todd Zimmerman
>>>>> 08/09/2006 11:15:27 AM -1345344608 bajjer.io io.py:161 DEBUG RECV: <message type='groupchat' to='8180087163ff65364de2ad59cc6ba1e9 at jabber.mcs.anl.gov/default' from='ag-tech-room(venueserver2.westgrid.ca)@conference.mcs.anl.gov'><body>ag-tech-room(venueserver2.westgrid.ca)</body></message>
>>>>> 08/09/2006 11:15:27 AM -1345344608 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}message> level=1
>>>>> 08/09/2006 11:15:27 AM -1345344608 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}body> level=2
>>>>> 08/09/2006 11:15:27 AM -1345344608 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}body> level=2
>>>>> 08/09/2006 11:15:27 AM -1345344608 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}message> level=1
>>>>> 08/09/2006 11:15:27 AM -1345344608 JabberClient JabberClient.py:133 DEBUG ag-tech-room(venueserver2.westgrid.ca)@conference.mcs.anl.go: ag-tech-room(venueserver2.westgrid.ca)
>>>>> 08/09/2006 11:15:27 AM -1345344608 bajjer.io io.py:161 DEBUG RECV: <message type='groupchat' to='8180087163ff65364de2ad59cc6ba1e9 at jabber.mcs.anl.gov/default' from='ag-tech-room(venueserver2.westgrid.ca)@conference.mcs.anl.gov'><body>This room supports the MUC protocol.</body></message>
>>>>> 08/09/2006 11:15:27 AM -1376814176 VenueClient VenueClient.py:1260 DEBUG Got location from bridge: unicast milton.mcs.anl.gov 53368
>>>>> 08/09/2006 11:15:27 AM -1345344608 bajjer.io io.py:161 DEBUG RECV: <message type='groupchat' from='ag-tech-room(venueserver2.westgrid.ca)@conference.mcs.anl.gov' to='8180087163ff65364de2ad59cc6ba1e9 at jabber.mcs.anl.gov/default'><body>Todd Zimmerman has joined this session</body></message>
>>>>> 08/09/2006 11:15:27 AM -1345344608 JabberClient JabberClient.py:133 DEBUG ag-tech-room(venueserver2.westgrid.ca)@conference.mcs.anl.go: This room supports the MUC protocol.
>>>>> 08/09/2006 11:15:27 AM -1208600896 EventClient InsecureVenueEventClient.py:77 INFO BaseVenueEventClient lost connection.
>>>>> 08/09/2006 11:15:27 AM -1345344608 JabberClient JabberClient.py:133 DEBUG ag-tech-room(venueserver2.westgrid.ca)@conference.mcs.anl.go: Todd Zimmerman has joined this session
>>>>> 08/09/2006 11:15:27 AM -1376814176 VenueClient VenueClient.py:1260 DEBUG Got location from bridge: unicast milton.mcs.anl.gov 53100
>>>>> 08/09/2006 11:15:27 AM -1376814176 VenueClient VenueClient.py:1260 DEBUG Got location from bridge: unicast milton.mcs.anl.gov 53004
>>>>> 08/09/2006 11:15:27 AM -1208600896 GroupMsgClient GroupMsgClient.py:112 INFO Connected. Connection ID: 8180087163ff6536598e606758d7f94f
>>>>> 08/09/2006 11:15:27 AM -1208600896 EventClient InsecureVenueEventClient.py:60 INFO BaseVenueEventClient made connection.
>>>>> 08/09/2006 11:15:28 AM -1376814176 VenueClient VenueClient.py:1260 DEBUG Got location from bridge: unicast milton.mcs.anl.gov 52582
>>>>> 08/09/2006 11:15:28 AM -1376814176 RTPBeacon RTPBeacon.py:296 DEBUG Called Stop.
>>>>> 08/09/2006 11:15:28 AM -1376814176 VenueClient VenueClient.py:951 INFO Beacon being reconfigured, stopping running beacon
>>>>> 08/09/2006 11:15:28 AM -1376814176 VenueClient VenueClient.py:959 INFO VenueClient.StartBeacon: Address milton.mcs.anl.gov/52582
>>>>> 08/09/2006 11:15:28 AM -1376814176 RTPBeacon RTPBeacon.py:278 DEBUG Called Start.
>>>>> 08/09/2006 11:15:28 AM -1376814176 VenueClient VenueClient.py:1190 DEBUG UpdateNodeService: Method UpdateNodeService called
>>>>> 08/09/2006 11:15:28 AM -1376814176 VenueClient VenueClient.py:1195 DEBUG Setting node service streams
>>>>> 08/09/2006 11:15:28 AM -1376814176 NodeService AGNodeService.py:328 INFO NodeService.SetStreams
>>>>> 08/09/2006 11:15:28 AM -1376814176 NodeService AGNodeService.py:257 INFO NodeService.GetServices
>>>>> 08/09/2006 11:15:28 AM -1398592608 ServiceManager AGServiceManager.py:218 INFO AGServiceManager.GetServices
>>>>> 08/09/2006 11:15:28 AM -1376814176 NodeService AGNodeService.py:695 INFO NodeService.__SendStreamsToService
>>>>> 08/09/2006 11:15:28 AM -1376814176 NodeService AGNodeService.py:699 DEBUG service capabilities: [consumer, audio, 8e3a358333096536dec30af9596ae5ae, L16, 16000, 1, consumer, audio, 8e3a358333096536dec30af9596ae5ae, L16, 8000, 1, consumer, audio, 8e3a358333096536dec30af9596ae5ae, L8, 16000, 1, consumer, audio, 8e3a358333096536dec30af9596ae5ae, L8, 8000, 1, consumer, audio, 8e3a358333096536dec30af9596ae5ae, PCMU, 16000, 1, consumer, audio, 8e3a358333096536dec30af9596ae5ae, PCMU, 8000, 1, consumer, audio, 8e3a358333096536dec30af9596ae5ae, GSM, 16000, 1, consumer, audio, 8e3a358333096536dec30af9596ae5ae, GSM, 8000, 1, producer, audio, 8e3a358333096536dec30af9596ae5ae, L16, 16000, 1]
>>>>> 08/09/2006 11:15:28 AM -1376814176 NodeService AGNodeService.py:713 INFO Sending stream (type=[consumer, audio, 8180087163ff629be074b224aad547b3, L16, 16000, 1, consumer, audio, 8180087163ff629be074b224aad547b3, L16, 8000, 1, consumer, audio, 8180087163ff629be074b224aad547b3, L8, 16000, 1, consumer, audio, 8180087163ff629be074b224aad547b3, L8, 8000, 1, consumer, audio, 8180087163ff629be074b224aad547b3, PCMU, 16000, 1, consumer, audio, 8180087163ff629be074b224aad547b3, PCMU, 8000, 1, consumer, audio, 8180087163ff629be074b224aad547b3, GSM, 16000, 1, consumer, audio, 8180087163ff629be074b224aad547b3, GSM, 8000, 1]) to service: http://floyd.irmacs.sfu.ca:56488/Services/AudioService.8e3a358333096536decfdc29e8e7216d
>>>>> 08/09/2006 11:15:28 AM -1376814176 NodeService AGNodeService.py:699 DEBUG service capabilities: [producer, debug, None, None, None, 1, consumer, debug, None, None, None, 1]
>>>>> 08/09/2006 11:15:28 AM -1376814176 NodeService AGNodeService.py:718 ERROR Exception in AGNodeService.__SendStreamsToService.
>>>>> File "/usr/lib/python2.4/site-packages/AccessGrid/AGNodeService.py", line 708, in __SendStreamsToService
>>>>> if c.matches(cap):
>>>>> File "/usr/lib/python2.4/site-packages/AccessGrid3/AccessGrid/Descriptions.py", line 314, in matches
>>>>> if (str(self.type) != str(capability.type) or
>>>>> TypeError: int() argument must be a string or a number
>>>>> 08/09/2006 11:15:28 AM -1376814176 VenueClient VenueClient.py:1199 ERROR Error setting streams
>>>>> File "/usr/lib/python2.4/site-packages/AccessGrid3/AccessGrid/VenueClient.py", line 1197, in UpdateNodeService
>>>>> self.nodeService.SetStreams( self.streamDescList )
>>>>> File "/usr/lib/python2.4/site-packages/AccessGrid/AGNodeService.py", line 340, in SetStreams
>>>>> self.__SendStreamsToService( service.uri )
>>>>> File "/usr/lib/python2.4/site-packages/AccessGrid/AGNodeService.py", line 723, in __SendStreamsToService
>>>>> SetStreamException: Error updating [producer, debug, None, None, None, 1, consumer, debug, None, None, None, 1]
>>>>> 08/09/2006 11:15:28 AM -1376814176 VenueClient VenueClient.py:914 DEBUG Updating client profile cache.
>>>>> 08/09/2006 11:15:28 AM -1225692256 RTPBeacon RTPBeacon.py:289 INFO RTPBeacon.UpdateThread exiting
>>>>> 08/09/2006 11:15:30 AM -1208600896 NodeService AGNodeService.py:275 INFO NodeService.SetServiceEnabled
>>>>> 08/09/2006 11:15:30 AM -1208600896 NodeService AGNodeService.py:248 INFO NodeService.GetServiceManagers
>>>>> 08/09/2006 11:15:30 AM -1225692256 ServiceManager AGServiceManager.py:218 INFO AGServiceManager.GetServices
>>>>> 08/09/2006 11:15:35 AM -1208600896 NodeManagementUIClasses NodeManagementUIClasses.py:1036 DEBUG NodeManagementClientFrame.EnableService: Enabling Service: DebugService
>>>>> 08/09/2006 11:15:35 AM -1208600896 NodeService AGNodeService.py:275 INFO NodeService.SetServiceEnabled
>>>>> 08/09/2006 11:15:35 AM -1208600896 NodeService AGNodeService.py:695 INFO NodeService.__SendStreamsToService
>>>>> 08/09/2006 11:15:35 AM -1208600896 NodeService AGNodeService.py:699 DEBUG service capabilities: [producer, debug, None, None, None, 1, consumer, debug, None, None, None, 1]
>>>>> 08/09/2006 11:15:35 AM -1208600896 NodeService AGNodeService.py:718 ERROR Exception in AGNodeService.__SendStreamsToService.
>>>>> if c.matches(cap):
>>>>> 08/09/2006 11:15:35 AM -1208600896 NodeService AGNodeService.py:282 ERROR http://floyd.irmacs.sfu.ca:64864/Services/DebugService.8e3a3583333a6536e9540206adb5e731
>>>>> 08/09/2006 11:15:35 AM -1208600896 NodeManagementUIClasses NodeManagementUIClasses.py:1043 ERROR Error enabling service
>>>>> File "/usr/lib/python2.4/site-packages/AccessGrid3/AccessGrid/NodeManagementUIClasses.py", line 1037, in EnableService
>>>>> 08/09/2006 11:15:38 AM -1208600896 NodeService AGNodeService.py:275 INFO NodeService.SetServiceEnabled
>>>>> 08/09/2006 11:15:38 AM -1208600896 NodeService AGNodeService.py:248 INFO NodeService.GetServiceManagers
>>>>> 08/09/2006 11:15:38 AM -1225692256 ServiceManager AGServiceManager.py:218 INFO AGServiceManager.GetServices
>>>>> 08/09/2006 11:15:40 AM -1208600896 NodeManagementUIClasses NodeManagementUIClasses.py:1036 DEBUG NodeManagementClientFrame.EnableService: Enabling Service: DebugService
>>>>> 08/09/2006 11:15:40 AM -1208600896 NodeService AGNodeService.py:275 INFO NodeService.SetServiceEnabled
>>>>> 08/09/2006 11:15:40 AM -1208600896 NodeService AGNodeService.py:695 INFO NodeService.__SendStreamsToService
>>>>> 08/09/2006 11:15:40 AM -1208600896 NodeService AGNodeService.py:699 DEBUG service capabilities: [producer, debug, None, None, None, 1, consumer, debug, None, None, None, 1]
>>>>> 08/09/2006 11:15:40 AM -1208600896 NodeService AGNodeService.py:718 ERROR Exception in AGNodeService.__SendStreamsToService.
>>>>> if c.matches(cap):
>>>>> 08/09/2006 11:15:40 AM -1208600896 NodeService AGNodeService.py:282 ERROR http://floyd.irmacs.sfu.ca:64864/Services/DebugService.8e3a3583333a6536e9540206adb5e731
>>>>> 08/09/2006 11:15:40 AM -1208600896 NodeManagementUIClasses NodeManagementUIClasses.py:1043 ERROR Error enabling service
>>>>> 08/09/2006 11:15:54 AM -1208600896 VenueClient VenueClientUI.py:2200 INFO --------- END VenueClient
>>>>> 08/09/2006 11:15:54 AM -1208600896 VenueClient VenueClient.py:1132 INFO ExitVenue
>>>>> 08/09/2006 11:15:54 AM -1208600896 VenueClient VenueClient.py:1173 INFO ExitVenue: Stopping node services
>>>>> 08/09/2006 11:15:54 AM -1208600896 NodeService AGNodeService.py:301 INFO NodeService.StopServices
>>>>> 08/09/2006 11:15:54 AM -1225692256 ServiceManager AGServiceManager.py:225 INFO AGServiceManager.StopServices
>>>>> 08/09/2006 11:15:55 AM -1208600896 NodeService AGNodeService.py:328 INFO NodeService.SetStreams
>>>>> 08/09/2006 11:15:55 AM -1208600896 NodeService AGNodeService.py:257 INFO NodeService.GetServices
>>>>> 08/09/2006 11:15:55 AM -1225692256 ServiceManager AGServiceManager.py:218 INFO AGServiceManager.GetServices
>>>>> 08/09/2006 11:15:55 AM -1208600896 NodeService AGNodeService.py:695 INFO NodeService.__SendStreamsToService
>>>>> 08/09/2006 11:15:55 AM -1208600896 NodeService AGNodeService.py:699 DEBUG service capabilities: [consumer, audio, 8e3a358333096536dec30af9596ae5ae, L16, 16000, 1, consumer, audio, 8e3a358333096536dec30af9596ae5ae, L16, 8000, 1, consumer, audio, 8e3a358333096536dec30af9596ae5ae, L8, 16000, 1, consumer, audio, 8e3a358333096536dec30af9596ae5ae, L8, 8000, 1, consumer, audio, 8e3a358333096536dec30af9596ae5ae, PCMU, 16000, 1, consumer, audio, 8e3a358333096536dec30af9596ae5ae, PCMU, 8000, 1, consumer, audio, 8e3a358333096536dec30af9596ae5ae, GSM, 16000, 1, consumer, audio, 8e3a358333096536dec30af9596ae5ae, GSM, 8000, 1, producer, audio, 8e3a358333096536dec30af9596ae5ae, L16, 16000, 1]
>>>>> 08/09/2006 11:15:56 AM -1208600896 NodeService AGNodeService.py:699 DEBUG service capabilities: [producer, debug, None, None, None, 1, consumer, debug, None, None, None, 1]
>>>>> 08/09/2006 11:15:56 AM -1208600896 NodeService AGNodeService.py:695 INFO NodeService.__SendStreamsToService
>>>>> 08/09/2006 11:15:56 AM -1208600896 NodeService AGNodeService.py:699 DEBUG service capabilities: [consumer, video, 8e3a358333036536de76e51f5b703c18, H261, 90000, 1, producer, video, 8e3a358333036536de76e51f5b703c18, H261, 90000, 1]
>>>>> 08/09/2006 11:15:56 AM -1208600896 VenueClient VenueClient.py:1103 DEBUG ExitVenue: Stop event client obj
>>>>> 08/09/2006 11:15:56 AM -1208600896 VenueClient VenueClient.py:1105 DEBUG ExitVenue: Remove event client reference
>>>>> 08/09/2006 11:15:56 AM -1208600896 VenueClient VenueClient.py:1110 INFO ExitVenue: Stopping text client
>>>>> 08/09/2006 11:15:56 AM -1208600896 JabberClient JabberClient.py:73 DEBUG Sending the presence to 'AG-Tech-Room(venueserver2.westgrid.ca)@conference.mcs.anl.gov/Todd Zimmerman' of type 'unavailable'...
>>>>> 08/09/2006 11:15:56 AM -1208600896 bajjer.io io.py:122 DEBUG SEND: <presence to="AG-Tech-Room(venueserver2.westgrid.ca)@conference.mcs.anl.gov/Todd Zimmerman" type="unavailable"><x /></presence>
>>>>> 08/09/2006 11:15:56 AM -1208600896 RTPBeacon RTPBeacon.py:296 DEBUG Called Stop.
>>>>> 08/09/2006 11:15:56 AM -1208600896 ServiceManager AGServiceManager.py:70 INFO AGServiceManager.Shutdown
>>>>> 08/09/2006 11:15:56 AM -1208600896 ServiceManager AGServiceManager.py:71 INFO Remove services
>>>>> 08/09/2006 11:15:56 AM -1208600896 ServiceManager AGServiceManager.py:208 INFO AGServiceManager.RemoveServices
>>>>> 08/09/2006 11:15:56 AM -1208600896 ServiceManager AGServiceManager.py:162 INFO AGServiceManager.RemoveService
>>>>> 08/09/2006 11:15:56 AM -1345344608 bajjer.io io.py:161 DEBUG RECV: <presence to='8180087163ff65364de2ad59cc6ba1e9 at jabber.mcs.anl.gov/default' type='unavailable' from='ag-tech-room(venueserver2.westgrid.ca)@conference.mcs.anl.gov/Todd Zimmerman'><x/><x xmlns='http://jabber.org/protocol/muc#user'><item affiliation='none' role='none'/></x></presence>
>>>>> 08/09/2006 11:15:56 AM -1345344608 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}presence> level=1
>>>>> 08/09/2006 11:15:56 AM -1345344608 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}x> level=2
>>>>> 08/09/2006 11:15:56 AM -1345344608 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}x> level=2
>>>>> 08/09/2006 11:15:56 AM -1345344608 bajjer.serialize serialize.py:72 DEBUG start <{http://jabber.org/protocol/muc#user}x> level=2
>>>>> 08/09/2006 11:15:56 AM -1345344608 bajjer.serialize serialize.py:72 DEBUG start <{http://jabber.org/protocol/muc#user}item> level=3
>>>>> 08/09/2006 11:15:56 AM -1345344608 bajjer.serialize serialize.py:86 DEBUG end <{http://jabber.org/protocol/muc#user}item> level=3
>>>>> 08/09/2006 11:15:56 AM -1345344608 bajjer.serialize serialize.py:86 DEBUG end <{http://jabber.org/protocol/muc#user}x> level=2
>>>>> 08/09/2006 11:15:56 AM -1366324320 RTPBeacon RTPBeacon.py:289 INFO RTPBeacon.UpdateThread exiting
>>>>> 08/09/2006 11:15:56 AM -1345344608 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}presence> level=1
>>>>> 08/09/2006 11:15:56 AM -1345344608 JabberClient JabberClient.py:148 DEBUG ag-tech-room(venueserver2.westgrid.ca)@conference.mcs.anl.gov/Todd Zimmerman is unavailable (None / None)
>>>>> 08/09/2006 11:15:56 AM -1345344608 VenueClient VenueClientUI.py:2313 DEBUG remove user: Todd Zimmerman
>>>>> 08/09/2006 11:15:58 AM -1208600896 ServiceManager AGServiceManager.py:162 INFO AGServiceManager.RemoveService
>>>>> 08/09/2006 11:16:00 AM -1208600896 ServiceManager AGServiceManager.py:162 INFO AGServiceManager.RemoveService
>>>>> 08/09/2006 11:16:02 AM -1208600896 ServiceManager AGServiceManager.py:73 INFO Stop network interface
>>>>> 08/09/2006 11:16:02 AM -1208600896 RTPBeacon RTPBeacon.py:296 DEBUG Called Stop.
