[AG-DEV] Custom Node Service Enabling/Disabling Problem
Thomas D. Uram
turam at mcs.anl.gov
Wed Aug 9 13:53:30 CDT 2006
Given that enable/disable works fine with the Audio and Video services,
I'm not sure what the problem is. I'd be happy to look at details of
the error from the logfile (don't have time to recreate the problem at
the moment). Also, which platform?
Tom
On 8/9/06 1:41 PM, Todd Zimmerman wrote:
> I'm having an issue with enabling/disabling a custom node service. I have since tried the same
> thing with the DebugService and it appears the same problem exists.
> Here is the behaviour:
> Start AG3 and connect to venue
> Bring up Node Configuration and add DebugService
> Disable/Enable service (works fine).
> Change Venues
> Disable service OK. Enable service fails. (in fact I think there is a failure when changing venues
> also... but didn't fully look at the logs.)
> Further, this (bug?) is also true when:
> Start AG3 - Add DebugService
> Connect to VenueServer
> Disable Debugservice (works fine)
> Enable Service fails.
> Is this a bug - shall I report it? Is it a problem with using the 2.4 Debug Service in AG3?
> Any help appreciated.
> Thanks!
> Todd
