[AG-DEV] Custom Node Service Enabling/Disabling Problem
Todd Zimmerman
toddz at sfu.ca
Wed Aug 9 13:41:57 CDT 2006
I'm having an issue with enabling/disabling a custom node service. I have since tried the same
thing with the DebugService and it appears the same problem exists.
Here is the behaviour:
Start AG3 and connect to venue
Bring up Node Configuration and add DebugService
Disable/Enable service (works fine).
Change Venues
Disable service OK. Enable service fails. (in fact I think there is a failure when changing venues
also... but didn't fully look at the logs.)
Further, this (bug?) is also true when:
Start AG3 - Add DebugService
Connect to VenueServer
Disable Debugservice (works fine)
Enable Service fails.
Is this a bug - shall I report it? Is it a problem with using the 2.4 Debug Service in AG3?
Any help appreciated.
Thanks!
Todd
