AG 2.3 Packaging
Thomas D. Uram
turam at mcs.anl.gov
Mon Sep 13 11:17:14 CDT 2004
I extracted SOAPpy from the source tarballs for 2.3beta2 and 2.3, and
got the diff below. It looks like the beta2 source you're using is from
cvs or 0.11.5, since it contains changes from well beyond the 4/29
release of 0.11.4.
It looks like our beta2 SOAPpy came from cvs at an earlier point, since
it includes files not in the release. In the final, we're using the
SOAPpy 0.11.4 release with a patched Server.py, which is better than
using cvs.
The additional output that Chris mentioned comes from verifying that all
CA certificates are in the user's cert repo each time an app is run.
Previously, this only happened when the cert repo was created, so with
the first app execution. Now that we're doing it each time, the text
appears each time. The text is printed to stderr by globus; since we
don't provide the source for it, and probably don't want to patch it, I
guess we'll have to live with it for now, and consider how to handle it
for the future.
If you run into any other problems, let us know.
Tom
diff SOAPpy-0.11.4.2.3beta2 SOAPpy-0.11.4.2.3
Only in SOAPpy-0.11.4.2.3beta2: .cvsignore
Only in SOAPpy-0.11.4.2.3beta2: ChangeLog
Only in SOAPpy-0.11.4.2.3beta2: LICENSE
Only in SOAPpy-0.11.4.2.3beta2: MANIFEST.in
Only in SOAPpy-0.11.4.2.3: PKG-INFO
Only in SOAPpy-0.11.4.2.3beta2: RELEASE_INFO
Common subdirectories: SOAPpy-0.11.4.2.3beta2/SOAPpy and
SOAPpy-0.11.4.2.3/SOAPpy
Only in SOAPpy-0.11.4.2.3beta2: SOAPpy.spec
Only in SOAPpy-0.11.4.2.3beta2: TODO
Common subdirectories: SOAPpy-0.11.4.2.3beta2/bid and SOAPpy-0.11.4.2.3/bid
Common subdirectories: SOAPpy-0.11.4.2.3beta2/contrib and
SOAPpy-0.11.4.2.3/contrib
Common subdirectories: SOAPpy-0.11.4.2.3beta2/docs and
SOAPpy-0.11.4.2.3/docs
Common subdirectories: SOAPpy-0.11.4.2.3beta2/tests and
SOAPpy-0.11.4.2.3/tests
Common subdirectories: SOAPpy-0.11.4.2.3beta2/tools and
SOAPpy-0.11.4.2.3/tools
Common subdirectories: SOAPpy-0.11.4.2.3beta2/validate and
SOAPpy-0.11.4.2.3/validate
Only in SOAPpy-0.11.4.2.3beta2: zope
Douglas Kosovic wrote:
> Hi Tom,
> On Mon, 2004-09-13 at 23:38, Thomas D. Uram wrote:
>>SOAPpy and pyGlobus should be the same in the 2.3beta2 and 2.3 source
>>tarballs.
> SOAPpy doesn't appear to be the same, I just did a diff between the two
> and placed the diff here:
> http://www.itee.uq.edu.au/~douglask/diff/SOAPpy.diff.txt
> I also checked pyGlobus and both appear to be identical.
>>I'll look today at the additional output that Chris mentioned,
>>and see if I can reduce/eliminate it.
> Thanks.
> Doug
