AG 2.3 Packaging
Ivan R. Judson
judson at mcs.anl.gov
Fri Sep 10 08:57:05 CDT 2004
Hey Doug,
There was an error in setup.py (we didn't remove the AGNodeService from the
list of bin scripts). I've corrected that. Can you try again and let me know
if it works?
--Ivan
PS - The log on the web was a really bighelp, if you can do that again it'd
be awesome!
> -----Original Message-----
> From: Douglas Kosovic [mailto:douglask at itee.uq.edu.au]
> Sent: Friday, September 10, 2004 8:25 AM
> To: Ivan R. Judson
> Cc: 'Chris Willing'; 'Eric Olson'; joseph at cs.usyd.edu.au;
> 'Steve Smith'; ag-dev at mcs.anl.gov; 'Thomas D. Uram'
> Subject: RE: AG 2.3 Packaging
> Hi Ivan,
> > These are worrisome. But I can't tell what's actually
> happening from them.
> > Can you send the full list?
> I have more or less the same problem Chris is describing, see
> the following for the BuildSnapshot.py output:
> http://www.itee.uq.edu.au/~douglask/log/
> In the log output you'll see the following line:
> cmd = cp QuickBridge /sandbox/agtk/dist-20040910_230034/bin
> Where dist-20040910_230034/bin is not a dir, but the copied
> QuickBridge file. So it is failing before that line.
> Thanks,
> Doug
