FW: [Pywebsvcs-talk] Creating WSDLs
Ivan R. Judson
judson at mcs.anl.gov
Thu May 20 15:08:55 CDT 2004
Charles works for Randy and Indiana University; this is an interesting thing
--ivan
> -----Original Message-----
> From: pywebsvcs-talk-admin at lists.sourceforge.net
> [mailto:pywebsvcs-talk-admin at lists.sourceforge.net] On Behalf
> Of Charles Moad
> Sent: Thursday, May 20, 2004 2:11 PM
> To: Charles Moad
> Cc: pywebsvcs-talk at lists.sourceforge.net; blunck at gst.com
> Subject: Re: [Pywebsvcs-talk] Creating WSDLs
> I found the problem. I needed to pass the namespace to
> the function registrations. Below is what the server code
> looks like now. I can run "python py2wsdl.py calculator.py >
> calculator.wsdl" to generate the wsdl file. It handles
> simple types right now, and I will consider adding complex
> types depending on the interest.
> calculator.py
> >> #!/usr/bin/python
> >> # py2wsdl
> >> # service Calculator
> >> # target impl:Calculator
> >> # location http://hostname:10081
> >> # int add int int
> >> # int subtract int int
> >> # double pi
> >> # py2wsdl
> >> import math
> >> import SOAPpy
> >> SOAPpy.Config.Debug=1
> >> def add(a, b):
> >> return a + b
> >> def subtract(a, b):
> >> return a - b
> >> def pi():
> >> return math.pi
> >> server = SOAPpy.SOAPServer(("euclid.uits.iupui.edu",
> 10081)) >> server.registerFunction(add) >>
> server.registerFunction(subtract) >>
> server.registerFunction(pi) >> >> server.serve_forever()
> Charles Moad wrote:
> > As promised here is the error output I am seeing. I am
> having trouble
> > getting the html debugging message for some reason.
> > >>> import SOAPpy
> > >>> p = SOAPpy.WSDL.Proxy('http://myhostname/calculator.wsdl')
> > >>> p.methods.keys()
> > [u'add', u'pi', u'subtract']
> > >>> p.pi()
> > <Fault SOAP-ENV:Client: No method impl:Calculator:pi found:
> > exceptions.KeyError u'impl:Calculator'>Traceback (most
> recent call last):
> > File "<stdin>", line 1, in ?
> > File "/usr/lib/python2.3/site-packages/SOAPpy/Client.py",
> line 421,
> > in __call__
> > return self.__r_call(*args, **kw)
> line 443,
> > in __r_call
> > self.__hd, self.__ma)
> line 357,
> > in __call
> > raise p
> > SOAPpy.Types.faultType: <Fault SOAP-ENV:Client: No method
> > impl:Calculator:pi found: exceptions.KeyError u'impl:Calculator'>
> > I would greatly appreciate it if anyone could isolate what
> this error is.
> > Thanks,
> > Charles Moad wrote:
> >> I have taken this into account. Python's dynamic
> typical would
> >> make it impossible to create a wsdl that correctly reflected the
> >> code. The way I handle this is by adding a header (in
> comments) that
> >> could be thought of as function declarations with expected
> types. I
> >> also include some other useful variables. Below is the
> file I have
> >> been working so far, a simple calculator service. This
> code is just
> >> like a java sample with Axis, and I can actually take my wsdl
> >> generator output and point it at the axis web service and it works.
> >> SOAPpy.SOAPServer chokes when a method is invoked. I get
> the error
> >> output exactly as I see it, and post it tomorrow. I mention the
> >> error I am seeing in more detail in a post below.
> >> I am attaching the wsdl file that my program outputs if anyone
> >> would like to try to see it they can reproduce the error. Please
> >> replace "hostname" accordingly.
> >> Thanks as always,
> >> Charlie Moad
> >> #!/usr/bin/python
> >> # py2wsdl
> >> # int add int int
> >> # double pi
> >> # py2wsdl
> >> import math
> >> import SOAPpy
> >> def add(a, b):
> >> return a + b
> >> def subtract(a, b):
> >> return a - b
> >> def pi():
> >> return math.pi
> >> server = SOAPpy.SOAPServer(("euclid.uits.iupui.edu", 10081))
> >> On May 19, 2004, at 3:47 PM, Christopher Blunck wrote:
> >>> Hi Charles-
> >>> I work with the ZSI project a lot, but have a little
> experience with
> >>> SOAPpy. I didn't respond because SOAPpy isn't my area of
> expertise,
> >>> but seeing as how nobody else responded I'll take a stab
> at it and
> >>> share my opinion on the concept of WSDL generation from a python
> >>> codebase: it's difficult.
> >>> It's difficult primarily because of Python's late dynamic
> binding.
> >>> It's fairly
> >>> straightforward to navigate a dictionary consisting of primitives
> >>> (Strings, ints, and the like) and produce a partially respectable
> >>> WSDL from the static code analysis. But, as soon as you
> introduce
> >>> more complex types (User, Loan, Vehicle, etc), it becomes more
> >>> difficult. How do you infer the "correct"
> >>> name for the parameter passed to the function:
> >>> def CreateLoan(loan): pass
> >>> In other languages that favor compile time type checking, this
> >>> translation from source code to WSDL is trivial (Java and
> C come to
> >>> mind). But in a dynamic langauge like Python it's difficult. I
> >>> believe this is the primary reason why not much work has been
> >>> performed in this arena.
> >>> If you have some reference code tho, I'm sure folks would love to
> >>> take a look at what you've accomplished! :)
> >>> -c
> >>> On Wed, May 19, 2004 at 03:34:14PM -0500, Charles Moad wrote:
> >>>> Alright, the lack of response lends me to believe
> there is not a
> >>>> solution. I have made fairly good progress on writing
> my own wsdl
> >>>> generator, but I am running into the problem that
> SOAPpy.SOAPServer
> >>>> does
> >>>> not seem to handle request correctly from a
> SOAP.WSDL.Proxy that is
> >>>> initialized from a wsdl. I have equivalent python and
> java services,
> >>>> and I can take the wsdl and point it at the java service
> running in
> >>>> Axis, and it works fine. The error I am getting says it
> can't find
> >>>> method "http://localhost:10081/:pi" when I am calling
> the pi() method.
> >>>> Thanks,
> >>>> Charles Moad wrote:
> >>>>> How would one go about creating a wsdl for a
> SOAPServer created
> >>>>> using SOAPpy? I am hoping there is an automated solution as
> >>>>> opposed to
> >>>>> a by-hand one.
> >>>>> Thanks,
> >>>>> Charles Moad
> > This SF.Net email is sponsored by: Oracle 10g
> > Get certified on the hottest thing ever to hit the
> market... Oracle 10g.
> > Take an Oracle 10g class now, and we'll give you the exam FREE.
> > http://ads.osdn.com/?ad_id=3149&alloc_id=8166&op=click
> > _______________________________________________
> > Pywebsvcs-talk mailing list
> > Pywebsvcs-talk at lists.sourceforge.net
> > https://lists.sourceforge.net/lists/listinfo/pywebsvcs-talk
> Get certified on the hottest thing ever to hit the market...
> Oracle 10g.
