venue clients and observers
Robert Olson
olson at mcs.anl.gov
Mon Mar 29 16:39:24 CST 2004
So I'm looking at adding the functionality where an failed invocation
through a VenueIW will trigger a callback to the app if it's an
exception that can be handled by some certmgr interaction with the user.
The notification ends up happening in a fault handler method in the
VenueClient object (that was registered as the fault handler on the
VenueIW). I need to get the invocation thru to the venue client UI and
eventually to the gui cert mgmt stuff.
At first blush, it seems I should be able to use an observer on the venue
client. It looks like for this, I'd need to add another method to
VenueObserver and its subclasses - does that fit with your design model?
--bob
