new pyGlbous
Thomas D. Uram turam at mcs.anl.gov
Wed Feb 11 10:59:23 CST 2004
Bob:
We've been working on getting gt2.4.3 working with pyGlobus from (their)
cvs, which meant conveying the diffs to Matt for integration.  If you've
added SSL exceptions to our pyGlobus, those changes also need to be
given to Matt for inclusion in the stock pyGlobus.  My understanding is
that's the only difference between their pyGlobus and ours, no?
Tom
Robert Olson wrote:
>Last I knew you and tom and eric and matt were all working on this; I can
>look at this if you guys give me some idea of what state things were left
>in. I have no idea other than that you were fighting with getting things
>compiled.
>On Mon, 9 Feb 2004, Ivan R. Judson wrote:
>>So not the latest from their cvs, then.  We need to get to that ASAP. We're
>>running down on time if we want to do any significant amount of testing.
>>Can you work through that and see what's left to do?
>>--Ivan
>>>-----Original Message-----
>>>From: Robert Olson [mailto:olson at mcs.anl.gov]
>>>Sent: Monday, February 09, 2004 4:44 PM
>>>To: judson at mcs.anl.gov; ag-dev at mcs.anl.gov
>>>Subject: RE: new pyGlbous
>>>At 04:39 PM 2/9/2004, Ivan R. Judson wrote:
>>>>By up-to-date, what do you mean specifically?
>>>Up to date with respect to the FL CVS repo, meaning it has
>>>the SSL exceptions support that the new cert mgr uses, and
>>>that it is compiled against a winglobus that's compiled
>>>against openssl 0.9.6c so that encrypted channels work.
>>>>--Ivan
>>>>>From: owner-ag-dev at mcs.anl.gov
>>>>>[mailto:owner-ag-dev at mcs.anl.gov] On Behalf Of Robert Olson
>>>>>Sent: Monday, February 09, 2004 4:08 PM
>>>>>To: ag-dev at mcs.anl.gov
>>>>>Subject: new pyGlbous
>>>>>Here:
>>>>>http://www-unix.mcs.anl.gov/~olson/AG/snaps/pyGlobus-2004-0209.exe
>>>>>you will find an up-to-date pyGlobus, built against the
>>>openssl that
>>>>>lets us use encrypted channels, and with ssl exceptions included
>>>>>(with a backwards-compatibility bit that lets it work
>>>properly with
>>>>>the 2.1.2 codebase).
>>>>>I'd like folks to give this a shot; if folks verify it
>>>works (or if
>>>>>time passes and noone says anything :-) I'll commit the cert mgmt
>>>>>code that depends on the exceptions being there for proper
>>>>>operation.
>>>>>--bob
URL: <http://lists.mcs.anl.gov/pipermail/ag-dev/attachments/20040211/d38ca504/attachment.htm>
More information about the ag-dev mailing list
